Logitech-owned Jaybird has been designing Bluetooth earbuds since 2007 and has established itself as a manufacturer known for creating quality headphones ideal for working out.
Jaybird's latest product, Freedom, is the culmination of years of design refinements. The Freedom Wireless Buds are Jaybird's smallest and most comfortable yet, with a sleek sweat-proof design, multipoint pairing, and up to eight hours of battery life. As with most products, there are some downsides, so make sure to read on to find out what to expect from Jaybird's latest product.
jaybirdbox
Design and Fit
Jaybird's Freedom Buds are tiny, a feat achieved by moving many of the audio components from the earbuds themselves to the remote control. Jaybird sells the Freedom in a range of colors from white and black to red and blue, with the earbuds themselves made from metal with plastic accents.
Visually, they're smaller than any other earbuds on the market, but they look and feel like a quality product thanks to the metal design, a deviation from previous plastic earbud designs from Jaybird. These are wireless headphones, which means there's no wire to plug into your phone because they connect via Bluetooth. I loved the look of the gold and white Freedom earbuds I tested -- they're small and sleek, the perfect companion to an iPhone.
jaybirdboxopen
There's a cord that connects the two earpieces together, and on the right side of the cord, there's a remote. Unlike the earbuds themselves, there's nothing small about the remote. It houses all of the electronics normally located in the earbuds, and while it's not heavy, it is bulky. It measures in at nearly two inches long and 1/4 inch thick.
jaybirdearbudsremote
When it comes to earbuds, comfort is my number one priority. I have small ears and with most headphones, Apple's EarPods and UrBeats included, the insides of my ears start aching within a half an hour. The Freedom Buds are small enough that I barely feel them in my ears, even when using them for a couple of hours at a time.
jaybirdearbuds
With the wide range of tip options that come in the box, I suspect most users will be able to get a comfortable fit. There are silicone ear tips in small, medium, and large, plus Comply foam ear tips, also in small, medium, and large. I used the silicone tips while testing the Freedom Buds because the sound was better, but the foam tips were also comfortable.
jaybirdwhatsinthebox
The earbuds fit well in my ears, but getting them to stay in my ears was another issue. The bulk of the remote on the right earbud caused the earbuds to continually slip out of my ears and I was never really able to get a secure fit. Jaybird does include a set of ear fins with the earbuds, made of a soft, supple silicone, and that was the only way I could get them to stay put when moving around.
Jaybird says the Freedom Buds are sweat proof, and I didn't have any issues. I didn't run them under water or anything, but they definitely held up during regular activity.
Jaybird's earbuds can be worn in two ways, depending on user preference. You can wear them like standard earbuds under the ears, or you can wear them over-ear with the cord wrapped behind your ears. Wrapping the cord around the ears alleviates some of the bulk of the remote, and two cord management clips can customize the cord length and further relieve the remote weight to make the earbuds more comfortable.
Shortening the cord of the Freedom Buds meant the remote hung down a bit less and was less in the way, but no matter what, it always pulled on the right earbud and was a consistent irritation. With heavy activity, the earbuds had a tendency to slip out of my ear a bit because of the remote's weight, but clipping them to my shirt helped with the slippage, as did adding the fins.
jaybirdearbudsshortcord
Battery
The earbuds alone have a battery life of approximately four hours, but there's an extra charging clip you can clip on to the remote to extend battery to eight hours. Theoretically, you can use this clip while the earbuds are in use, but it was just too bulky, heavy, and silly looking for me to use the charging clip this way.
jaybirdearbudsremoteandcharger2
Made of black plastic, the charging clip snaps right onto the back of the remote. It's a battery in of itself, and it's also what's used to charge the Freedom Buds through a micro-USB port. The earbuds ship with a small micro-USB cable that can plug into any USB port or USB charger.
Frequent charging is one of the biggest downsides to wireless earbuds, and while I wasn't a fan of using the clip while wearing the earbuds, it was a clever accessory for charging on the go. Snapping the clip onto the earbuds while they were in my purse was a quick and easy way to recharge them without needing to plug them in and it ensured I was never stuck with dead earbuds. 20 minutes of charging offers an hour of music playback.
jaybirdearbudscharging
My one qualm with the clip is its size. It's small and easy to lose, and as far as I can tell, Jaybird isn't selling replacements yet. It's also worth noting that when you attach the clip to the remote while music is playing, it'll cut off and need to be restarted.
