Reviews are now out for the iPhone 12 Pro Max, providing us with a closer look at the super-sized device before it begins arriving to customers on Friday. We've rounded up a handful of reviews from media outlets below. For video reviews, see here.
iphone 12 pro max verge
Image: The Verge
With a 6.7-inch display, the iPhone 12 Pro Max is the largest iPhone ever, eclipsing the 6.5-inch iPhone 11 Pro Max. Given that the iPhone 12 Pro has already launched, this review roundup focuses on what sets the iPhone 12 Pro Max apart from its smaller sibling, including its larger display, more advanced camera improvements, and longer battery life.
Large Display
With its super-sized 6.7-inch display, the iPhone 12 Pro Max won't be for everyone, as The Verge's Nilay Patel explains:
The combination of the size and flat sides basically demands a case to make it easier to hold, which makes the whole thing even bigger. It's still workable, but it is right on the edge of being too big. I think the size is a reflection of increased choice: this year Apple has more phone sizes available than ever before, including the diminutive iPhone 12 mini, so it had the ability to push the Max even farther.
But: it's still big. I strongly recommend finding a way to safely see the 12 Pro Max's size in person before making a call on ordering one.
The Wall Street Journal's Joanna Stern wished that Apple would take more advantage of the device's large display:
It is crazy to me, however, that Apple hasn't enabled us to do more on a phone that is practically iPad-size. Why can't I view my inbox on the top half of the screen and my calendar on the bottom, like Samsung allows with its Multi-Window mode? Why does the tiny iPhone Mini allow the same number of rows of home-page app icons and widgets as the iPhone Giant? Why can't I use an Apple Pencil to take notes on the notebook-size device? Apple declined to comment on future software updates.
Long Battery Life
The Wall Street Journal's Joanna Stern found the iPhone 12 Pro Max to have impressive all-day battery life. In a YouTube video streaming test, she found the device lasted 17.5 hours, compared to 14.5 hours for the iPhone 12 Pro and iPhone 12, and 10.5 hours for the iPhone 12 mini. Of course, heavy 5G usage will result in lower battery life than this.
I tried—really tried—to get the Pro Max's battery to die by bedtime. I've been unsuccessful. It’s simple: Bigger phone = bigger battery = longer battery life. See the iPhone Mini review for the inverse proof.
While the iPhone 12 and iPhone 12 Pro also last until bedtime, the Pro Max wasn’t even down to 15% territory by 11:30 p.m. most days. My video-streaming YouTube test showed the same: The Pro Max lasted a crazy 17½ hours; the iPhone 12 and 12 Pro went 14½ hours, and the poor little Mini lasted 10½. Expect shorter times if you're tapping the 5G network a lot.
Engadget's Chris Velazco also achieved more than one day of battery life:
Overall, I've been able to use the Pro Max for full workdays and still have quite a bit left in the tank the following morning. Full disclosure: Rather than setting this phone up as new, I restored it from a backup the way many iPhone users do. Apple has said previously that background processes related to device restoration can continue for up to a few days after the fact, so it's possible that battery life could improve a bit in time. Anyway, I wouldn't sweat it: Even with a restore, the Pro Max will still get you through a long day with a little extra left over for the next one.
Camera Upgrades
Apple's camera improvements this year go a few steps further on the iPhone 12 Pro Max compared to the iPhone 12 Pro. Unique to the iPhone 12 Pro Max is a larger ƒ/2.2 aperture for the telephoto lens, a 47 percent larger sensor for the wide-angle lens, and what Apple refers to as sensor-shift optical image stabilization.
The Verge's Nilay Patel believes the iPhone 12 Pro Max has "the best smartphone camera you can get," noting that photos shot on the device "are generally less noisy" than those shot on the iPhone 12 Pro. However, Patel said that these improvements are mostly only noticeable in lower-light environments, as he found both devices produce virtually indistinguishable photos in brighter, sunlit conditions.
Under slightly darker conditions, most of the phones automatically shifted to their respective night modes, where they take multiple long exposures and merge them together. But the iPhone 12 Pro Max's bigger sensor, with its higher maximum ISO, means it doesn't automatically go into Night mode as often. And when the iPhone 12 Pro Max does go into Night mode, it does so with shorter exposures than the 12 Pro — in situations where the 12 Pro would take a three-second exposure, the 12 Pro Max only needed a one-second shot, resulting in a sharper photo.
