Aqara makes a range of HomeKit-compatible smart home devices for multiple regions around the world. This review takes a look at six of Aqara's most popular products, including the Camera Hub G2H, Motion Sensor, Door and Window Sensor, Water Leak Sensor, Vibration Sensor, and Single Switch Module T1.
aqara review main
With this broad selection of accessories, supported by the Camera Hub G2H, I was able to create a varied HomeKit setup and put Aqara's devices to the test. While Aqara does have its own app for controlling and setting up the accessories, it is possible to control, automate, and manage them entirely through Apple's Home app.
Designs
All of the Aqara smart home devices share the same minimalist design language. With the exception of the Water Leak Sensor, they each use a smooth, matte white plastic, almost like the texture of the Apple Pencil, with gray accents. The result feels high quality, and there is clear consistency across the family of devices.
I was very impressed by each product's design and it is noticeable how compact these devices are compared to many of their ‌HomeKit‌ competitors. This is especially important with smart home devices, where being discreet and fading into the background is vital.
Setup
For the Camera Hub G2H, users simply need to plug in the included micro-USB cable and download the Aqara app to begin the setup process. The Aqara app recognizes the Camera Hub on the network very quickly and automatically adds it to the Home app with all features, such as HomeKit Secure Video, ready to go.
Unlike many other smart home accessories I have used before, the G2H issues voice alerts to inform you about the status of the device, such as when it has been detected, is searching for a network, or has been successfully connected.
Setting up each of the other Aqara devices was even simpler. First, you open the Aqara app and select which accessory you would like to add. Then, you pull out the blue battery tab to power on the accessory and hold down the small pairing button. The Camera Hub G2H then issues voice alerts to clearly inform you that the new device has been detected, and a few moments later, added.
The voice alerts from the G2H are very loud and not entirely necessary, but the feature does add some clarity to what is going on in the pairing process at any given time.
I would have preferred it if I did not need to use a proprietary app, but overall, Aqara's setup process is one of the easiest I have experienced with ‌HomeKit‌. Where other accessories I have used have struggled to connect to the network or taken a few minutes to pair, Aqara's process was quick and hassle-free.
Camera Hub G2H
The Camera Hub G2H is a 1080p HomeKit-enabled smart camera with a 140-degree wide-angle lens. The camera features HomeKit Secure Video, two-way audio, and night-vision.
aqara review camera hub g2h 2
The base of the G2H rotates and folds out to orient the camera in any preferred direction, and it is also magnetic to attach to walls via a small metal plate included in the box. This plate can be affixed to a surface with an adhesive pad or directly screwed in. I was impressed by the amount of flexibility that the camera's fold-out base afforded, especially compared to some other smart cameras, and it was easy to quickly get it facing in the right direction.
aqara review camera hub g2h stand
The camera is powered via a standard micro-USB cable. Some other smart home cameras, such as the Logitech Circle 2, use a proprietary power cable, which makes it difficult to get hold of a longer cable if placing the camera further away from a power outlet, so the G2H's use of micro-USB makes it easy to obtain a longer cable if the one included in the box is insufficient for your setup.
The Camera Hub's support for HomeKit Secure Video allows it to encrypt and store footage in iCloud rather than on servers handled by Aqara. Recordings can be viewed in Apple's Home app, and all motion and people detection is done on-device for privacy purposes. Using ‌‌HomeKit Secure Video‌‌ requires an upgraded ‌‌iCloud‌‌ storage plan. Apple's 200GB plan supports one ‌‌HomeKit Secure Video‌‌ camera, while the 2TB plan supports up to five cameras.
The G2H also offers a standard night-vision mode and uses a small color-changing LED to indicate the device's status. While it is clear that the camera is not as crisp as some 4K alternatives and the colors were a little washed out, it copes well with different lighting situations and is more than acceptable for monitoring an area of the home.
In addition, the G2H features ‌HomeKit‌ two-way audio, allowing users to hear live audio from the camera and even communicate through its speaker via the Home app. The G2H's microphone apparently performs ambient noise reduction, but this was not especially noticeable to me during daily use. The speaker is very loud for its size and easily projects across a large room, and while it does not deliver the clearest possible sound, its quality is adequate for a brief voice message.
What makes the G2H different from many other cameras on the market is that it also functions as a Zigbee hub, allowing it to work as a local control center for other devices. This means that users do not need to connect a separate hub to their router to control Aqara's range of devices. As someone that already has a cluttered router with the likes of Philips Hue and Soma Connect Hubs taking up space and ethernet ports, the fact that the G2H doubles as a hub is an excellent idea, and it is good to see smart home accessory manufacturers finding innovative ways to stop relying on router-connected hubs.
The only downside to this solution is if you wish to use other Aqara devices without the camera, you would need to purchase a dedicated Aqara hub.
