The new Mac Studio with the M4 Max and M3 Ultra chip launches tomorrow. Ahead of time, the first reviews of the device have been shared by select publications and YouTube channels.
Mac Studio Desk
This is the first ‌Mac Studio‌ refresh since the desktop computer was updated with M2 Max and ‌M2‌ Ultra chip options in June 2023. The overall design of the machine has not changed. The front of the computer has two Thunderbolt 5 or USB-C ports depending on the configuration, and an SD card slot, while the rear side has four Thunderbolt 5 ports, an HDMI port, a 10-Gigabit Ethernet port, two USB-A ports, a headphone jack, a power cord connector, and a power button.
With the M4 Max and M3 Ultra chips, the ‌Mac Studio‌ catches up to other newer Macs by gaining hardware-accelerated ray tracing for the first time. It can also now be configured with up to 16TB of SSD storage, up from the previous model's 8TB maximum.
Highlights
M4 Max Chip
With Apple's latest chip technology, the M4 Max ‌Mac Studio‌ mode outpaces the M3 Ultra in single-core performance, despite being considerably cheaper. The Verge's Chris Welch:
It's important to note that there are objective benefits to choosing the M4 Max Mac Studio model. It outpaces the M3 Ultra in single-core performance, which is the most critical element in making most everyday apps feel "fast."
The M4 Max chip was already released last year in the 14-inch and 16-inch MacBook Pro. It can be configured with up to a 16-core CPU, up to a 40-core GPU, and up to 128GB of unified RAM. Geekbench 6 benchmark results indicate that the M4 Max is up to 75% faster than the ‌M2‌ Max chip available in the previous-generation ‌Mac Studio‌.
M3 Ultra Chip
The all-new M3 Ultra chip features up to a 32-core CPU, with 24 performance cores and eight efficiency cores, and up to an 80-core GPU. Apple says the M3 Ultra chip is up to 1.5x faster than the previous ‌Mac Studio‌'s ‌M2‌ Ultra chip, which has up to a 24-core CPU. Graphics performance is up to 2x faster than the previous ‌Mac Studio‌ with the ‌M2‌ Ultra chip, which was available with up to a 72-core GPU. The M3 Ultra chip supports up to 512GB of unified RAM, whereas the ‌M2‌ Ultra maxed out at 192GB of unified RAM. The Verge's Chris Welch:
The M3 Ultra chip is overkill for many. If you need this level of power, you already know exactly how you'll get the most from it. It's for visual effects artists and animators. It's for professionals doing ambitious audio and video production work. Are you regularly crunching big medical datasets? Maybe you can use all those cores and memory to their fullest potential. And as AI development continues to flourish, the kitted out configurations with 256GB or 512GB of memory could prove appealing to anyone interested in running sophisticated LLM models locally on their machine.
arsTechnica's Andrew Cunningham:
It's the magnitude of Apple's generation-over-generation updates that makes this Studio refresh feel odd, though. The lower-end Studio gets an M4 Max processor like you'd expect—the same chip Apple sells in its high-end MacBook Pros but fit into a desktop enclosure instead of a laptop. But the top-end Studio gets an M3 Ultra instead of an M4 Ultra. That's still a huge increase in CPU and GPU cores (and there are other Ultra-specific benefits, too), but it makes the expensive Studio feel like less of a step up over the regular one.
Thunderbolt 5 and Improved External Display Support
Following in the footsteps of ‌MacBook Pro‌ and Mac mini models with M4 Pro and M4 Max chips, the ‌Mac Studio‌ now supports Thunderbolt 5. There are four Thunderbolt 5 ports on ‌Mac Studio‌ configurations with the M4 Max chip, and six Thunderbolt 5 ports on configurations with the M3 Ultra chip. Thunderbolt 5 provides up to 120 Gb/s data transfer speeds. Tom's Guide's Alex Wawro:
While the USB-C ports on our Mac Studio M4 Max are capable of transmitting up to 10 GBp/second, the Thunderbolt 5 ports are theoretically capable of achieving up to 120GBp/second in certain conditions. And in standard use Thunderbolt 5 is specced to offer double the bandwidth capacity of Thunderbolt 4 (80 Gbps vs. 40 Gbps), which means it can move more data faster than its predecessors.