Jaybird put a lot of thought into making charging as easy as possible, even down to the user interface. When the earbuds are turned on, the battery level is announced, and it's also visible in the MySound app and in the Notification Center when connected to an iOS device.
An orange light is displayed when the earbuds are charging, and it changes to green once charging has completed. In my experience, it took just a couple of hours to charge the earbuds from dead to full.
Sound
I'm not an expert on sound, but as an average earbud user, the Jaybird Freedom sounds great -- better than other wireless earbuds I've tried and better than many of the wired earbuds I own.
Noise insulation and blocking isn't great, but because the earbuds are so small, it's possible to get a good seal in the ear for the best possible sound. With a tight seal, all of the music I played was crisp and balanced, especially after I adjusted the equalizer to my tastes with the MySound app. The only negative I noticed was somewhat muddy bass on bass heavy songs.
jaybirdapp
Volume wise, the earbuds got loud enough to block out almost any ambient noise while still sounding clear and non-distorted.
Using the app, it's possible to make minute adjustments and download sound profiles like "Bring the Bass," "R&B" Jams, and "Warmth." There are even sound profiles created by pro athletes like Sonya Looney and James Lawrence.
While sound is good, I wasn't impressed with the range of the Freedom Buds. Jaybird says optimal range is about two feet, and that was about accurate to me. Direct line of sight also seemed to be required for clear sound - stepping into another room could cause it to cut out, and holding my phone in certain positions outdoors also sound to cut out once or twice. Jaybird recommends an armband that keeps the iPhone above the elbow when using the earbuds outdoors.
I had no trouble connecting the earbuds to any Bluetooth device, from my Mac to my iPhone to my Apple Watch. It was all seamless and simple.
Other Features
In addition to offering volume up, volume down, and power buttons, the remote also incorporates double presses for additional functionality. Holding down on the volume up button goes to the next song, while holding down on the volume down button goes back to the previous song. A short press on the middle button initiates a redial, a longer press ends a call or activates Siri, and an even longer press turns the earbuds off.
There's a built-in microphone so the earbuds can be used for making phone calls, and the calls I made with it sounded loud and clear with no interference. When on a call, the buttons on the remote can be used to switch a call over to the Freedom, mute and un-mute, or place a call on hold and answer a second call.
A built-in "Multipoint" feature lets the earbuds pair with and connect to two different Bluetooth devices at once, allowing for quick switching. You can use the earbuds to listen to music on one device, like a Mac, and then switch over to answer a call, and there's also a sharing feature for listening to the same music on two sets of Freedom earbuds from one device.
Bottom Line
$200 is a lot to spend on earbuds. It's more than i normally spend because I'm prone to losing them, and I have mixed feelings on whether or not the Jaybird earbuds are worth the purchase price.
On one hand, I love the size, comfort, and long battery life, but that bulky remote was nearly a deal breaker for me, constantly getting in the way and pulling the earbuds out of my ears. It's entirely possible that due to my small ear size and ear shape, I wasn't able to get a good enough fit with the Freedoms to keep them in my ears, so others might have a different experience.
jaybirdearbudsfinalpic
If you can get a good, secure fit with Jaybird's latest earbuds, I think you'll be happy with them. The sound is great for the average user and they're undeniably comfortable, but you'll definitely be paying a premium for these features. At $200, the Freedom earbuds are pricier than quality options from competitors.
We all have different ear shapes so not every set of earbuds is going to fit every ear. I'd recommend giving the Freedom a try if you're looking for a set of premium wireless earbuds, but buy from Amazon so you have an easy way to return them if they don't work out.
Pros:
  • Tiny
  • Comfortable fit, even in small ears
  • Fins keep earbuds secure
  • Fins are comfortable to wear for hours at a time
  • On the go charging with battery dongle
  • Can customize sound with accompanying app
Cons:
  • Remote is bulky, weighs earbuds down
  • Remote pulls earbuds out of ear
  • Battery life is limited
  • Extra battery dongle is heavy/bulky
  • Battery dongle is easy to lose
How to Buy
Jaybird's Freedom Wireless Buds can be purchased from the Jaybird website or Amazon.com for $199.95.
Note: Jaybird provided the Freedom Wireless Buds to MacRumors free of charge for the purposes of this review. No other compensation was received.
