Griffin Guide Magnetic Cable Management Set Review - MacRumors
Skip to Content
Griffin Review: The Guide Cable Management Set Will Keep Your Desk Organized
by
Griffin's Guide Magnetic Cable Management Set was first announced at CES in January of 2015, but it didn't become available for purchase until September. We went hands-on with the Guide to see if it was worth the wait as a cable management solution.
The Guide Cable Management Set is modular and consists of three weighted bases and three magnetic aluminum cable anchors that attach to the bases. Each base is made from a polished stainless steel with a shiny finish while the anchors, available in three sizes from small to large, are made from an anodized copper-colored aluminum.
griffin guide
Together, the Guide system looks great on a desk, but it is only available in the polished steel and copper colorway, which doesn't match any iOS devices and while neutral, may not match all office and room decors. I liked the design of the Guide, but I did wish it was available in a wider selection of colors.
Each of the three bases is the same size, measuring in at 2.28 x 1.98 inches, but the magnetic cable anchors come in a range of sizes to fit different cords. The smallest of the three anchors is sized to fit a single iPhone cable, while the middle one can hold several iPhone-sized cables or a couple of larger cables, and the biggest anchor can hold thicker cables like those for cameras and other electronics. The weight of the Guide bases will keep them in place, but there's also a non-skid material on the bottom to provide even more traction.
griffin guide2
Because the anchors attach to each base using magnets, they can be arranged in multiple ways. One anchor can be used per base or multiple anchors can fit on a single base to meet various cable management needs. For my work space, I used the smaller one to hold an iPhone cable that has a pesky habit of slipping off the edge of the desk, while I used the other two to hold my MacBook cable and cables for other devices in place.
griffinguideonecable
Due to their weight, the Guide bases can't realistically be mounted on walls or on the sides of desks and tables (and the Guide doesn't come with the necessary hardware) so these are going to be limited to on-the-desk organization. For that use case, the Guide is primarily going to keep your cables where you want them to be so they're not sliding all over the desk or slipping off. The Guide isn't going to hide or conceal cables and cords, but it will keep them looking more organized and streamlined.
griffinguidemultiplecables
The large base size means the Guide takes up more room on a desk than simpler cable routing options, but sacrificing the extra space felt worth it to me both for the versatility of being able to rearrange the pieces at will and for the premium aesthetic. If you have multiple cables in different areas, such as on a desk and on a nightstand, the Guide can also be split up across multiple rooms. After some experimentation, I found the Guide to be more useful for me when split up, because a single larger cable anchor can hold multiple cables in place, letting me address several problem areas.
griffinguidecables
Given the usefulness of the Guide's interchangeable pieces, I'm surprised there aren't more magnetic cable management systems on the market. Before the Guide, I hadn't considered magnets as cable organizing solution, but it seems like an ideal way to wrangle cables.
Bottom Line
The magnetic Guide system is a clever way to organize cables on a desk, and because it can be used in so many ways, it's suitable for a range of cable configurations and setups. Since it's magnetic, it's easy to arrange and rearrange cables and the Guide system as necessary, and its industrial look blends in with a lot of decors.
griffinguideevenmorecables
If you've got pesky cables that are continually slipping off of your desk or getting tangled and knocked out of place, the Guide is going to keep them where they belong with no problem.
The only real negative with the Guide is the price. At $40, this is a somewhat expensive solution to manage a handful of cables, and I do wish it was either more reasonably priced or had more pieces. If you don't mind shelling out $40 in the name of desktop organization, the Guide is worth picking up.
How to Buy
Griffin's Guide cable organizers can be purchased from the Griffin website for $39.99 or from Amazon.com for the same price.
Top Rated Comments
Sharewaredemon Avatar
143 months ago
This is how I do mostly. I also like to set up/tear down to have a completely empty desk.
Score: 11 Votes (Like | Disagree)
143 months ago
Ugh, I prefer my cables under my desk and out of sight! This is hideous!
OldSchoolMacGuy Avatar
143 months ago
Running cabling through big magnets and having big magnets next to sensitive electronics? Sounds like a horrid idea.
143 months ago
So let me get this straight -
We are being asked to shell out $40 so we can put a hunk of metal on our desk and intentionally then run data cables through a magnetic field that is created by these other (ugly) hunks of metal?
