Mophie earlier this year came out with several multi-device charging solutions after Apple failed to deliver the AirPower. The $80 Dual Wireless Charging Pad can charge two devices at one time, while the 3-in-1 Wireless Charging Pad ($140) is designed to charge an iPhone, Apple Watch, and AirPods all at once.
Design wise, these chargers are fairly simple, made from a black plastic covered with a suede-like fabric for grip and protection from scratches. Mophie also makes a version that's a glossy black plastic for those that don't like the ultrasuede look, and it's sold on the Apple online store.
mophiechargers
I'm not a huge fan of the suede because of the way that it can look discolored depending on the lay of the fabric, but it's a clean enough design and the suede keeps the devices properly in place while charging. I'm also not sure the black plastic is the best material given the price of these chargers, but again, there's nothing wrong with it. It's simple and clean, if a bit boring.
The Dual Wireless Charging Pad is a simple oblong charging pad that houses a single ‌iPhone‌ in landscape orientation or two iPhones positioned in portrait orientation. There's a line on each side, directing users where to place each ‌iPhone‌ for proper charging positioning.
dualwirelesscharger2
The bottom features a rubber ring for stability on a desk or a table, and there's a port for the charging cable and an additional spot to plug in another USB-A cable, such as a cable for charging an Apple Watch. Both of Mophie's chargers come with rather large power bricks that offer enough power to charge multiple devices.
dualwirelessmophie
The 3-in-1 Wireless Charger has a similar design with the same black suede base and a dedicated spot for each device. The right side, which is flat, is meant to charge an ‌iPhone‌, while there's an indentation where AirPods are meant to lie. This indentation was designed for the original AirPods, so the AirPods Pro's Wireless Charging Case is not a perfect fit, but it does charge when placed in the indentation.
mophie3in1applewatch
Above the indentation for the AirPods, there's a little Apple Watch charging puck that's actually a detachable piece that you need to snap into place, which isn't my favorite design. It's easy to get in the right area, and I suppose it's there so you can remove it and charge something else, but it seemed to give me charging issues.
mophie3in1charger2
I had a problem where I needed to take it out and reseat it a few times to get my Apple Watch to charge right. I also noticed that at times, I have to take the Apple Watch off of the charger multiple times to get it to start charging, which is not ideal. I didn't have issues with charging the ‌iPhone‌ on either charger, though, and the AirPods also charged fine.
The charging puck does allow the Apple Watch to be put in Nightstand mode, so you can glance over and see the time if it's at your bedside. Both charging pads feature LED lights at the front so you can make sure a given device is charging properly
Mophie's wireless chargers offer 7.5W charging speeds for Apple devices, including after the iOS 13 patch that seems to have limited some 7.5W wireless chargers to 5W instead of 7.5W.
mophiechargers2
With the 3-in-1 Wireless Charging Pad, the ‌iPhone‌ XS Max charged from zero to 23 percent after a half an hour, and 43 percent after an hour. The iPhone 11 Pro Max charged to 21 percent after a half hour and 38 percent after an hour, which is in line with other 7.5W wireless chargers.
I saw similar charging speeds from the Dual Wireless Charging Pad, which charged the ‌iPhone‌ XS Max to 21 percent after a half an hour and 42 percent after an hour. The ‌iPhone 11 Pro Max‌ charged to 22 percent after 30 minutes and 38 percent after an hour.
Bottom Line
Mophie's charging products are always good quality and are typically reliable, but Mophie is known for its premium pricing and these wireless chargers are no exception.
The Dual Wireless Charging Pad is $80 and the 3-in-1 Wireless Charging Pad is $140, which is a lot to ask, even if it is in line with other higher-end wireless products like those from Nomad.
mophie3in1devices
At these price points, it's difficult to flat out recommend Mophie's chargers, and with the 3-in-1 in particular, I have reservations because of the Apple Watch charging issues I experienced. There's nothing that makes these wireless chargers stand out from other similar options on the market, which is disappointing.
I like Mophie's products for the most part, but given the build quality, pricing, and charging issues, the Dual Wireless Charging Pad and the 3-in-1 Wireless Charging Pad feel like a bit of a miss. Mophie does sometimes have sales, so if you can get these at a cheaper price point, they're a whole lot more appealing. Otherwise, I'd recommend shopping around for a better deal.
How to Buy
The Dual Wireless Charging Pad and the 3-in-1 Wireless Charging Pad can be purchased from the Zagg website for $80 and $140, respectively.
Note: Mophie provided MacRumors with a 3-in-1 Wireless Charger and Dual Wireless Charger for the purpose of this review. No other compensation was received. MacRumors is an affiliate partner with some of these Mophie. When you click a link and make a purchase, we may receive a small payment, which helps us keep the site running.
Tags: Mophie, Zagg
Top Rated Comments
TheRealTVGuy Avatar
71 months ago
I purchased the plastic version of the dual wireless charging pad this past weekend at my local Apple Store. I’ve been disappointed thus far with just how precise you have to be with the phone to make it charge.
I consistently have to try placing it several times in order to get it to charge.
m0sher Avatar
71 months ago
I love Mophie I even own mophie, but there’s no reason in this day and age that we can’t get an 18 W charger. At the very least 15w.
dannyyankou Avatar
71 months ago
This indentation was designed for the original AirPods and not the AirPods Pro, so I'm not sure if it's going to work for Apple's newest AirPods.
FYI, I have it and it works with the AirPods pro.
bonokoot Avatar
71 months ago
Slice charger pro FTW
Traverse Avatar
71 months ago
I’ve had the same issues. I’ve woken up multiple days to discover my phone or AirPods did not continuously charge despite showing as charging when I put it down. I went back to my little rubber mophie puck which had had a 99.9% success rate
BoricuaHec01 Avatar
71 months ago
I'll stick to my Nomad 3 in 1 Base Station.
Popular Stories
Beyond iPhone 13 Better Triad
iOS 19 Roundup Feature
CarPlay Hero
iphone 16 pro models 1
Apple 2025 Thumb 1
iOS 18
Apple Releases iOS 18.4.1 With Bug Fixes
Wednesday April 16, 2025 10:11 am PDT by
Apple today released iOS 18.4.1 and iPadOS 18.4.1, minor updates to the iOS 18 and iPadOS 18 operating systems that came out last September. iOS 18.4.1 and iPadOS 18.4.1 come two weeks after the launch of iOS 18.4 and iPadOS 18.4. The new software can be downloaded on eligible iPhones and iPads over-the-air by going to Settings > General > Software Update. There have been complaints about ...
iPhone 6s MacRumors YouTube
Apple Says These Products Are Now Vintage
Tuesday April 15, 2025 9:53 am PDT by
Apple today updated its vintage products list to add the 2018 Mac mini and the iPhone 6s, devices that will get more limited service and repairs now that they are considered vintage. The iPhone 6s initially launched in 2015, but Apple kept it around as a low-cost device until 2018, which is why it is only now being added to the vintage list. The iPhone 6s had Apple's A9 chip, and it was...
macOS Sequoia Feature
Apple Releases macOS Sequoia 15.4.1 With Bug Fixes
Wednesday April 16, 2025 10:16 am PDT by
Apple today released macOS Sequoia 15.4.1, a minor update to the macOS Sequoia operating system that launched in September. macOS Sequoia 15.4.1 comes two weeks after the launch of macOS Sequoia 15.4. Mac users can download the ‌‌macOS Sequoia‌‌ update through the Software Update section of System Settings. It is available for free on all Macs able to run macOS 15. According to...
