Popular accessory brand Ugreen has built up a veritable lineup of portable power banks and chargers in the last few years, with several options to serve the needs of gadget users on the road. It can be hard to work out what kind of unit will meet your particular requirements, but if you are looking for a compact USB-C/A bank that has enough juice to fully recharge your smartphone and laptop and then some, Ugreen's Nexode 100W power bank could be worth considering.
1ugreen nexode 100w power bank
I've been testing out the Nexode for a few weeks now, and I've come away impressed enough that it's become an ever-present accessory in my laptop bag, and I don't leave the house without it when I'm working away from home.
Normally priced at $79.99 (and sometimes quite a lot cheaper if you shop around online), it's a compact, unassuming unit that weighs about 513 grams. While it's almost three times as heavy as an iPhone 15 Pro, its dimensions are pretty similar, and it's around 1.5x as thick as Apple's smartphone, which makes it pocketable if you're wearing a coat.
The flame-retardant plastic case is black on the back and painted in metallic grey on one side and around the edges. It's soft to the touch, but its smoothness suggests it will scratch easily, which is why I keep it in the supplied draw-string velvety pouch when it's not in use. The included USB-C to USB-C cable is around 18 inches long, and also fits snugly inside.
3ugreen nexode 100w power bank
On one side of the unit is a button that when pressed illuminates a simple LCD readout that tells you the percentage of charge left in its five 21700 battery cells, which together total 20,000mAh capacity. The power bank itself supports fast charging at a maximum 65W. With a charger that takes advantage of that, the unit reaches 50% capacity in about 50 minutes, and full capacity in about 110 minutes, so you can basically look at the LCD percentage readout to get a fairly good idea of how its progressing. The bank is also capable of charging your devices while being charged itself.
On one side of the bank are three ports: The IN1/OUT1 is a USB-C port that's used to charge the Nexode, but it's also the connector to use if you want to charge a device at the maximum 100W output. Then there's secondary USB-C and USB-A ports, allowing you to charge up to three devices simultaneously.
I've been charging my M3 MacBook Air 13-inch using the maximum 100W fast charging speed, and from 10% battery it can bring my laptop up to a 50% charge in around 25 minutes, and fully charge it in about an hour, with around 10% of juice in the bank to spare. When I plug in my ‌iPhone‌ 15 Pro when it's hovering around 10%, it hits 60% charge in half an hour, and fully charges in under an hour, with enough left in the power bank's tank to fully recharge the ‌iPhone‌ from almost dead more than twice over.
7ugreen nexode 100w power bank
Those charge times, while swift, do depend on nothing else being connected to the power bank, because that's when the variable output changes. With more than one device plugged in, the 100W port is limited to 65W, which still isn't bad, but the wait time obviously goes up. On their own, the second USB-C port maxes out at 30W, while the USB-A port can handle 22.5W, both of which are good for AirPods or an Apple Watch (if both gadgets are connected, pressing the unit's button three times in succession activates a small-current mode).
2ugreen nexode 100w power bank
That said, if all three ports are active, the two secondary ports share 20W, although that doesn't affect the 100W rate, which feels reasonable for a power bank on a single charge. Regardless, the overall capacity of the unit means that I've been able to work away from home all day without having to worry if I'll have access to a power outlet – even if my MacBook hasn't been charged to full overnight.
Similarly, heading out for a weekend away with a fully charged MacBook and ‌iPhone‌, it's easily met my needs, even when I've not had easy access to power. All in all, the Ugreen Nexode 100W hasn't let me down. There may be no bells and whistles to speak of, but that helps keep the price reasonable.
ugreen nexode 100w
As an Amazon Prime Day deal, the Ugreen Nexode 100W 20000mAh Power Bank is available from Amazon and the Ugreen website, priced at $54.39 (down from the regular $79.99 list price).
Note: Ugreen provided MacRumors with the Nexode 100W 20000mAh Power Bank for the purpose of this review. No other compensation was received. MacRumors is an affiliate partner with Amazon. When you click a link and make a purchase, we may receive a small payment, which helps us keep the site running.
Tag: Ugreen
Top Rated Comments
zorinlynx Avatar
19 months ago
How many watt-hours? Don't they realize mAH is a useless measurement unless the voltage of the internal battery is known?
CarAnalogy Avatar
19 months ago
All of a sudden I see Ugreen everywhere. Now I want to look into their background. Seems they're the new Anker. I wonder what the story is there.
fbr$ Avatar
19 months ago
I have the 140W 25000mAh version bought from Ugreen Official Store on Aliexpress. I can't tell much about it because I haven't used it much yet.
Link:
https://a.aliexpress.com/_mMih4oG
I guess you assume 3.3V or 3.7V (don't remember exactly which one), so every 1A would correspond to 3.3W or 3.7W.