I bought a "Cable Management System" from Staples for $9.99. It had numerous plastic holders that I could hide on the edge of my desk where it didn't get in my way and didn't look ugly. And it has lots of extra parts that I haven't yet used. And I probably still paid too much.
mgipe Avatar
143 months ago
Two words: Duct Tape
143 months ago
Early April fool?
Popular Stories
apple pro tell logo
Apple Launching Two More New Products This Friday
Monday November 9, 2026 4:22 am PST by
The Apple launches keep coming! The company is set to release two new products on Friday, November 13: the all-new Apple HomeView and the fourth-generation Apple TV 4K, both of which have been available to pre-order since mid-October. Apple HomeView: Apple's new smart home display, powered by Apple Intelligence with Siri AI, for entertainment and managing the home. Available in tabletop and...
imac video apple feature
November 20 to Mark the End of an Era at Apple
Wednesday November 11, 2026 7:51 am PST by
Apple has announced that the long-running Apple Support Community discussion forums for user-to-user tech support will be permanently closing on Friday, November 20. The forums have existed in some form for nearly 30 years, so it is the end of an era. Effectively immediately, the Apple Support Community forums are in a read-only state, with new posts no longer being accepted. The final...
iOS 28 AI
Apple Taking New Approach to Developing iOS 28 and macOS 28
Sunday November 8, 2026 7:42 am PST by
Apple has made a change to its development process for iOS 28, macOS 28, and corresponding software updates, according to Bloomberg's Mark Gurman. In his Power On newsletter today, he said Apple separates development of each year's new operating systems into three major stages. Typically, he said each stage consists of four weeks of coding followed by a four-week "convergence" period where...
Latest Stories
Apple on Fatal Vehicle Crash Near Apple Park: 'Our Hearts Are Broken'
4 hours ago
Apple Invites App Updated With Two New Features
5 hours ago
Google Says Gemini App Rolling Out on Apple CarPlay Starting Today
6 hours ago
Is It Worth Buying a Ceramic Apple Watch?
8 hours ago
Samsung Early Black Friday Event Brings Major Sales to Frame TVs and More
10 hours ago
iPhone 18 Pro Max Wins Battery Test Involving 32 Smartphones
10 hours ago
AirTag 2 4-Pack Hits Record Low $69.99 Price Ahead of Black Friday
12 hours ago
Rumored Apple Smart Glasses Mentioned in Supplier's Earnings Briefing
12 hours ago
Make Apple Watch Listen for Sounds Like the Doorbell
15 hours ago
Apple Chip Supplier TSMC Approves $1 Billion AI Investment
16 hours ago
'Apple Support Community' Permanently Closing on November 20
22 hours ago
Apple's Holiday Gift Guide Highlights iPhone Duo and More
1 day ago
Three Workers Die at Tata iPhone Parts Plant in India
1 day ago
iCloud Mail, Calendar, Contacts and More Experiencing Outage [Updated]
1 day ago
Apple's Claris Testing 'Harbor' App for Local AI on Macs
1 day ago
iFixit's PROLED MacBook Pro Teardown Reveals Logo LEDs
1 day ago
10 Free iPhone Duo Apps Worth Downloading
1 day ago
Apple Releases New AirPods Firmware
1 day ago
Amazon Begins Early Black Friday Sale, Featuring Sitewide Discounts on Tech and Decor
1 day ago
Apple Announces Swift Student Challenge Ahead of WWDC 2027
1 day ago
Next iPad Air Likely to Have These 10 New Features
1 day ago
iPad Mini 2021 vs. 2026 Buyer's Guide: Is It Worth Upgrading?
1 day ago
New Apple TV Sign Language Feature Announced
1 day ago
Disable Touch on MacBook Pro PROLED XDR and When Using Sidecar
1 day ago
Anker's Early Black Friday Sale Surprises With Mystery Boxes and Big Discounts
1 day ago
Apple Arcade Adding These Four Games in December
1 day ago
OLED iPad Air Rumored to Launch in Two Sizes in Early 2027
2 days ago
The Original iPod Went on Sale 25 Years Ago Today
2 days ago
Apple Maps Could Factor Parking Into Your Arrival Time
2 days ago
Waze Now Alerts Drivers to Nearby Cyclists Using Garmin LiveTrack
2 days ago