Tag: Jaybird
Top Rated Comments
BeefCake 15 Avatar
114 months ago
Too bad their logo looks like fallopian tubes.
Nothing wrong with that
OLVFD Avatar
114 months ago
spinedoc77 Avatar
114 months ago
I'm a HUGE jaybird fan, starting with them on the original Freedom's I think about 6 or 7 years ago. Currently I have a couple of pairs of the X2's and find them amazing. I'm very tempted by these new ones, especially because they are smaller. My only caveats are the battery life, and the price is just way too much. If I usually wait a few months I would expect to see many sales on them, probably in the $120 range based on the sales I saw on the X2's 2-3 months after release. I think they are worth $120, but not $200.
s15119 Avatar
114 months ago
$200 and 4 hour battery. I'll pass. I agree with above poster, $20 is more my price range for ear budz
Mr. Donahue Avatar
114 months ago
200$!??!!!! For what?! Hindu cow! That's a lot of money.
bigjnyc Avatar
114 months ago
I would have to charge my x2's after two workouts so its not too much worse. I see a benefit in always keeping them in my bag and just charging the clip now. Every day to every 2 days difference. A Trade off for comfort/size/sound/look and customizability.
good point I can charge them while sitting at my desk at work. aaah who am i kidding I'll probably get them with the first price drop I see :D
Popular Stories
apple watch ultra yellow
What's Next for the Apple Watch Ultra 3 and Apple Watch SE 3
Friday April 25, 2025 2:44 pm PDT by
This week marks the 10th anniversary of the Apple Watch, which launched on April 24, 2015. Yesterday, we recapped features rumored for the Apple Watch Series 11, but since 2015, the Apple Watch has also branched out into the Apple Watch Ultra and the Apple Watch SE, so we thought we'd take a look at what's next for those product lines, too. 2025 Apple Watch Ultra 3 Apple didn't update the...
iPhone 17 Air Pastel Feature
iPhone 17 Air Launching Later This Year With These 16 New Features
Thursday April 24, 2025 8:24 am PDT by
While the so-called "iPhone 17 Air" is not expected to launch until September, there are already plenty of rumors about the ultra-thin device. Overall, the iPhone 17 Air sounds like a mixed bag. While the device is expected to have an impressively thin and light design, rumors indicate it will have some compromises compared to iPhone 17 Pro models, including only a single rear camera, a...
iphone 16 display
iPhone 17's Scratch Resistant Anti-Reflective Display Coating Canceled
Monday April 28, 2025 12:48 pm PDT by
Apple may have canceled the super scratch resistant anti-reflective display coating that it planned to use for the iPhone 17 Pro models, according to a source with reliable information that spoke to MacRumors. Last spring, Weibo leaker Instant Digital suggested Apple was working on a new anti-reflective display layer that was more scratch resistant than the Ceramic Shield. We haven't heard...
iPhone 17 Reaches Key Milestone Ahead of Mass Production
Monday April 28, 2025 8:44 am PDT by
Apple has completed Engineering Validation Testing (EVT) for at least one iPhone 17 model, according to a paywalled preview of an upcoming DigiTimes report. iPhone 17 Air mockup based on rumored design The EVT stage involves Apple testing iPhone 17 prototypes to ensure the hardware works as expected. There are still DVT (Design Validation Test) and PVT (Production Validation Test) stages to...
Beyond iPhone 13 Better Blue
20th Anniversary iPhone Likely to Be Made in China Due to 'Extraordinarily Complex' Design
Monday April 28, 2025 4:29 am PDT by
Apple will likely manufacture its 20th anniversary iPhone models in China, despite broader efforts to shift production to India, according to Bloomberg's Mark Gurman. In 2027, Apple is planning a "major shake-up" for the iPhone lineup to mark two decades since the original model launched. Gurman's previous reporting indicates the company will introduce a foldable iPhone alongside a "bold"...
top stories 2025 04 26
Top Stories: iPhone 17 Air Rumors, Apple Watch Turns 10, and More
Saturday April 26, 2025 6:00 am PDT by
We've known for quite some time about Apple's plans for a thinner "iPhone 17 Air" coming later this year, but wow, the latest dummy models give us our best look yet at just how thin this phone is going to be. Other Apple news and rumors this week included another iOS 18.5 beta, the 10th anniversary of the Apple Watch launch, and more management reshuffling in Apple's Siri division, so read...