The practical payoff is that you can use a higher number of more capable displays via Thunderbolt 5 than Thunderbolt 4, for example, our Mac Studio M4 Max is rated to support up to five external displays (4 @6K/60Hz via Thunderbolt 5, 1 @4K/144Hz via HDMI) while the upgraded M3 Ultra model can supposedly support up to eight (at 6K/60Hz or 4K/144Hz) at once.
Alternatively, our M4 Max review unit can support a single 8K/60Hz display while the M3 Ultra version can support up to four 8K/60Hz displays. So if you really want to be future-proofed against a potential 8K future, the new Mac Studio has you covered.
If I were considering buying one of these Macs in 2025, I'd be more excited about the potential to build the ultimate workstation by investing in a great Thunderbolt 5 dock, along with a good display (honestly, I can live without Thunderbolt 5 speeds for my display needs) and a great Thunderbolt 5 external SSD for moving big files around fast.
And frankly, Thunderbolt 5 gear is still pretty sparse on the market despite the fact that the standard debuted in 2023. While you can buy 8K displays and 8K TVs right now, the fact is that 8K content only started arriving in small doses in 2023, and it's still very rare in Mac apps and streaming services.
So while it's great to get Thunderbolt 5 ports on the most powerful Mac desktop for the first time, it's not a great reason to upgrade unless you're really excited about investing in a lot of Thunderbolt 5 accessories.
Reviews
Articles
Videos
The new ‌Mac Studio‌ is available to pre-order now, and it will launch on Wednesday, March 12. In the U.S., pricing continues to start at $1,999 for configurations with an M4 Max chip, and at $3,999 for configurations with an M3 Ultra chip.
Related Roundup: Mac Studio
Buyer's Guide: Mac Studio (Buy Now)
Related Forum: Mac Studio
Top Rated Comments
Naiborg Avatar
4 weeks ago
YouTube tech influencers testing the capabilities of top-of-the-line, high-end computers with basic video editing is becoming increasingly ridiculous and cringeworthy.
Score: 19 Votes (Like | Disagree)
FSMBP Avatar
4 weeks ago
This is one of those things I want but have no legit reason to own.
Score: 16 Votes (Like | Disagree)
macmyworld Avatar
4 weeks ago
Justine reviewing a Mac Studio…really?
Score: 12 Votes (Like | Disagree)
theluggage Avatar
4 weeks ago
These M3 Ultras with 512GB RAM for less than 10K are gonna sell like hotcakes on a deserted island with chocolate drinks for free.
So, that would be a dessert island, then?
I'll get my coat. :)
frankly Avatar
4 weeks ago
Still surprising to me they didn't engineer an M4 Ultra chip. Seems like a really odd thing. Like you have to figure there will be an M4 BTO config soon, right?
Apple has said that the M4 does not have the interconnect necessary to make an M4 Ultra.
You don't think she is a power user, with the amount of video she edits and the frequency with which she posts? Makes perfect sense to me.
512Gb of RAM.
1/4 that of the old Mac Pro
First, it is 1/3 of the RAM, not 1/4. Second, it is 8 times the max graphics memory you could get on that Mac Pro.
Neil J. Squillante Avatar
4 weeks ago
This review from Creative Strategies ('https://creativestrategies.com/mac-studio-m3-ultra-ai-workstation-review/') covers using the M3 Ultra Mac Studio for running LLMs, which seems to be its primary use case.
