When it comes to the MagSafe power bank marketplace, it's largely a sea of sameness. Not this one. Kuxiu's S2 stands apart with its semi-solid state battery technology that promises enhanced safety and longevity, albeit at a steeper price than conventional alternatives.
kuxiu solid state power bank 0
Design and Features
The Kuxiu S2 is a sleek, compact Qi2 unit with a premium construction that has four key components: a magnetic wireless charging area on top, a power button on the side, a USB-C input/output port (braided USB-C cable included), and LED indicator lights that display battery level. The aluminum alloy frame is paired with matte Corning Gorilla Glass panels, and the pack feels like it can take a whack – though it's not impervious to cosmetic scratches, as a couple of weeks' reviewing attest.
At just 143g (5.04oz) and measuring 106 × 69.5 × 10mm (4.17 × 2.74 × 0.39in), it's impressively portable and lighter than an iPhone 16. That said, when attached to my iPhone 16 Pro, the battery extends slightly beyond the phone's bottom edge, creating a minor asymmetry that likely isn't an issue when paired with the iPhone 16 Pro Max. The cameras remain unobstructed, at least.
s2
The S2 has a handy LED indicator system, with four lights showing battery levels: 4 LEDs (>75%), 3 LEDs (>50%), 2 LEDs (>25%), and 1 LED (>10%). When battery drops below 10%, a single LED flashes. There's also a special LED pattern – four lights flickering like a running light – that indicates Small Current Mode is active (more on that below).
The Solid State Difference
In a departure from traditional lithium-ion alternatives, the S2's headline feature is its semi-solid state battery technology. This design eliminates leakage, explosion, and combustion risks. Kuxiu claims the battery can survive nail penetration tests without catching fire or exploding – and based on the company's own dramatic demonstration videos, it continues to function even after such extreme damage.
Despite some confusion on the labeling (which reads "Li Polymer Battery"), Kuxiu confirmed that the S2 does indeed use semi-solid state technology. The solid electrolyte inside can be made from various materials, including polymers – making both claims technically accurate.
Performance and Functionality
The 5,000mAh capacity power bank supports both 15W wireless charging for the iPhone 12 through iPhone 16 series and wired charging at up to 20W via USB-C. The USB-C input specs show it accepts 5V⎓3A/9V⎓2.2A for charging itself.
kuxiu power bank photos3
The manual recommends a first-use procedure: discharging the power bank completely until it shuts off (0%) before fully charging to 100%, preferably with a PD fast charger for optimal speed.
There are three main charging modes: wireless charging (with MagSafe activation), wired charging for other smartphones, and a dedicated Small Current Charging mode. This special mode is activated by double-clicking the power button, and is designed specifically for low-power devices like earbuds and smartwatches that might not draw enough power to keep the bank from auto-shutting off. I had no problems drawing power to charge AirPods Pro via MagSafe and Apple Watch via the charging port.
AirPods
In my testing with an iPhone 16 Pro, the fully charged S2 brought my completely drained phone to 97% before depleting – slightly less than Kuxiu's claim of "approximately 1.2 full charges." The 16 N52 magnets provide a reassuringly strong connection that maintains its grip even when slipped into a loose pocket or bag. If your iPhone has a non-MagSafe case though, the bank is eventually going to slip off.
One particularly impressive aspect is the thermal management. Some slim power banks can become alarmingly hot during discharge (especially at low charge levels), but the S2 remained noticeably cooler in my experience.
Longevity and Value
Here's where the semi-solid state technology really shines. While the S2's $79.99 price tag is approximately 60% higher than comparable liquid-based power banks from companies like Anker or EcoFlow, the longevity benefits are substantial. Kuxiu claims the S2 will maintain 80% of its original capacity after 1,000 charging cycles, compared to just 300-500 cycles for traditional power banks. That's potentially double or triple the useful lifespan.
The efficiency is equally impressive. A full discharge offers 18-19Wh capacity power output, which is excellent after accounting for conversion losses. Looking long-term, this efficiency combined with extended cycle life makes the premium price more palatable.
Summing Up
KUXIU S2 Black 12
The Kuxiu S2 feels like a genuine step forward in power bank technology. The $79.99 price tag initially stings, but when you consider the potential for double or triple the lifespan of conventional alternatives, along with enhanced safety and premium materials, the value proposition becomes clearer. For those who frequently rely on portable power, the investment should pay dividends over time.
What's missing? A kickstand would be nice. Some users might also miss the iOS widget integration that was available in Kuxiu's previous S1 model. Due to Qi2 certification requirements, the S2 doesn't offer the satisfying iOS integration that Apple's own MagSafe battery pack provided – no special animation on the lock screen or appearance in the battery widget. Don't get me wrong, it works flawlessly. It just doesn't feel as "Apple-like" as some might prefer. But these are minor quibbles against what appears to be a genuinely innovative product. If safety and longevity matter more to you than saving a few dollars upfront, the Kuxiu S2 deserves consideration.
Where to Buy
KUXIU S2 Black 1 357e301f 2351 40b4 b983 e7c279d1ad83
The Kuxiu S2 Qi2 5000mAh MagSafe Solid-State Power Bank is available in black or natural titanium colors for $79.99 from Kuxiu's website and authorized resellers.
