Belkin, known for the accessories that it makes for Apple's devices, recently announced its first MagSafe products, the Boost Charge Pro MagSafe 3-in-1 Wireless Charger and the Car Vent PRO. The wireless charger isn't out just yet, but the Belkin Car Vent Mount PRO with ‌MagSafe‌ has launched.
belkin car vent mount magsafe 2
The Car Vent PRO is, as the name suggests, a mount that's been created for use in the car with a design that attaches to a car's vents. Priced at $40, the Car Vent PRO is not a charger and has no charging capabilities.
belkin car vent 1
The accessory is a simple magnet-based mount that attaches to ‌MagSafe‌ devices that include the iPhone 12, 12 mini, 12 Pro, and 12 Pro Max, adhering to the ‌MagSafe‌ magnet built into those devices. It also works with ‌MagSafe‌ cases attached to ‌iPhone‌ 12 models.
I'm not entirely sure why the Car Vent PRO has "Pro" attached to its name because it's a fairly simple mount. It's made from a lightweight plastic material that's designed to look like aluminum with a softer material on the mount portion of the accessory to ensure an attached ‌iPhone‌ isn't scratched or otherwise damaged.
belkin car vent 2
The lightweight design is nice because it's not putting unnecessary weight on the car's vents. There's a silicone prong on the back of the Car Vent PRO that grabs right into a car's vents, with about an inch and a half space between the vents and the front of the mount. The grip is tight enough that I'm confident it's not going to come loose from the vent.
belkin car vent mount 3
I'm not often in the car these days so I haven't been able to do extensive terrain testing on how well the magnetic connection works. With my ‌iPhone‌ attached, if I give the mount a good shake I can dislodge my ‌iPhone‌, but I do have to put a decent amount of effort into it.
belkin vent mount 4
I suspect that there are situations where a huge bump could dislodge the ‌iPhone‌ from the mount, but for day to day smoother driving, it feels well-adhered. I took several trips on a fairly bumpy road and had no problems with the magnetic connection with an ‌iPhone‌ 12 or a heavier iPhone 12 Pro Max even at fast speeds and during turns.
belkin vent mount 5
While there's no built-in charging, you can attach the Vent PRO to an in-car Lightning cable if you already have that setup, which makes it more useful. There is a spot for routing a cable around the back if you do want to use it with a charger. My car's charging ports are located in the center console under a lid, so it's not a convenient setup for my situation and I wasn't able to test it with a cable attached.
belkin vent mount 6
The Car Vent PRO can be used in either portrait or landscape mode with an attached ‌iPhone‌, so depending on your in-car setup and how you prefer Maps to look, you can get it working the way that you like. To facilitate use in either orientation, the Car Vent PRO itself rotates thanks to an adjustable ball joint that can also change the angle of the phone as needed.
Bottom Line
Belkin's Car Vent PRO does what it's supposed to do - it successfully provides a way to mount your ‌iPhone‌ in the proper position for using apps like Maps while in the car. The magnetic connection held up well in my testing, and the adjustable ball joint allows the mount to work in most vehicle setups.
Compared to other mounting options, it's simple because it requires no extra hardware or magnets, and it's basically the only ‌MagSafe‌ mounting option at the moment. If you need a mount for the car and have an ‌iPhone‌ 12, Belkin's option is worth checking out.
How to Buy
The Belkin Car Vent PRO can be purchased from Apple for $39.99.
Note: Belkin provided MacRumors with a Car Vent PRO for the purpose of this review. No other compensation was received.
Tag: Belkin
Top Rated Comments
Noah Bloom Avatar
57 months ago
"I'm not often in the car these days so I haven't been able to do extensive testing on how well the magnetic connection works."
Maybe have somebody who does drive review it then? lol
Score: 33 Votes (Like | Disagree)
mikfrank Avatar
57 months ago
This would be "Pro" if it included wireless charging. This is just a magnetic mount.
Score: 25 Votes (Like | Disagree)
twodonnell Avatar
57 months ago
Returned mine immediately. The magnet is definitely not sufficient. Literally going around a corner from a turn lane is enough to make the mount shift one direction or the other and send my phone flying. The mount may be "lightweight" but it protrudes so far out from the mount point on my car's vent that with my iPhone Pro attached it's enough to make my vents swing in whichever direction I turn the car (and thus the phone flying). This is a terrible product.
Score: 12 Votes (Like | Disagree)
Theydonboi Avatar
57 months ago
Just seems pretty redundant without charging capabilities. The point of a magsafe mount is surely to provide ease of attachment without unnecessary fiddling. It defeats the point if I have to attach and remove a cable each and every time I want to move the phone.
I would rather Belkin had focused their efforts on releasing their 3-in-1 MagSafe charger before Christmas. That’s a far more enticing release.
theBigD23 Avatar
57 months ago
Yes, it's expensive, but I got it right away and it works great. Sticks tight and easy to use. Happy with the purchase and much nicer than other similar vent mounts.
kuwxman Avatar
57 months ago
Ha, I was semi on board even at $40 when I thought it WAS made out of aluminum. Now that I hear it is made from plastic, this is a hard pass.
Popular Stories
Beyond iPhone 13 Better Triad
iOS 19 Roundup Feature
Apple 2025 Thumb 1
CarPlay Hero
Apple Bristol Current
An Apple Store in the UK is Permanently Closing Later This Year
Monday April 14, 2025 7:33 am PDT by
Apple has confirmed that it will be permanently closing its retail store in the heart of Bristol, England, and there is no replacement in sight. Apple Bristol in 2023 Apple Bristol will be closing its doors on Saturday, August 9, due to redevelopment plans at the Cabot Circus Shopping Centre, and the adjacent Bristol Shopping Quarter. According to news reports, and a building application, the ...
iPhone 6s MacRumors YouTube
Apple Says These Products Are Now Vintage
Tuesday April 15, 2025 9:53 am PDT by
Apple today updated its vintage products list to add the 2018 Mac mini and the iPhone 6s, devices that will get more limited service and repairs now that they are considered vintage. The iPhone 6s initially launched in 2015, but Apple kept it around as a low-cost device until 2018, which is why it is only now being added to the vintage list. The iPhone 6s had Apple's A9 chip, and it was...
iOS 18
Apple Releases iOS 18.4.1 With Bug Fixes
Wednesday April 16, 2025 10:11 am PDT by
Apple today released iOS 18.4.1 and iPadOS 18.4.1, minor updates to the iOS 18 and iPadOS 18 operating systems that came out last September. iOS 18.4.1 and iPadOS 18.4.1 come two weeks after the launch of iOS 18.4 and iPadOS 18.4. The new software can be downloaded on eligible iPhones and iPads over-the-air by going to Settings > General > Software Update. There have been complaints about ...
