Nomad today introduced its most powerful charger to date, the 130W USB-C Power Adapter that's equipped with three USB-C PD ports. The 130W adapter joins Nomad's existing 65W, 30W, and 20W adapters.
nomad 130w 1
Priced at $110, the 130W Power Adapter features the same design as Nomad's prior adapters, so if you have one of the smaller varieties, you can have a matching set. It's got a sleek black "carbide" enclosure, and it does use GaN (gallium nitride) technology to ensure a compact size.
I always find myself wishing Nomad made its accessories in white or other colors, but black is the Nomad aesthetic and it works. I can say without hesitation that this is the snazziest charging brick I've used, though I have to admit I don't often think too much about the build quality of the power adapter I'm using since it's out of sight and under the desk. If you have a charging setup on a desk or somewhere that looks matter, you won't be disappointed with the design of Nomad's Power Adapter.
Though the power adapter has three ports, it is smaller in size than the 140W charger from Apple that's designed for the 16-inch MacBook Pro models, and it is close in size to the Apple 96W power adapter. There are flip out prongs so when the charger is not in use, it folds down into a little cube that can be tucked away in a bag or a suitcase. I do want to point out that it has some heft - it's not a lightweight charger.
nomad 130w 2
Each port is capable of 100W charging, but that is the maximum. You won't be able to get the 140W charging you're able to achieve on the 16-inch ‌MacBook Pro‌ with the MagSafe power adapter from Apple, but 100W is plenty for keeping power levels up while the ‌MacBook Pro‌ is in use. I rarely use the ‌MagSafe‌ port on my ‌MacBook Pro‌ for charging, and it's always at full battery when I'm at my desk regardless of what I'm doing. 100W is also enough power to max out all of Apple's other notebooks, and plenty for iPhones, iPads, and other USB-C accessories.
When charging multiple devices, Nomad's power adapter is able to intelligently split power. With two devices, it sends 100W to the top port and 30W to the other port, so you can charge a MacBook at full speed while also having 30W available for an iPhone or an iPad. With all three ports in use, the top port charges at 70W, while the two bottom ports get 30W each.
If you use just the bottom two ports and not the top port, you can get 65W with each port for evenly split power, and it's nice to have so many different charging options with one charger depending on which ports you opt for. With a minimum of 30W going to each port regardless of what's being charged, all three ports can fast charge an ‌iPhone‌.
Bottom Line
Nomad's 130W Power Adapter is a convenient all-in-one power adapter thanks to its three ports and smart charging modes. It's useful for charging several devices at home, and equally helpful when traveling because you only need to pack a single power adapter.
At $110, the only downside is the price. That's a lot for a charger, but it is only $10 more than Apple's 140W charger, and it is not to far off of the price of similar chargers from companies like Anker and Satechi.
How to Buy
The Nomad 130W Power Adapter can be purchased from the Nomad website for $110.
Note: Nomad provided MacRumors with a 130W Power Adapter for the purpose of this review. No other compensation was received.
Tag: Nomad
Top Rated Comments
friedmud Avatar
22 months ago
Anker should learn something from this release. ?
Anker's largest GanPrime charger (the 747) has 3 USB-C _and_ a USB-A... and does 150 Watts... AND has "dynamic power" charging (it changes the amount of power output on each port based on how dead the battery is that's connected to that port - that way the more "dead" devices get topped up fastest/first).... AND it's the same price as this at $110.
The Anker is a much better deal IMO.
https://www.anker.com/products/a2340?ref=naviMenu&variant=41974288777366&discount=WS7DPNMW2H
friedmud Avatar
22 months ago
Why USB - A? That should be dead and gone by now?! ?
Compared to this charger... it's a bonus. You still get 3 USB-C... just ignore the A if you don't need it.
Personally, I carry a USB-A to USB-C cable with me so that I can charge my lower power USB-C devices without taking up a USB-C port. For instance, my Sony headphones and Switch controllers both charge using USB-C, but don't need much juice so using that USB-A port for them is very handy so that I can leave the USB-C ports open for things that need more juice.
Tagbert Avatar
22 months ago
I still have multiple devices and cables that use USB-A for power. It’s nice to have that as an option.
smoking monkey Avatar
22 months ago
This is the first power adapter I've seen like this (3 USB-C ports, plugs in directly to outlet). It's about time.
100w+ (130/140) been out for awhile now. You can get them cheaper and with a USB A port as well. The price seems a little exxy but I assume Nomad is a solid company compared to some of the dodgy mobs you see on Amazon.
Lcgiv Avatar
22 months ago
That’s a lot of watts!! That’ll be 110 bucks baby! You want cables with that?
bottsjw Avatar
22 months ago
But … wow, I miss the power indicator light. Anker’s latest is missing it also. It’s super handy when you can’t tell if that airport outlet, hotel outlet or random actually has power. It was a great visual on Anker’s early adapters.
Popular Stories
CarPlay Hero
Beyond iPhone 13 Better Triad
iOS 19 Roundup Feature
maxresdefault
iphone 16 pro models 1
AirPods Pro 3 Mock Feature
iOS 18
Apple Releases iOS 18.4.1 With Bug Fixes
Wednesday April 16, 2025 10:11 am PDT by
Apple today released iOS 18.4.1 and iPadOS 18.4.1, minor updates to the iOS 18 and iPadOS 18 operating systems that came out last September. iOS 18.4.1 and iPadOS 18.4.1 come two weeks after the launch of iOS 18.4 and iPadOS 18.4. The new software can be downloaded on eligible iPhones and iPads over-the-air by going to Settings > General > Software Update. There have been complaints about ...
tvOS 18 Thumb 1
Apple Releases tvOS 18.4.1
Wednesday April 16, 2025 10:04 am PDT by
Apple today released tvOS 18.4.1, a minor update to the tvOS 18 operating system that came out last September. tvOS 18.4.1 comes two weeks after Apple released tvOS 18.4, and it is available for the Apple TV 4K and Apple TV HD models. tvOS 18.4.1 can be downloaded using the Settings app on the ‌Apple TV‌. Open up Settings and go to System > Software Update to get the new software....
iPhone Security Feature 25
Five iPhone Security Features You Should Be Using
Wednesday April 16, 2025 4:15 pm PDT by
Apple has quite a few security features that it's added to iPhones, iPads, and Macs over the years. Now more than ever, it's important to make sure you're taking advantage of the built-in security tools that are available to keep yourself and your data safe, so we've rounded up a list of the most important options. If you don't already have these enabled, you might want to consider turning...