Patel shared a side-by-side comparison of a photo shot on the iPhone 12 Pro Max (left) and iPhone 12 Pro (right) in lower-light environment, noting that the 12 Pro took a three-second Night mode shot, while the Pro Max only needed a one-second exposure:
verge iphone 12 pro max vs 12 pro
TechCrunch's Matthew Panzarino had a similar assessment, finding the iPhone 12 Pro Max to outperform the iPhone 12 Pro in lower-light conditions:
Wide angle shots from the iPhone 12 Pro Max display slightly better sharpness, lower noise and better color rendition than the iPhone 12 Pro and much more improvement from the iPhone 11 Pro. In bright conditions you will be hard pressed to tell the difference between the two iPhone 12 models but if you're on the lookout the signs are there. Better stabilization when handheld in open shade, better noise levels in dimmer areas and slightly improved detail sharpness.
More Reviews
We've also rounded up unboxing videos for the iPhone 12 Pro Max, iPhone 12 mini, MagSafe Duo Charger, and Leather Sleeve.
Related Forum: iPhone
Top Rated Comments
jcshas Avatar
58 months ago
There’s more controversy in this years iPhone lineup than there is in last weeks election results. :)
Score: 23 Votes (Like | Disagree)
DarkCole Avatar
58 months ago
These reviews have only made me more excited for my Pro Max delivery on Friday.
Score: 22 Votes (Like | Disagree)
Zwhaler Avatar
58 months ago
Meanwhile MKBHD: 'You can't tell the difference'
Score: 21 Votes (Like | Disagree)
Lord Hamsa Avatar
58 months ago
I'm 50 years old with deteriorating near vision and I have pretty large hands being 6' 2" tall. I'll take the Pro Max's size in a heartbeat.
Score: 20 Votes (Like | Disagree)
oneteam Avatar
58 months ago
I cannot wait to have my Pro Max this Friday...Very excited!!!
Score: 17 Votes (Like | Disagree)
Kylo83 Avatar
58 months ago
the max needs split screen like iPads now
Score: 15 Votes (Like | Disagree)
Popular Stories
iPhone 17 Air Pastel Feature
iPhone 17 Air Launching Later This Year With These 16 New Features
Thursday April 24, 2025 8:24 am PDT by
While the so-called "iPhone 17 Air" is not expected to launch until September, there are already plenty of rumors about the ultra-thin device. Overall, the iPhone 17 Air sounds like a mixed bag. While the device is expected to have an impressively thin and light design, rumors indicate it will have some compromises compared to iPhone 17 Pro models, including only a single rear camera, a...
apple watch ultra yellow
What's Next for the Apple Watch Ultra 3 and Apple Watch SE 3
Friday April 25, 2025 2:44 pm PDT by
This week marks the 10th anniversary of the Apple Watch, which launched on April 24, 2015. Yesterday, we recapped features rumored for the Apple Watch Series 11, but since 2015, the Apple Watch has also branched out into the Apple Watch Ultra and the Apple Watch SE, so we thought we'd take a look at what's next for those product lines, too. 2025 Apple Watch Ultra 3 Apple didn't update the...
AirPods Pro 3 Mock Feature
ipad air magic keyboard feature
iPadOS 19 Rumored to Show Mac-Like Menu Bar When Connected to Magic Keyboard
Thursday April 24, 2025 12:09 pm PDT by
When an iPad running iPadOS 19 is connected to a Magic Keyboard, a macOS-like menu bar will appear on the screen, according to the leaker Majin Bu. This change would further blur the lines between the iPad and the Mac. Bloomberg's Mark Gurman previously claimed that iPadOS 19 will be "more like macOS," with unspecified improvements to productivity, multitasking, and app window management,...
top stories 2025 04 26
Top Stories: iPhone 17 Air Rumors, Apple Watch Turns 10, and More
Saturday April 26, 2025 6:00 am PDT by
We've known for quite some time about Apple's plans for a thinner "iPhone 17 Air" coming later this year, but wow, the latest dummy models give us our best look yet at just how thin this phone is going to be. Other Apple news and rumors this week included another iOS 18.5 beta, the 10th anniversary of the Apple Watch launch, and more management reshuffling in Apple's Siri division, so read...
Global Close Your Rings Day Pin
Apple Stores Giving Away a Limited-Edition Pin For Free Today
Thursday April 24, 2025 10:15 am PDT by
Starting today, April 24, Apple Stores around the world are giving away a special pin for free to customers who request one, while supplies last. Photo Credit: Filip Chudzinski The enamel pin's design is inspired by the Global Close Your Rings Day award in the Activity app, which Apple Watch users can receive by closing all three Activity rings today. The limited-edition pin is the physical...
