Elevation Lab, known for its popular line of wired dock options for the iPhone, recently came out with its first wireless charging dock, the NightPad.
The NightPad, which is a 7.5W charger, looks like a lot of other wireless chargers on the market, but there are some premium features to be aware of. It's covered in a soft silicone material that holds the iPhone in place while it's charging, and there's also a raised ring that makes sure the iPhone stays secure.
nightpad
While the design of the NightPad is simple, that silicone material has such a matte finish that it makes the charging pad look super black, so it does stand out from your average charging pad. There is subtle Elevation Lab branding on the top of the charger, but it can be hard to see just because it's so dark.
nightpadlogo
Size wise, the NightPad is palm-sized and a little larger than a coaster. As with most wireless chargers this size, you do need to make sure to get the iPhone lined up in the center because if it's off to the side a bit (which can happen -- especially in the dark) it won't charge.
nightpadunderneath
There is no LED on the NightPad at all, which is a deviation from most chargers. This was done so that it can be used in a dark room, and it's a decision that I understand. It's easy enough to tell when the iPhone is charging because there's a buzz when you first put it on the charger.
nightpadwithiphone
A 6-foot braided micro-USB cable is included with the NightPad, so this is a great choice if you need a long cable. I don't, so it was a bit of a nuisance, but Elevation Lab does include a velcro cable wrangler to wind up extra cord.
nightpadcomponents
You can purchase the NightPad with or without a power supply, and the version with 15W QC 3.0 power supply is $10 more expensive. 15W+ adapters are required for Apple's faster 7.5W charging, so people without a QC 3.0 power adapter will want to purchase the version that includes it.
If you already have a compatible power adapter, you can use that and get a discount on the NightPad.
nightpadcharger
In my testing, the NightPad charged at 7.5W as advertised. I drained it to 1 percent battery and then put it on the charger for an hour. With the first test, it charged up to 37 percent, and with the second test, it charged to 39 percent.
That's in line with other 7.5W charging speeds I've seen during the summer, where the indoor temperature is about 74 degrees. Temperature can impact wireless charging speeds quite a lot, so expect to see a lot of variance depending on ambient temperature and other factors.
Elevation Lab says that the NightPad can charge the iPhone 50 percent faster than standard Qi wireless chargers, but that must be in optimal conditions because the NightPad charges the iPhone at the same rates as other 7.5W chargers and the difference between a 7.5W charger and a 5W charger in our experience is not typically 50 percent.
nightpadwithiphone2
While designed for iPhone, the NightPad will work with other Qi-based devices and it supports Samsung's 10W fast charging.
Wireless charging is no match for wired charging so it's not always ideal when you need a lot of power in a short amount of time, but it's ideal for charging over the course of the day or at night.
I tested the NightPad with a standard Apple silicone case, but Elevation Lab says that it will officially work with cases up to 3mm thick and unofficially, it supports cases up to 6mm thick.
Bottom Line
All of the 7.5W iPhone wireless chargers charge at about the same speed. so choosing one comes down to the features that appeal to you.
The NightPad is a good choice if you're going to use your wireless charger at night, because there's no LED to add extra light pollution to the room.
It offers an appealing pure black color and a silicone base that holds the iPhone in place, plus it has an extra long braided cord. The $40 version is worth it to make sure you get the faster 7.5W charging speeds, and it is competitively priced with other premium chargers on the market.
How to Buy
You can purchase the NightPad from the Elevation Lab website for $39.95 standalone and for $49.95 with a 15W QC 3.0 power supply included.
Top Rated Comments
ActionableMango Avatar
96 months ago
I would think the "perfect bedtime charger" would be a slow charger, not a quick charger. If it's bedtime you have hours to charge. No need to ram the charge in there, generate heat, and ultimately shorten battery life.
Score: 11 Votes (Like | Disagree)
travisjaymoore Avatar
96 months ago
Love that there's no LED. Great design choice!
Apple_Robert Avatar
96 months ago
I think it is better to stick with the Apple store Mophie wireless charger for about the same price.
Analog Kid Avatar
96 months ago
No LED is a great feature.
https://xkcd.com/1973/
rjtyork Avatar
96 months ago
I agree here. I’d get one of these fast chargers for a place like next to my couch so it charges fast when I’m only going to be in one place for an hour or 2 and I’ll be picking it up and checking it. For my bedside? I got a $6 charger on amazon and I figure I’ll wake up with 100% no matter how fast or slow my charger is.
robinp Avatar
96 months ago
Can’t believe it’s taken this long for someone to make a Qi charger without an LED. Honestly, they are completely unnecessary; your phone tells you when it’s charging. We don’t need LEDs on normal chargers and there’s been no way I’d have one with an LED next to my bed.