So: 20000mAh = 20Ah ---> 66Wh or 74Wh.
Realityck Avatar
19 months ago
Enough with USB-A already.
It has to do with using other adapters and devices likely lightning based (example USB-A to Lightning cables). Not everything that a person has is USB-C only.
It least its not a two USB-A one USB-C Power bank, there are still a lot of those out there. ;)
roar08 Avatar
19 months ago
#ankerforever
Fuzzball84 Avatar
19 months ago
I’ve used a few of their cable accessories and found them to be very high quality indeed. Not used any of their power tech yet but if of same standard I think you could say on par with Anker or even better.
I’m always hesitant with third party accessories but Ugreen have impressed me for sure on the items I’ve used so far.
Popular Stories
iphone 17 models
No iPhone 18 Launch This Year, Reports Suggest
Thursday January 1, 2026 8:43 am PST by
Apple is not expected to release a standard iPhone 18 model this year, according to a growing number of reports that suggest the company is planning a significant change to its long-standing annual iPhone launch cycle. Despite the immense success of the iPhone 17 in 2025, the iPhone 18 is not expected to arrive until the spring of 2027, leaving the iPhone 17 in the lineup as the latest...
duolingo ad live activity
Duolingo Used iPhone's Dynamic Island to Display Ads, Violating Apple Design Guidelines
Friday January 2, 2026 1:36 pm PST by
Language learning app Duolingo has apparently been using the iPhone's Live Activity feature to display ads on the Lock Screen and the Dynamic Island, which violates Apple's design guidelines. According to multiple reports on Reddit, the Duolingo app has been displaying an ad for a "Super offer," which is Duolingo's paid subscription option. Apple's guidelines for Live Activity state that...
Clicks Communicator Feature
'Clicks Communicator' Unveiled — Will You Carry This With Your iPhone?
Friday January 2, 2026 6:35 am PST by
The company behind the BlackBerry-like Clicks Keyboard accessory for the iPhone today unveiled a new Android 16 smartphone called the Clicks Communicator. The purpose-built device is designed to be used as a second phone alongside your iPhone, with the intended focus being communication over content consumption. It runs a custom Android launcher that offers a curated selection of messaging...
Low Cost A18 Pro MacBook Feature Pink
Apple's 2026 Low-Cost A18 Pro MacBook: What We Know So Far
Friday January 2, 2026 4:33 pm PST by
Apple is planning to release a low-cost MacBook in 2026, which will apparently compete with more affordable Chromebooks and Windows PCs. Apple's most affordable Mac right now is the $999 MacBook Air, and the upcoming low-cost MacBook is expected to be cheaper. Here's what we know about the low-cost MacBook so far. Size Rumors suggest the low-cost MacBook will have a display that's around 13 ...
Low Cost MacBook Feature A18 Pro
Low-Price 12.9-Inch MacBook With A18 Pro Chip Reportedly Launching Early This Year
Friday January 2, 2026 9:08 am PST by
Apple plans to introduce a 12.9-inch MacBook in spring 2026, according to TrendForce. In a press release this week, the Taiwanese research firm said this MacBook will be aimed at the entry-level to mid-range market, with "competitive pricing." TrendForce did not share any further details about this MacBook, but the information that it shared lines up with several rumors about a more...
Apple Fitness Plus hero
Apple Announces New Fitness+ Workout Programs, Strava Challenge, and More
Friday January 2, 2026 6:43 am PST by
Apple today announced a number of updates to Apple Fitness+ and activity with the Apple Watch. The key announcements include: New Year limited-edition award: Users can win the award by closing all three Activity Rings for seven days in a row in January. "Quit Quitting" Strava challenge: Available in Strava throughout January, users who log 12 workouts anytime in the month will win an ...
govee floor lamp
CES 2026: Govee Announces New Matter-Connected Ceiling and Floor Lights
Sunday January 4, 2026 5:00 am PST by
Govee today introduced three new HomeKit-compatible lighting products, including the Govee Floor Lamp 3, the Govee Ceiling Light Ultra, and the Govee Sky Ceiling Light. The Govee Floor Lamp 3 is the successor to the Floor Lamp 2, and it offers Matter integration with the option to connect to HomeKit. The Floor Lamp 3 offers an upgraded LuminBlend+ lighting system that can reproduce 281...
Belkin 25W Battery magnetic
CES 2026: Belkin Announces Magnetic Ring Power Bank, Modular Dock, and More
Sunday January 4, 2026 3:02 pm PST by
Belkin today announced a range of new charging and connectivity accessories at CES 2026, expanding its portfolio of products aimed at Apple device users. UltraCharge Pro Power Bank 10K with Magnetic Ring The lineup includes new Qi2 and Qi2.2 wireless chargers, magnetic power banks, a high-capacity laptop battery, and USB-C productivity accessories, with an emphasis on higher charging...
