Avido's new WiBa Wireless and Stackable Power Bank and Charging Pad combines wireless charging with a wireless power bank, allowing for a completely wire-free iPhone charging experience both at home and on the go.
The WiBa kit comes with three pieces: a wireless charging pad, a 5,000 mAh battery pack, and a cable plus power adapter to power the wireless charging portion of the device. The battery pack is designed to charge on the charging pad with the iPhone able to charge on top of the battery pack, so you can charge both the iPhone and the battery pack all at once.
wibastackedup
Made from a white plastic with a soft rubber coating, the WiBa wireless charging pad is about the size of the iPhone X when it comes to length and width, but it's much thicker.
The accompanying power bank is crafted from the same material and is the same size and length as the wireless charging ‎pad. The power bank is even thicker than the pad, which means it's several times thicker than an iPhone X. Theoretically, you could pocket the power bank just like an iPhone X, but given its thickness, I'm not sure that you'd want to.
wibastackwithiphone
The power bank fits better in a bag or a backpack, but it's still going to take up more room than competing power banks that have the same battery capacity, which is one of the negatives to this accessory.
wibapowerbankwithiphone
Because it's the same size as the iPhone X, the wireless charging pad also has a somewhat bigger footprint than most upright wireless chargers, so it's going to take up more space on a desk than some charging options. Compared to round flat chargers, though, the rectangular shape of the WiBa takes up less overall desk real estate.
wibapowerbankinhand
At the bottom of the wireless charging pad, there's a magnetic attachment area where the power bank fits so that it can charge wirelessly. The magnet is nice because the power bank always slips right into the correct place when it needs to be charged with the charging pad, so I never had to fuss with it to find the ideal charging alignment.
There's also a magnet in the power bank, which works with a separate magnet attachment that's available for the iPhone to keep it in place while wirelessly charging. My test unit did not come with this accessory so I wasn't able to try it, but for those who don't mind a magnet stuck on the iPhone with adhesive, it should make wireless charging via the power bank more convenient.
Sans magnet, it's not really convenient to charge an iPhone with the wireless power bank unless it's set on a flat surface because the power bank has no way to attach to the iPhone.
On the wireless charging pad, there's a single USB-C port to connect it to the included power adapter, while the power bank features both a USB-C port and a USB-A port. The USB-C port can be used to charge the power bank more quickly if you don't want to use the wireless charging pad, while the USB-A port can be used to charge devices that don't support wireless charging.
wibapowerbankports
Both the power bank and the charging pad feature an Avido logo front and center, which I wasn't a fan of. The power bank has four white LEDs on one side that let you know the charge and a bright green LED on the other side when it's turned on. Both the green LED and the white LEDs come on when the side button is pressed and charging is activated, and the green LED in particular is distracting. It does, however, turn off after a few minutes.
wibapowerbankleds
While the iPhone 8, iPhone 8 Plus, and iPhone X support 7.5W wireless charging, the WiBa is limited to 5W charging speeds, which is another downside to the product. It does charge at 10W for Android devices, but Avido told me it was capped at 5W for "safety precautions."
Avido also pointed out that there's often not a huge difference between 5W and 7.5W charging, which is not untrue. I've tested a lot of wireless charging options both at 5W and at 7.5W. In the best of conditions, you can eke out about 10 to 12 percent more charge over the course of an hour with a 7.5W charger, but the difference can be lower based on temperature and other factors.
I still generally find it worthwhile to choose 7.5W over 5W when possible, so it is disappointing not to see 7.5W support in the WiBa, especially at a $100 price point.
In multiple tests in Airplane mode and starting at a 1 percent charge, the WiBa wireless charging pad and the power bank charged my phone to 28 to 34 percent over the course of an hour, which is what I'd expect to see from a 5W charger. 28 to 34 percent is less than the charge you can expect to see from a wired power bank in an hour's time, so this isn't the most efficient on-the-go charging method.
wibapowerbankpadlineup
The WiBa boasts a 5,000mAh battery that offers just about enough juice to charge an iPhone X from a dead battery to full once over. In two of my tests, the WiBa power bank charged my iPhone X to 85 percent before dying (again in Airplane mode) but in four other tests, it charged it up to 100 percent with about 5 percent of an additional charge left over.