Motion Sensor
The Aqara Motion Sensor can detect movement within a range of 22 feet and 170 degrees. You can use the sensor to detect unexpected motion, such as to be alerted to a potential intruder, or simply for home automation to activate lights and other smart home devices.
aqara review motion sensor 2
The sensor is incredibly compact and light, making other motion sensors that I have used, such as the Philips Hue Motion Sensor, feel needlessly large and heavy. There is an LED embedded behind the sensor portion of the device to indicate status, but this remains off most of the time to fit in with the discreet design.
Furthermore, Aqara's motion sensor includes an optional fully-articulated stand, to allow for precise orientation. This base is adhesive to attach to a wall, and since the whole package is so light, I expect it would easily be strong enough to hold it. The stand makes Aqara's motion sensor much more versatile and easy to set up than many other motion sensors.
Aqara's Door and Window Sensor can detect whether a door or window is open or closed. The sensor can be used to alert users with a notification from the Home app when a door or window is opened unexpectedly, and the sensor can also activate ‌HomeKit‌ scenes, such as turning on lights when a door is opened. You can use Siri to ask if a door or window is open, or simply check the Home app.
aqara review door and window sensor
The Aqara Door and Window Sensor works with most types of doors, windows, and other fixtures with similar mechanisms, such as drawers, cabinets, and more, allowing for a gap of up to 22mm between the two parts.
I was struck by how small the sensor was, especially compared to the Elgato Door and Window Sensor, which is considerably thicker and bulkier. During daily use, the sensor was extremely responsive and updated the status in the Home app with virtually no delay.
Water Leak Sensor
Whenever the Aqara Water Leak Sensor detects water, it sends a notification via the Home app to your devices to alert you to leaks and potential flooding. While the main purpose of such a sensor is these alert notifications, it is also possible to set it to trigger ‌HomeKit‌ scenes.
aqara review water leak sensor
No wiring or screws are required to set up the sensor. You simply need to place it on a flat surface where you suspect dripping, leaking, or flooding could occur. The underside of the sensor has two sensitive leak probes which are able to detect up to 0.5mm of water, which is more than enough to be aware of an emergency leak.
The sensor has a durable IP67 water and rust-proof housing, and has a glossy plastic exterior for better water resistance.
To test the water sensor I tried tipping small amount of water under the device, and it immediately issued an alert notification to my devices via the Home app. After drying the sensor off on a towel, it was able to sense water again immediately.
Though the speed of the water detection was impressive and I was pleased that very little water was needed to initiate a detection, I was frustrated by the button on the sensor. The other Aqara devices have a small round button on their exterior for pairing, but due to the need for water resistance, the pairing button on the Water Leak Sensor is hidden under the top of the shell. Not only was it initially unclear where the button actually was, but it was also very difficult to press in due to the thickness of the shell. While it is true that users will very rarely have to press the button, I was disappointed that it was unclear where the button was, even after looking at the instruction manual, and that it required such a large amount of pressure to depress.
Vibration Sensor
Whenever the Aqara Vibration Sensor detects unexpected vibration, it will send an alert to your devices, much like the Water Leak Sensor. It can detect tilts, drops, jolts, and vibrations.
aqara review vibration sensor 2
The Vibration Sensor is extremely versatile. For example, you could adhere the sensor to a drawer or object to be alerted when it used, or even attach it to a window to alert to breakages as a security measure. Again, while the main purpose is alert notifications, you could easily integrate the Vibration Sensor into a ‌HomeKit‌ automation.
While the sensor seems to be sensitive enough to be useful, it does seem to take up to around ten seconds to reset, and I noticed that it is not quite as responsive as the other Aqara devices. Nevertheless, I was confident that the sensor could provide an alert notification when needed, but it simply lacked the seemingly instantaneous response of the other Aqara devices.
The Single Switch Module T1 is installed behind a wall switch and can be used to make ceiling fans, power outlets, light switches, and more part of your smart home setup.
aqara review t1 switch no neutral
The Single Switch Module was smaller than expected, but quite heavy for its size, and I am unsure how comfortable I am with this much weight tugging on the wires behind my switches.
Despite being installed behind a switch, the T1 works in a very similar way to the other Aqara accessories and pairs the same way, by holding down a small button on the device. The main difference is that you can specify what exactly is being activated by the T1 in the Home app.
My main takeaway from using the T1 is that the instructions included in the box could have been much better. It was not clear to me how the module should be installed, which is essential when it comes to rewiring a switch. As a result, I would not encourage anyone to undertake installation without significant confidence.
HomeKit Support
The Aqara app's ability to add accessories automatically to the Home app, combined with the company's embrace of ‌HomeKit‌ features such as Secure Video or two-way audio, makes for ‌HomeKit‌ support that is generally as good as it gets.
I did not receive any "no response" indicators from any of the accessories in my time using them, and they seemed to be consistently connected to my network.
When using the Home app to control the accessories, they were just as responsive as in Aqara's own app. The same cannot be said for some other smart home providers such as Philips Hue, where there is a clear advantage to using the company's own app. With the exception of the Vibration Sensor, which stuck out as distinctively less responsive and sensitive than the others, I was struck by just how responsive the devices were in general. Any changes in status detected by an accessory were updated in the Home app almost immediately.
