RAVPower recently introduced a new 45W USB-C Power Adapter that uses eGaNFET circuitry allowing for an ultrathin design more portable than traditional USB-C power adapters.
Made from white plastic, the power adapter measures in at 2.8 inches long, 2.1 inches wide, and 0.56 inches thick. Compared to the 29/30W USB-C chargers for the MacBook and the MacBook Air, it's longer, but thinner.
ravpower1
The thinner design allows the power adapter to fit easily in a pocket, bag, or backpack. It's not as oddly square-shaped as Apple's own chargers, which makes it more convenient to carry. RAVPower does not ship this power adapter with any cables, so you're going to need to supply your own USB-C to USB-C cable or USB-C to Lightning cable.
Since this is a 45W charger, it's ideal for the MacBook Air or the MacBook, but won't really work for the 61W 13-inch MacBook Pro or the 85W 15-inch MacBook Pro.
ravpowerback
It is, however, also useful paired with a USB-C to Lightning cable to charge an iPhone or with a USB-C to USB-C cable to charge one of Apple's new iPad Pros more quickly.
Design wise, this is a nice looking power adapter. The aforementioned white plastic is unblemished aside from a RAVPower logo at the top, and there's a single USB-C port at one side.
ravpowervs29wadapter
RAVPower's adapter next to 29W power adapter from Apple
At the back, there's a set of prongs for plugging it into an outlet, which fold down when the power adapter is not in use. This also allows it to be pocketed or tucked away in a small pouch in a backpack.
ravpowerprongs
At 45W, the RAVPower charger enables fast charging with the iPhone 8, 8 Plus, X, XS, XS Max, and XR when paired with one of Apple's Lightning to USB-C cables. Fast charging charges your iPhone to 50 percent in a half hour, and with the RAVPower charger and the required cable, my iPhone XS Max charged from 1 percent to 52 percent in a 30-minute time period.
When using the 45W RAVPower adapter, I was also able to charge the new USB-C 11-inch iPad Pro faster. With the standard 18W charger it ships with, the iPad Pro charged to 45 percent from 1 percent over the course of an hour.
ravpowerthickness
With the 45W RAVPower adapter, the iPad Pro charged from one percent to 66 percent during the same time period. As a caveat, though, faster charging is available with 29W/30W chargers too, as I was also able to reach a 66 percent charge in one hour using a standard 29W MacBook power adapter. The same goes for iPhone fast charging - 45W offers no benefit over 29W/30W.
On my MacBook, the standard 29W charger charged it to 62 percent over the course of an hour, which is the exact same result I got with the 45W charger, so there's also no benefit using 45W over 29W/30W with a MacBook.
ravpowercord
45W is overkill for charging a MacBook, MacBook Air, 11-inch iPad, or iPhone, but it's not enough power for a 13 or 15-inch MacBook Pro under a heavy load (technically you can charge either of these machines with the 45W adapter, but it's not going to be enough when using a lot of power), which makes RAVPower's adapter kind of an odd choice for Apple devices.
Bottom Line
I don't really have much else to say about the power adapter. RAVPower makes good products, and the new ultrathin USB-C power adapter is no exception.
It's portable, offers faster charging for the iPhone and iPad Pro, and works well with Apple's MacBook and MacBook Air. It has a foldable plug, and with its thin body, it's ideal for travel because it's not going to take up much space.
Unfortunately, RAVPower has priced its new USB-C power adapter rather high, charging $55 for it. That's more expensive than the $49 power USB-C 30W Power Adapter direct from Apple, and more expensive than many non-ultrathin ~30W USB-C power adapter solutions.
RAVpower's power adapter is nice, but it doesn't seem worth the premium over other 30 and 45W power adapters just to save a bit of space. There are many more affordable charging options on the market, and for Apple devices, 30W seems to be the sweet spot for fast charging the 11-inch iPad Pro, iPhone, and the MacBook and MacBook Air so why shell out extra money for RAVpower's solution?
RAVPower does often discount its products, though, so if you're in the market for a pocketable 45W USB-C charger, keep an eye out for a sale before picking this one up.
How to Buy
The 45W USB-C ultrathin charger from RAVPower can be purchased from Amazon for $54.99.
Note: RAVPower provided MacRumors with a 45W power adapter for the purpose of this review. No other compensation was received.
Top Rated Comments
dsraj Avatar
86 months ago
How do you review an “ultra thin” product and not include even one photo showing the thickness?
*eyeroll*
EDIT: Appreciate updating the post with a photo of the side. Thanks Juli!
jclo Avatar
86 months ago
*eyeroll*
Sorry, thought the comparison photo showed thickness well enough and it has a direct mention in the article. I'll add another photo.
konqerror Avatar
86 months ago
Now I ain't saying RavPower is some kind of fly-by-night operation with a charger that will wreck your laptop. But I am saying that a _smaller_ charger delivered at a _higher_ price than what Apple charges is a little suspicious.
