Satechi's latest charger, the USB-C Magnetic Wireless Charging Cable, is modeled after Apple's MagSafe charger and includes a built-in magnet that allows it to attach to Apple's iPhone 12 devices, but it's not ‌MagSafe‌ and can charge Apple devices at a maximum of 7.5W rather than 15W.
satechi magnetic charger iphone
Since this is a Qi-based charger, it works with AirPods and also Android smartphones, and for Android smartphones that allow for faster charging, it can charge at up to 15W.
Design wise, Satechi's Magnetic Wireless Charging Cable looks similar to a ‌MagSafe‌ charger, but it is made from a space gray plastic with a white front that's not quite the same material as a ‌MagSafe‌ charger. The back of the Magnetic Wireless Charging Cable is slightly domed when attached to an ‌iPhone‌, so it doesn't quite sit flush and can rock a little, but I didn't find this to be a major issue because the rounded shape is so slight.
satechi magsafe comparison front
As with a ‌MagSafe‌ charger, the Magnetic Wireless Charging Cable attaches to the ring of magnets in one of Apple's ‌iPhone‌ 12 models or a ‌MagSafe‌ compatible case. There's a 1.5m cord along with a USB-C connector, but the charging cable does not come with a power adapter and you must supply an 18W+ charger.
satechi charger magsafe comparison
By default, the Magnetic Wireless Charging Cable can charge earlier iPhones because it's a Qi charger, but you're not going to get the same magnetic alignment unless you buy a secondary Satechi accessory, the Magnetic Sticker, which is available for ‌iPhone‌ 11 and ‌iPhone‌ 12 models. The Magnetic Sticker comes with a series of guides that let you know where to place it on an ‌iPhone‌ 11 or an ‌iPhone‌ 12.
satechi sticker guide magnetic
You peel off the guide, stick it to the appropriate phone, and then attach the magnet with adhesive. Once attached, the magnet that you've added to an ‌iPhone‌ is able to adhere to Satechi's charger with automatic alignment over the built-in wireless charging coil. The magnet is slim and it works well, making this a useful accessory for an ‌iPhone‌ 11, plus it can also be used to add magnets to non-MagSafe ‌iPhone‌ 12 cases to allow those cases to work with the Magnetic Wireless Charging Cable.
satechi iphone 11 pro max sticker
The Magnet Sticker is compatible with Apple's ‌MagSafe‌ Charger as well, though non-iPhone 12 models will still be limited to slower non-MagSafe charging speeds. I found the sticker to be useful for setting my iPhone 11 Pro Max to charge with my ‌MagSafe‌ Duo and the standard ‌MagSafe‌ Charger, so that might be worth picking up even if you don't plan to get the cable from Satechi. I was not able to use this with Belkin's new 3-in-1 MagSafe charger because the adhesive does not stay in place when the ‌iPhone‌ is positioned upright for charging, but it worked fine flat. Note that charging with the sticker using Apple's ‌MagSafe‌ chargers is limited to 7.5W.
satechi iphone 11 pro max sticker charger
I think the most logical use case for the Magnetic Wireless Charging Cable is with an ‌iPhone‌ 11 model and the Magnetic Sticker. At $29.99 + $9.99 for the sticker, it's reasonably priced, and the magnetic attachment makes it simpler to use than standard Qi-based wireless chargers where you might need to shift things around to get the alignment right.
The Magnetic Wireless Charging Cable is also fine for the ‌iPhone‌ 12 models, and I found that it attaches to the correct spot and charges at the advertised 7.5W speed, but it's just not as fast as ‌MagSafe‌. It has the same design as the ‌MagSafe‌ Charger and is just $10 cheaper, so ‌iPhone‌ 12 owners will likely be better served paying the extra $10 for the faster 15W ‌MagSafe‌ charging (or 12W if you have an iPhone 12 mini).
satechi magnetic charger iphone 2
There are already other "magnetic" chargers like this Satechi charger on the market, and there's a lot of potential for confusion here. Chargers that aren't official ‌MagSafe‌ chargers (Apple requires Made for ‌iPhone‌ certification for ‌MagSafe‌) are not going to charge an ‌iPhone‌ 12 model at 15W even though they're attaching to the ‌iPhone‌ magnetically, so those who want to make sure they're getting the fastest charging will need to double check labeling and advertised charging speed.