This is key for devices such as a Motion Sensor, where you would want lights to come on immediately in response, for example. It also has the added effect of instilling more confidence in the devices themselves to do their job in the background.
The Bottom Line
The Aqara accessories set a high standard in terms of design, ease-of-use, reliability, and responsiveness that some other brands could learn a lot from. I like Aqara's compact, aesthetic designs, the pairing process was easy, and Apple ‌HomeKit‌ was well-integrated. Above all, Aqara's devices worked exactly as they should.
With competitive price points, Aqara's selection of ‌HomeKit‌ accessories make for a very compelling package within any smart home setup.
How to Buy
Aqara's full range of ‌HomeKit‌ accessories is available in the U.S. via Amazon.
The Single Switch Module T1 is unavailable in the United States as it is designed for the UK and EU market. For customers in these regions, Aqara's devices are available through third-party distributors.
Note: Aqara provided MacRumors with a Camera Hub G2H, Motion Sensor, Door and Window Sensor, Water Leak Sensor, Vibration Sensor, and Single Switch Module T1 for the purpose of this review. No other compensation was received.
Top Rated Comments
whyamihere Avatar
54 months ago
It's unfortunate each item doesn't connect to HomeKit directly. They all need to go through their hub (which is currently not available on Amazon) or the camera with a built-in hub (which not everyone wants/needs their camera).
mharve Avatar
54 months ago
They need a temperature sensor. If an area or thing gets too hot or cold something else can be turned on. Like if a room gets too hot a fan comes on.
They have one. It's on Amazon ('https://www.amazon.com/Aqara-WSDCGQ11LM-Temperature-Humidity-Sensor/dp/B07D37FKGY') for $19.99.
They also have a mini Switch ('https://www.amazon.com/Aqara-WXKG11LM-Switch-Wireless-Remote/dp/B07D19YXND') that functions as a Homekit remote. It works great for $18.
AngerDanger Avatar
54 months ago
Huh, that camera reminds me of something…
Attachment Image
kk200 Avatar
54 months ago
That there is a required hub makes it a no-go for me. I thought the price of the sensor was right until I noticed that fact. Additionally, there are plenty of no-hub motion sensors that also include temperature and humidity sensors for a couple of bucks more. Best of luck to you!
my aqara motion sensor works with a CR2450 battery more than 2.5 years. And one gateway can connect the whole house with 4 flors.
If you have 40sensors at home, you will understand why zigbee is super.
rictus007 Avatar
54 months ago
I have two cameras. Initially I was concerned about privacy, and how some devices “call home” frequently. No need to signup to use the cameras, their app is useful only for updates - everything else is done at HomeKit app. I had not noticed any unusual activity (firewall logs)
jparchem Avatar
54 months ago
I think I prefer having these devices on their own hubs. Without any hub, they have to be either on WiFi (I prefer not to have IoT devices cluttering up my WiFi) or bluetooth to some other device. Having the hub also gives some measure of redundancy so if something like Apple's Home App gets buggy you can try using the manufacturers own app to troubleshoot.
Popular Stories
iPhone 17 Air Pastel Feature
iPhone 17 Air Launching Later This Year With These 16 New Features
Thursday April 24, 2025 8:24 am PDT by
While the so-called "iPhone 17 Air" is not expected to launch until September, there are already plenty of rumors about the ultra-thin device. Overall, the iPhone 17 Air sounds like a mixed bag. While the device is expected to have an impressively thin and light design, rumors indicate it will have some compromises compared to iPhone 17 Pro models, including only a single rear camera, a...
AirPods Pro 3 Mock Feature
Global Close Your Rings Day Pin
Apple Stores Giving Away a Limited-Edition Pin For Free Today
Thursday April 24, 2025 10:15 am PDT by
Starting today, April 24, Apple Stores around the world are giving away a special pin for free to customers who request one, while supplies last. Photo Credit: Filip Chudzinski The enamel pin's design is inspired by the Global Close Your Rings Day award in the Activity app, which Apple Watch users can receive by closing all three Activity rings today. The limited-edition pin is the physical...
Apple Logo Spotlight Blue
White House Hits Back at Apple's Massive EU Fine
Thursday April 24, 2025 5:57 am PDT by
Apple's $570 million fine from the EU has triggered a sharp rebuke from the White House, which called the fine a form of economic extortion, Reuters reports. The fine was announced on Wednesday by the European Commission, following a formal investigation into Apple's compliance with the bloc's Digital Markets Act (DMA), a landmark piece of legislation aimed at curbing the market dominance of ...
ipad air magic keyboard feature
iPadOS 19 Rumored to Show Mac-Like Menu Bar When Connected to Magic Keyboard
Thursday April 24, 2025 12:09 pm PDT by
When an iPad running iPadOS 19 is connected to a Magic Keyboard, a macOS-like menu bar will appear on the screen, according to the leaker Majin Bu. This change would further blur the lines between the iPad and the Mac. Bloomberg's Mark Gurman previously claimed that iPadOS 19 will be "more like macOS," with unspecified improvements to productivity, multitasking, and app window management,...
