If you connect your Mac to an external display, you may find that the Mac's on-screen and keyboard volume controls are disabled. That's because HDMI, DisplayPort, and Thunderbolt connections carry a fixed volume digital audio signal, so the external device (in this case, a monitor) controls the sound level.
mac volume disabled
This can be frustrating if the volume controls on your external display are concealed in the bezel or buried in a fiddly on-screen menu. Fortunately, it is possible to re-enable your Mac's native volume controls and use them to adjust the sound level coming out of your monitor's speakers. The steps below show how it's done, although you will need administrator privileges to follow them.
  1. Download the free SoundFlower extension (v2.0b2) from Github.
    enable mac volume control of external monitor speakers00
  2. double-click the SoundFlower.dmg file to mount it.
  3. Hold down the Ctrl key and left-click the Soundflower.pkg file, then choose Open from the contextual menu.
    enable mac volume control of external monitor speakers1
  4. If you see a dialog asking if you're sure you want to open it, click Open. If you see a dialog saying the package can't be opened, click OK, open System Preferences' Security & Privacy pane, and in the General tab click Open Anyway.
    enable mac volume control of monitor speakers 3
  5. Let the Soundflower installer continue and enter your password if necessary.
  6. Next, download the SoundflowerBed utility (v2.0), mount the .dmg file, and drag the flower icon to your Applications folder.
    enable mac volume control of external monitor speakers3
  7. Launch the SoundflowerBed utility.
  8. Click the SoundflowerBed icon in the menubar and select DisplayPort, Thunderbolt or HDMI as the output in the (2ch) list.
    enable mac volume control of external monitor speakers04
  9. Click the volume icon in the menu bar and choose Soundflower(2ch). You can also make this selection in the Sound System Preference pane.
    enable mac volume control of external monitor speakers5
You should now be able to adjust the volume of the speakers in your HDMI or DisplayPort monitor using the native media controls on your Mac.
Top Rated Comments
ChromeAce Avatar
93 months ago
I installed this once 10 years ago and it conflicted with other audio apps. It took me 5 years to figure out what the problem was and get rid of the driver (by finally doing a clean install). Never again.
xflashx Avatar
93 months ago
Apple really should add native support for this in macOs. Every other OS (at least Linux and Windows) are able to adjust the volume when audio is delivered over HDMI/DP.
I’m waiting for this functionality to be added since forever...
Edwards007 Avatar
72 months ago
I used and appreciated Soundflower for years, but it quit working when I upgraded to High Sierra, and it doesn't appear to be supported anymore. I tried something called blackhole, but I couldn't get it to work, so I downloaded the 15 dollar sound control app mentioned by pizzapizza, and it works perfectly with my HDMI display.
Being able to control the sound output from the keyboard controls is so obvious that it is impossible to understand why Apple seems to go out of their way to inhibit this.
Ohples Avatar
93 months ago
Make sense that because it's a digital signal it would be harder to adjust the "volume" but you would think there would be some CEC ('https://en.wikipedia.org/wiki/Consumer_Electronics_Control') like mechanism so the volume control on the system can adjust the monitor/external device volume.
Val-kyrie Avatar
93 months ago
The need for this hack demonstrates Apple's lack of forethought both in its hardware and in its software.
I personally would not bother with this since it can cause more problems than it solves.
falcn Avatar
91 months ago
And, it works with the standard Mac volume keys. The only thing that's not perfect is the volume range. When it's at the lowest volume, it's not quite as low as I might want it.
Just installed this and it seems to be working well for me. As BobMcBob mentioned the volume control range is not as expansive as I would prefer, but volume control from my keyboard is back, so I am happy.
It is on sale at the moment so I bought a license after downloading and installing the trial version.
Thanks for the tip!
Sorry for late reply, I don't visit macrumors often.
You can go lower than one notch of volume, hold Shift+Option+[your volume key]. It's stock Mac OS feature.