Popular Stories
Alleged iOS 19 Icons Front Page Tech
iOS 19 Leak Reveals Alleged New Design With Rounder App Icons, Floating Tab Bar, and More
Monday April 7, 2025 3:13 pm PDT by
YouTube channel Front Page Tech is back today with another video that provides a closer look at iOS 19's alleged design changes. The video contains re-created renders of iOS 19, which are allegedly based on real footage of the software update, provided by sources within Apple. Overall, iOS 19 is expected to have a more glass-like, visionOS-inspired design, with added translucency for user...
iPhone 17 Pro's New Rear Camera Bar 'Same Color As Rest of Device'
Monday April 7, 2025 2:09 am PDT by
Apple's upcoming iPhone 17 Pro models will feature a redesigned rear camera panel that spans the width of the device, but it will be the same color as the iPhone itself, rather than being part of a two-tone design. That's according to Bloomberg's Mark Gurman. Writing in his latest Power On newsletter, the reporter says the iPhone 17 Pro won't have a two-toned back, as some renders have...
iphone x front back
Apple Planning 'Bold' New 20th Anniversary Design for 2027 iPhone Pro
Monday April 7, 2025 2:46 am PDT by
Apple is preparing a "major shake-up" for the iPhone's 20th anniversary in 2027, according to Bloomberg's Mark Gurman. iPhone X released in 2017 for 10th anniversary Writing in his latest Power On newsletter, Gurman says that Apple plans to launch a foldable iPhone alongside a "bold" new iPhone Pro model that makes more extensive use of glass. Could this mean Apple plans to realize former...
iOS 18 Siri Personal Context
Report Reveals Internal Chaos Behind Apple's Siri Failure
Thursday April 10, 2025 7:15 am PDT by
A new report from The Information today reveals much of the internal turmoil behind Apple Intelligence's revamped version of Siri. Apple apparently weighed up multiple options for the backend of Apple Intelligence. One initial idea was to build both small and large language models, dubbed "Mini Mouse" and "Mighty Mouse," to run locally on iPhones and in the cloud, respectively. Siri's...
iPhone Assembly
Trump Believes Apple Could Manufacture iPhones in the U.S.
Tuesday April 8, 2025 12:08 pm PDT by
U.S. President Donald Trump "absolutely" believes that Apple could manufacture its iPhones and other devices in the United States, Press Secretary Karoline Leavitt said today during a media briefing. Leavitt was asked whether Trump thought that iPhone manufacturing is the kind of technology that could move to the U.S. "Absolutely, he believes we have the labor, we have the workforce, we have ...
5 Biggest Changes Rumored for iPhone 17 Pro
Tuesday April 8, 2025 2:38 am PDT by
Later this year, Apple will introduce the iPhone 17 series, which includes the iPhone 17 Pro and the iPhone 17 Pro Max, two new high-end flagship devices that will be sold alongside the regular iPhone 17 and an all-new ultra-thin iPhone 17 Air. If you have been holding out for the iPhone 17 Pro or its bigger sibling, here are five of the biggest changes, informed by the latest reports and...
iphone 16 pro colors 1
Is Now the Time to Upgrade Apple Devices Before Tariffs Lead to Price Increases?
Friday April 4, 2025 3:41 pm PDT by
If you have an older Apple device that you've been considering upgrading, you're probably wondering how the newly announced tariffs might impact prices going forward, and whether it's worth buying now before there's a price hike. Given analyst and economist responses to the tariffs, market panic, and Trump's stance on the current financial chaos, the answer is that making a purchase...
iPhone 17 Pro Models Rumored to Offer Dual Video Recording Feature in Camera App
Tuesday April 8, 2025 7:23 am PDT by
YouTube channel Front Page Tech on Monday shared renders of iOS 19's alleged new design. The end of the video also revealed a new feature that is supposedly planned for the iPhone 17 Pro models later this year: dual video recording. According to Front Page Tech host Jon Prosser, the iPhone 17 Pro and iPhone 17 Pro Max will allow users to record video with the front and rear cameras...
iOS 18
iOS 18.4.1 Update Coming Soon for iPhones
Wednesday April 9, 2025 8:56 am PDT by
Apple employees are testing iOS 18.4.1 for iPhones, according to the MacRumors visitor logs, which have been a reliable indicator of upcoming iOS versions. The software update will likely be released in a week or two, if not sooner. As the version number implies, iOS 18.4.1 will obviously be a minor update that addresses software bugs and/or security vulnerabilities. There are no...