Literally, the very first sentence of the article explains why. This is built with GaN transistors which are more efficient, cooler, and more expensive than traditional silicon transistors. There's likely supply constraints too.
gnomeisland Avatar
86 months ago
Wouldn’t one advantage of 45w over 30w be if you want to power a hub and the device? The MacBook and the IPad Pro 2018 only have one port and basically need a hub with USB power pass through. In that case the power is decided between the hub (and plugged-in devices) and the device.
jclo Avatar
86 months ago
Anyone know what “braided” looking cord is connected to the Apple brick in the 3rd pic? Non of my Apple ones look like that.
Yeah, it's the Stella plug: https://www.macrumors.com/review/ten-one-design-stella-plug/
cerberusss Avatar
86 months ago
I wonder why they didn't go lower power and smaller, or high enough power to support a MBP.
Because 45W actually is more than enough power to go through the day, for most people. Apple's chargers are charged such that you can relatively rapidly charge the laptop from empty to full. This RAVPower adapter is not going to do that. However, to get through the day, you likely don't need more than 30W.
For the last year, I get through the day with a 45W charger. During the day, I use Xcode plus Firefox, Apple Mail, Slack, Excel, TeamViewer and a couple of other apps. Works fine.
Popular Stories
iPhone 17 Pro Lower Logo Feature 1
iPhone 17 Pro Coming Soon With These 14 New Features
Monday June 30, 2025 1:08 pm PDT by
Apple's next-generation iPhone 17 Pro and iPhone 17 Pro Max are less than three months away, and there are plenty of rumors about the devices. Apple is expected to launch the iPhone 17, iPhone 17 Air, iPhone 17 Pro, and iPhone 17 Pro Max in September this year. Below, we recap key changes rumored for the iPhone 17 Pro models:Aluminum frame: iPhone 17 Pro models are rumored to have an...
A18 Pro Chip
New MacBook With A18 Pro Chip Spotted in Apple Code
Monday June 30, 2025 8:05 am PDT by
Apple is developing a MacBook with the A18 Pro chip, according to findings in backend code uncovered by MacRumors. Earlier today, Apple analyst Ming-Chi Kuo reported that Apple is planning to launch a low-cost MacBook powered by an iPhone chip. The machine is expected to feature a 13-inch display, the A18 Pro chip, and color options that include silver, blue, pink, and yellow. MacRumors...
iPhone Car Key WWDC 2025
Apple Announces 13 Automakers Planning to Offer iPhone Car Keys
Friday June 27, 2025 11:42 am PDT by
In 2020, Apple added a digital car key feature to its Wallet app, allowing users to lock, unlock, and start a compatible vehicle with an iPhone or Apple Watch. The feature is currently offered by select automakers, including Audi, BMW, Hyundai, Kia, Genesis, Mercedes-Benz, Volvo, and a handful of others, and it is set to expand further. During its WWDC 2025 keynote, Apple said that 13...
maxresdefault
Five Features Coming to AirPods Pro 3
Friday June 27, 2025 10:52 am PDT by
Apple hasn't updated the AirPods Pro since 2022, and the earbuds are due for a refresh. We're counting on a new model this year, and we've seen several hints of new AirPods tucked away in Apple's code. Rumors suggest that Apple has some exciting new features planned that will make it worthwhile to upgrade to the latest model. Subscribe to the MacRumors YouTube channel for more videos. Heal...
macbook air spacegray purple
Apple Planning to Launch Low-Cost MacBook Powered By iPhone Chip
Monday June 30, 2025 3:20 am PDT by
Apple is planning to launch a low-cost MacBook powered by an iPhone chip, according to Apple analyst Ming-Chi Kuo. In an article published on X, Kuo explained that the device will feature a 13-inch display and the A18 Pro chip, making it the first Mac powered by an iPhone chip. The A18 Pro chip debuted in the iPhone 16 Pro last year. To date, all Apple silicon Macs have contained M-series...
anker power bank recall
PSA: Anker Recalls Multiple Power Banks Due to Fire Risk
Friday June 27, 2025 4:16 pm PDT by
Popular accessory maker Anker this month launched two separate recalls for its power banks, some of which may be a fire risk. The first recall affects Anker PowerCore 10000 Power Banks sold between June 1, 2016 and December 31, 2022 in the United States. Anker says that these power banks have a "potential issue" with the battery inside, which can lead to overheating, melting of plastic...
Chase Sapphire Reserve Apple Perk Feature
Chase Sapphire Reserve Card Introduces New Perk for Apple Customers
Wednesday June 25, 2025 2:08 pm PDT by
Chase this week announced a series of new perks for its premium Sapphire Reserve credit card, and one of them is for a pair of Apple services. Specifically, the credit card now offers complimentary annual subscriptions to Apple TV+ and Apple Music, a value of up to $250 per year. If you are already paying for Apple TV+ and/or Apple Music directly through Apple, those subscriptions will...
replay all time playlist apple music
Apple Music Debuts All-New Personalized Playlist
Monday June 30, 2025 7:16 am PDT by
As part of its 10-year celebrations of Apple Music, Apple today released an all-new personalized playlist that collates your entire listening history. The playlist, called "Replay All Time," expands on Apple Music's existing Replay features. Previously, users could only see their top songs for each individual calendar year that they've been subscribed to Apple Music, but now, Replay All...