A similar problem is adjusting the brightness on an external monitor. The standard Mac brightness keys don't work. I installed Brightness Slider from the app store. It's not bad, but it doesn't use the normal brightness keys. You can set your own keyboard shortcut, but you can't use the normal brightness keys. Does anyone have a better solution for that?
I use free app called Lunar https://lunarapp.site
It works if your external monitor supports DDC (most of them do)
It mirrors your internal screen brightness level on your external screen, which is great if you have auto-adjust on.
Popular Stories
iphone 17 models
No iPhone 18 Launch This Year, Reports Suggest
Thursday January 1, 2026 8:43 am PST by
Apple is not expected to release a standard iPhone 18 model this year, according to a growing number of reports that suggest the company is planning a significant change to its long-standing annual iPhone launch cycle. Despite the immense success of the iPhone 17 in 2025, the iPhone 18 is not expected to arrive until the spring of 2027, leaving the iPhone 17 in the lineup as the latest...
duolingo ad live activity
Duolingo Used iPhone's Dynamic Island to Display Ads, Violating Apple Design Guidelines
Friday January 2, 2026 1:36 pm PST by
Language learning app Duolingo has apparently been using the iPhone's Live Activity feature to display ads on the Lock Screen and the Dynamic Island, which violates Apple's design guidelines. According to multiple reports on Reddit, the Duolingo app has been displaying an ad for a "Super offer," which is Duolingo's paid subscription option. Apple's guidelines for Live Activity state that...
Clicks Communicator Feature
'Clicks Communicator' Unveiled — Will You Carry This With Your iPhone?
Friday January 2, 2026 6:35 am PST by
The company behind the BlackBerry-like Clicks Keyboard accessory for the iPhone today unveiled a new Android 16 smartphone called the Clicks Communicator. The purpose-built device is designed to be used as a second phone alongside your iPhone, with the intended focus being communication over content consumption. It runs a custom Android launcher that offers a curated selection of messaging...
Low Cost MacBook Feature A18 Pro
Low-Price 12.9-Inch MacBook With A18 Pro Chip Reportedly Launching Early This Year
Friday January 2, 2026 9:08 am PST by
Apple plans to introduce a 12.9-inch MacBook in spring 2026, according to TrendForce. In a press release this week, the Taiwanese research firm said this MacBook will be aimed at the entry-level to mid-range market, with "competitive pricing." TrendForce did not share any further details about this MacBook, but the information that it shared lines up with several rumors about a more...
Apple Fitness Plus hero
Apple Announces New Fitness+ Workout Programs, Strava Challenge, and More
Friday January 2, 2026 6:43 am PST by
Apple today announced a number of updates to Apple Fitness+ and activity with the Apple Watch. The key announcements include: New Year limited-edition award: Users can win the award by closing all three Activity Rings for seven days in a row in January. "Quit Quitting" Strava challenge: Available in Strava throughout January, users who log 12 workouts anytime in the month will win an ...
Low Cost A18 Pro MacBook Feature Pink
Apple's 2026 Low-Cost A18 Pro MacBook: What We Know So Far
Friday January 2, 2026 4:33 pm PST by
Apple is planning to release a low-cost MacBook in 2026, which will apparently compete with more affordable Chromebooks and Windows PCs. Apple's most affordable Mac right now is the $999 MacBook Air, and the upcoming low-cost MacBook is expected to be cheaper. Here's what we know about the low-cost MacBook so far. Size Rumors suggest the low-cost MacBook will have a display that's around 13 ...
Mac Pro Feature Blue
What's Happening With the Mac Pro?
Wednesday December 31, 2025 9:59 am PST by
Apple hasn't updated the Mac Pro since 2023, and according to recent rumors, there's no update coming in the near future. In fact, Apple might be finished with the Mac Pro. Bloomberg recently said that the Mac Pro is "on the back burner" and has been "largely written off" by Apple. Apple apparently views the more compact Mac Studio as the ideal high-end pro-level desktop, and it has almost...