Bottom Line
As I said up above, I like the Magnetic Wireless Charging Cable paired with the Magnetic Sticker as a simple wireless charging solution for the ‌iPhone‌ 11 models, but it's not an accessory that I would recommend for the ‌iPhone‌ 12 models because for $10 more, you can get double the charging speed with the $39 ‌MagSafe‌ Charger.
That said, if you want something that's more affordable and don't mind the slower charging speeds, the Magnetic Wireless Charging Cable works as well as any Qi-based charger and has the benefit of easy-attach magnets.
How to Buy
The Magnetic Wireless Charging Cable can be purchased from the Satechi website for $29.99. The Magnetic Sticker is also available from Satechi for $9.99.
Note: Satechi provided MacRumors with a Magnetic Wireless Charging Cable and Magnetic Sticker for the purpose of this review. No other compensation was received.
Tag: Satechi
Top Rated Comments
ryanflanders256 Avatar
56 months ago
And then you're stuck with a big ol' sticker on the back of your phone. No thanks.
Mdracer Avatar
56 months ago
I feel as though wireless charging is going backwards. Now for best results we need a huge puck to travel with us for the convenience?
yurc Avatar
56 months ago
Well....this is basically wired charger...just not plugged into lightning port.
Apple_Robert Avatar
56 months ago
It looks like a product looking for a problem that doesn't exist. No, thank you.
larrylaffer Avatar
56 months ago
It's not MagSafe, therefore its MagUnsafe? MagDangerous?
PinkyMacGodess Avatar
56 months ago
I'm not sure this makes much sense.
They seem to be trying to 'have their cake and eat it too'?
Exploiting the MagSafe, without paying to exploit it? Skating on thin ice?
EDIT: MagSafe is small thin, sexy. Oh, and officially supported. A Qi charger with magnets is NOT officially 'MagSafe', but could ape it pretty well, I'd wager. But Official MagSafe has been a disappointment here. It doesn't work with an OtterBox Defender case. Ahh, but it fits perfectly into a clean spot on my desk charge the various versions of the AirPods. Lose-win situation? Win-win, expensive situation? It works! *sigh*
Popular Stories
Beyond iPhone 13 Better Triad
iOS 19 Roundup Feature
CarPlay Hero
iphone 16 pro models 1
Apple 2025 Thumb 1
iOS 18
Apple Releases iOS 18.4.1 With Bug Fixes
Wednesday April 16, 2025 10:11 am PDT by
Apple today released iOS 18.4.1 and iPadOS 18.4.1, minor updates to the iOS 18 and iPadOS 18 operating systems that came out last September. iOS 18.4.1 and iPadOS 18.4.1 come two weeks after the launch of iOS 18.4 and iPadOS 18.4. The new software can be downloaded on eligible iPhones and iPads over-the-air by going to Settings > General > Software Update. There have been complaints about ...
iPhone 6s MacRumors YouTube
Apple Says These Products Are Now Vintage
Tuesday April 15, 2025 9:53 am PDT by
Apple today updated its vintage products list to add the 2018 Mac mini and the iPhone 6s, devices that will get more limited service and repairs now that they are considered vintage. The iPhone 6s initially launched in 2015, but Apple kept it around as a low-cost device until 2018, which is why it is only now being added to the vintage list. The iPhone 6s had Apple's A9 chip, and it was...
tvOS 18 Thumb 1
Apple Releases tvOS 18.4.1
Wednesday April 16, 2025 10:04 am PDT by
Apple today released tvOS 18.4.1, a minor update to the tvOS 18 operating system that came out last September. tvOS 18.4.1 comes two weeks after Apple released tvOS 18.4, and it is available for the Apple TV 4K and Apple TV HD models. tvOS 18.4.1 can be downloaded using the Settings app on the ‌Apple TV‌. Open up Settings and go to System > Software Update to get the new software....