It's safe to say that for the iPhone X, and the iPhone 8 Plus, which has a similar capacity battery, you can count on one additional full charge from the fully charged WiBa power bank. You might get one and a half to two full charges for the iPhone 8, which has a smaller battery.
wibachargingpad
As with the 5W charging limitation, I found the 5,000mAh capacity of the WiBa power bank to be disappointing given the size of the accessory and its price.
Bottom Line
The WiBa charger is a nice idea, and I can't argue that it's not convenient, but it doesn't feel like it's offering enough utility for the high price tag.
This is essentially a 5W wireless charger paired with a 5,000mAh battery pack. You can buy a 5,000mAh power bank on Amazon for about $10 to $15, and a wireless charger costs right around $15 to $20, for a total of $25 to $35.
That means Avido is charging quite a premium for the sake of convenience. Sure, you don't need to plug in the power bank while it charges or the iPhone while it charges from the power bank, but what's that shortcut worth?
I personally would opt for a standalone 7.5W wireless charger and wired power bank over this particular solution, but people who are looking for a grab and go no-hassle solution where the extra battery is simple to charge may prefer the WiBa setup.
I really would have liked to see a higher capacity battery with the WiBa, because a single extra charge for $100 doesn't feel worthwhile. Power banks that offer three times more capacity don't even cost $100.
It's also worth noting that wireless charging may not be the best power bank solution. Most people likely reach for a power bank when an iPhone's battery is critically low, and faster charging speeds are preferred in these situations. As a reminder, an hour of charging with the WiBa got my iPhone X to about 28 to 34% across multiple tests.
How to Buy
The WiBa Wireless and Stackable Power Bank and Charging Pad can be purchased from the Avido website for $99. An extra charging pad can be added for a total of $139.
Note: Avido provided MacRumors with a WiBa wireless charger and power bank for the purpose of this review, which was returned to Avido at the conclusion of the review. No other compensation was received.
Top Rated Comments
Return Zero Avatar
87 months ago
That awkward moment when the Tesla is 35% cheaper...
levitynyc Avatar
87 months ago
MacRumors said something was too expensive?
Imagine they ever did that to a product Apple made.
entropys Avatar
87 months ago
What I would like is a rubberised charger with same shape, with higher output but without the battery.
Something that can sit in the console of the car permanently connected to USB. The same shape would mean it was easy to ensure the phone is lined up properly for wireless, and the rubberised surface would stop it sliding around in the car.
OlliFlamme Avatar
87 months ago
Dude, let it go. You're hung up on a topic from over a year ago. I can't imagine why this obsession is stuck in your head.
Haha, @farewelwilliams had some point to make as a gentleman to supposedly another one. This is somehow funny to see popping up in this thread to begin with, but it seems to me that you are unable to regret and humbly approve a wrong statement. There’s a little bit of a mini Trump thing happening here. Better leave the lid on that pot, cause you are clearly not going to show the type of gentleman he wants to see.
You may guess who in conclusion is the real stuck in his head.
I don’t mean to shatter your ego, but know that to be a gentleman means you gotta be cool, are you cool?
[doublepost=1535693614][/doublepost]
It's a purple color that's since been discontinued. Ultraviolet.
https://www.apple.com/shop/product/MQT72ZM/A/iphone-x-silicone-case-ultra-violet
Good one, totally bulls eye :)
And all of a sudden, some individuals might think that this is an unfortunate discontinuation. :D
ChrisMoBro Avatar
87 months ago
And yet when Apple finally release their AirPower charging mat for the rumoured amount of either $149 - $199 not once will you say it’s too expensive.
Ion-X Avatar
87 months ago
Chargeception!
Popular Stories
AirPods Pro 3 Mock Feature
ipad air windows 11 arm
iphone 16 pro models 1
iOS 18
iPhone 17 Air Pastel Feature
iPhone 17 Air Launching Later This Year With These 16 New Features
Thursday April 24, 2025 8:24 am PDT by
While the so-called "iPhone 17 Air" is not expected to launch until September, there are already plenty of rumors about the ultra-thin device. Overall, the iPhone 17 Air sounds like a mixed bag. While the device is expected to have an impressively thin and light design, rumors indicate it will have some compromises compared to iPhone 17 Pro models, including only a single rear camera, a...