Top Rated Comments
FreeLunch1 Avatar
2 days ago at 07:21 am
"That said, when attached to my iPhone 16 Pro, the battery extends slightly beyond the phone's bottom edge"
The fundamental flaw here is that the product doesn’t properly fit a standard iPhone 16 Pro - and that should be made clear. There was a lack of attention to detail during design. The marketing photos conveniently obscure this issue, and even MacRumors photos appear to be glossing over it in their images vs pointing out the flaw.
If you’re going to review or promote products, clarity and transparency matter. Being upfront builds trust and credibility - glossing over major flaws doesn’t.
Score: 14 Votes (Like | Disagree)
surfzen21 Avatar
2 days ago at 06:27 am
I'm assuming the EU will mandate this is all phones by 2027 for safety reasons.
**Edit** I mistakenly typed EA instead of EU. I am preserving the original here so I can be properly roasted but changing it above so my actual intention is properly represented.
Thank you for coming to my TED Talk.
el-John-o Avatar
2 days ago at 06:50 am
I'm assuming the EA will mandate this is all phones by 2027 for safety reasons.
EA? Like the people who make Madden?
I knew they were getting big but wow, I had no idea that they were policymakers now.
spillled typos Avatar
2 days ago at 06:38 am
It sure would be nice to not have ticking time bombs in all our pockets.
mazz0 Avatar
2 days ago at 06:52 am
If they do mandate solid state batteries, I'll be pirating mine. I never give EA money.
AppleofyourI Avatar
2 days ago at 07:49 am
Who is going to use a single battery bank for 1000 cycles? Maybe heavy travelers? By the time you get to 1000 cycles, phone batteries will be very large and the bank will not be powerful enough. It's like an EV with a 1,000,000 mile battery. No one is keeping their car for 1M miles. People upgrade.
In the end, most people pay more for a feature they will never use...
Popular Stories
iOS 18
Here Are Apple's Full iOS 18.5 Release Notes
Tuesday May 6, 2025 2:17 pm PDT by
Apple today seeded the release candidate version of iOS 18.5 to developers and public beta testers, giving us a look at the final version of the update that will be provided to the public next week. With the release candidate, Apple provided release notes, so we have a more complete look at the new features that are included in the update, including those that weren't found during the beta...
siri glow
iPhone Users Now Able to Submit Claims in $95 Million Siri Spying Lawsuit
Wednesday May 7, 2025 11:40 am PDT by
If you owned a Siri-compatible device and had an accidental Siri activation between September 17, 2014 and December 31, 2024, you could be eligible for a payment from Apple as part of a class action lawsuit settlement. Apple in January agreed to pay $95 million to settle a class action lawsuit involving Siri spying accusations, and a website to distribute the funds has now been set up and...
iPhone 17: What's New With the Cameras
Friday May 2, 2025 3:52 pm PDT by
We've still got months to go before the new iPhone 17 models come out, but a combination of dummy models and leaks have given us some insight into what we can expect in terms of camera changes. Apple is adding new camera features, and changing the design of the camera bump for some models. You might be skeptical of dummy models, but over the years, they've proven to be a highly accurate...
iOS 18
Apple Says iOS 18.5 Coming Soon, Here is What's New
Monday May 5, 2025 8:19 am PDT by
In its press release for the new Pride Band today, Apple said that iOS 18.5 is "upcoming," following more than a month of beta testing. We expect the iOS 18.5 Release Candidate to be released this week, and this should be the final beta version, barring any last-minute bugs or changes. The software update should then be released to the general public next week. iOS 18.5 is a relatively...
Nineth iOS 19 Feature
iOS 19 Beta is a Month Away With These New Features for Your iPhone
Thursday May 8, 2025 7:37 am PDT by
The first iOS 19 beta is just one month away, and there are already many new features and changes that are expected with it. Apple should seed the first iOS 19 beta to developers immediately following the WWDC 2025 keynote, which is scheduled for Monday, June 9. Following beta testing, the update should be released to the general public in September. Below, we recap the key iOS 19 rumors...
Apple's Foldable iPhone Display Tech May Set New Industry Standard
Thursday May 8, 2025 3:29 am PDT by
Apple's upcoming foldable iPhone will feature a new type of display panel developed by Samsung that has never been used in a foldable product, claims a source with links to Apple's supply chain. According to the account yeux1122 on the Korean Naver blog, the foldable iPhone will use a custom display process for which Apple will hold branding trademark rights, and that meets Apple's stringent ...
Foldable iPhone Said to Have Two Key Advantages
Monday May 5, 2025 6:41 am PDT by
Apple plans to release its first foldable iPhone next year, according to several reporters and analysts who cover the company. In his Power On newsletter today, Bloomberg's Mark Gurman said the foldable iPhone will offer two key advantages over other foldable smartphones. First, he said the foldable iPhone will have a "nearly invisible" crease when unfolded. This means the device's...
AirPods Pro 3 Mock Feature
Tuesday April 29, 2025 1:30 am PDT by