Popular Stories
iOS 26
15 New Things Your iPhone Can Do in iOS 26.2
Friday December 5, 2025 9:40 am PST by
Apple is about to release iOS 26.2, the second major point update for iPhones since iOS 26 was rolled out in September, and there are at least 15 notable changes and improvements worth checking out. We've rounded them up below. Apple is expected to roll out iOS 26.2 to compatible devices sometime between December 8 and December 16. When the update drops, you can check Apple's servers for the ...
iPhone 14 Pro Dynamic Island
iPhone 18 Pro Leak Adds New Evidence for Under-Display Face ID
Monday December 8, 2025 4:54 am PST by
Apple is actively testing under-screen Face ID for next year's iPhone 18 Pro models using a special "spliced micro-transparent glass" window built into the display, claims a Chinese leaker. According to "Smart Pikachu," a Weibo account that has previously shared accurate supply-chain details on Chinese Android hardware, Apple is testing the special glass as a way to let the TrueDepth...
iOS 26
Apple Seeds Second iOS 26.2 Release Candidate to Developers and Public Beta Testers
Monday December 8, 2025 10:18 am PST by
Apple today seeded the second release candidate version of iOS 26.2 to developers and public beta testers, with the software coming one week after Apple seeded the first RC. The release candidate represents the final version iOS 26.2 that will be provided to the public if no further bugs are found. Registered developers and public beta testers can download the betas from the Settings app on...
Foldable iPhone 2023 Feature 1
Apple to Make More Foldable iPhones Than Expected
Tuesday December 9, 2025 9:59 am PST by
Apple has ordered 22 million OLED panels from Samsung Display for the first foldable iPhone, signaling a significantly larger production target than the display industry had previously anticipated, ET News reports. In the now-seemingly deleted report, ET News claimed that Samsung plans to mass-produce 11 million inward-folding OLED displays for Apple next year, as well as 11 million...
iPhone 17 Pro Cosmic Orange
10 Reasons to Wait for Next Year's iPhone 18 Pro
Monday December 1, 2025 2:40 am PST by
Apple's iPhone development roadmap runs several years into the future and the company is continually working with suppliers on several successive iPhone models at the same time, which is why we often get rumored features months ahead of launch. The iPhone 18 series is no different, and we already have a good idea of what to expect for the iPhone 18 Pro and iPhone 18 Pro Max. One thing worth...
Johny Srouji
Apple's Chipmaking Chief Johny Srouji Responds to Report About Him Potentially Leaving
Monday December 8, 2025 9:23 am PST by
Apple's chipmaking chief Johny Srouji has reportedly indicated that he plans to continue working for the company for the foreseeable future. "I love my team, and I love my job at Apple, and I don't plan on leaving anytime soon," said Srouji, in a memo obtained by Bloomberg's Mark Gurman. Here is Srouji's full memo, as shared by Bloomberg:I know you've been reading all kind of rumors and...
Johny Srouji
Apple Chip Chief Johny Srouji Could Be Next to Go as Exodus Continues
Sunday December 7, 2025 10:41 am PST by
Apple's senior vice president of hardware technologies Johny Srouji could be the next leading executive to leave the company amid an alarming exodus of leading employees, Bloomberg's Mark Gurman reports. Srouji apparently recently told CEO Tim Cook that he is "seriously considering leaving" in the near future. He intends to join another company if he departs. Srouji leads Apple's chip design ...
google pixel 10
Switching Between iPhone and Android Will Get Easier With New Apple and Google Collaboration
Monday December 8, 2025 11:10 am PST by
Apple and Google are teaming up to make it easier for users to switch between iPhone and Android smartphones, according to 9to5Google. There is a new Android Canary build available today that simplifies data transfer between two smartphones, and Apple is going to implement the functionality in an upcoming iOS 26 beta. Apple already has a Move to iOS app for transferring data from an Android...
Intel Inside iPhone Feature
Apple's Return to Intel Rumored to Extend to iPhone
Friday December 5, 2025 10:08 am PST by
Intel is expected to begin supplying some Mac and iPad chips in a few years, and the latest rumor claims the partnership might extend to the iPhone. In a research note with investment firm GF Securities this week, obtained by MacRumors, analyst Jeff Pu said he and his colleagues "now expect" Intel to reach a supply deal with Apple for at least some non-pro iPhone chips starting in 2028....
Apple Fitness Plus expansion hero
Apple Fitness+ Coming to 28 New Regions With Digital Voice Dubbing
Monday December 8, 2025 6:19 am PST by
Apple today announced that Fitness+ is expanding to 28 new markets on December 15 in the service's largest international rollout since launch, accompanied by new language dubbing and a K-Pop music genre. Apple Fitness+ will become available in Chile, Hong Kong, India, the Netherlands, Singapore, Taiwan, and additional regions on December 15, with Japan scheduled to follow early next year....
