iPhone 15 Pro vs. 15 Pro Max Buyer's Guide: 10 Differences Compared
Apple recently unveiled the iPhone 15 Pro and ‌iPhone 15‌ Pro Max as the successors to the iPhone 14 Pro and iPhone 14 Pro Max, featuring a new titanium design, an Action button, a USB-C port, the A17 Pro chip, and more. As Apple's premium flagship offerings, the ‌iPhone 15‌ Pro and ‌iPhone 15‌ Pro Max are the most fully-featured iPhones available.
iPhone 15 Pro vs 15 Pro Max Buyers Guide Alt
The ‌iPhone 15‌ Pro starts at $999 and the ‌iPhone 15‌ Pro Max starts at $1,199. For the Pro Max model, this is a $100 price increase over last year's model, but there is also no longer a 128GB storage configuration available for this device, meaning that it is effectively only a price hike if you normally buy this model.
Both phones have the same OLED Super Retina XDR always-on display with ProMotion and the Dynamic Island, the A17 Pro chip, 5G connectivity, a "Pro" rear camera setup, and are available in the same color options. Although the two phones share the vast majority of features, there are ten important differences between the devices. Our guide highlights the crucial differences between the ‌iPhone 15‌ Pro and ‌iPhone 15‌ Pro Max, and helps to answer the question of how to decide which of these two iPhone models is best for you.
‌iPhone 15‌ Pro ‌iPhone 15‌ Pro Max
6.1-inch OLED Super Retina XDR display with 2532-by-1170-pixel resolution 6.7-inch OLED Super Retina XDR display with 2778-by-1284-pixel resolution
12-megapixel Telephoto camera with ƒ/2.8 aperture 12-megapixel Telephoto camera with ƒ/2.8 aperture and larger sensor
Telephoto camera with second-generation sensor-shift optical image stabilization Telephoto camera with folded tetraprism design and autofocus 3D sensor-shift module
0.5x, 1x, 2x, 3x optical zoom 0.5x, 1x, 2x, and 5x optical zoom
23-hour battery life (during video playback) 29-hour battery life (during video playback)
5.77-inch (146.6mm) height 6.29-inch (159.9mm) height
2.78-inch (70.6mm) width 3.02-inch (76.7mm) width
6.60-ounce (187 grams) weight 7.81-ounce (221 grams) weight
128GB, 256GB, 512GB, or 1TB storage 256GB, 512GB, or 1TB storage
$999 (128GB), $1,099 (256GB), $1,299 (512GB), or $1,499 (1TB) $1,199 (256GB), $1,399 (512GB), or $1,599 (1TB)
Just like some previous ‌iPhone‌ models offered in two sizes, such as the ‌iPhone‌ 12 Pro and iPhone 12 Pro Max, there is a major additional camera feature to be gained with the larger model. This year, that's 5x telephoto optical zoom, which is ideal for sports or wildlife photography since it can get even closer to a subject.
iPhone 15 Pro Max provides the longest optical zoom ever on iPhone: 5x at 120mm. Great for close-ups, wildlife photos, and catching the action from further distances, the new Telephoto camera on iPhone 15 Pro Max has an innovative tetraprism design with a combined optical image stabilization and autofocus 3D sensor-shift module, Apple's most advanced stabilization system yet.
The ‌iPhone 15‌ Pro has a maximum optical zoom of 3x and lacks the hardware enhancements of the ‌iPhone 15‌ Pro Max's telephoto camera. The Main and Ultra Wide cameras, are, however, identical between the two devices.
The ‌iPhone 15‌ Pro Max represents the most you can get out of an ‌iPhone‌ with the best possible battery life, but that does not necessarily translate into a worthwhile purchase for all users. Some users may prefer a 3x optical zoom over a 5x optical zoom, in which case the ‌iPhone 15‌ Pro is a better choice. Ultimately, the alternative photography capabilities of the devices come down to this single difference. If you are more likely to use your new ‌iPhone‌ to take portrait photos, the 3x telephoto of the ‌iPhone 15‌ Pro is a better choice, while the ‌iPhone 15‌ Pro Max is unrivalled for sports and wildlife photography where you are looking to shoot subjects that are much farther away.
Combined with longer battery life and a larger display, the ‌iPhone 15‌ Pro Max differs from the ‌iPhone 15‌ Pro relatively significantly. The added $200 in price for the ‌iPhone 15‌ Pro Max seems fair for its additional display area, battery life, storage, and camera technology but it is important to weigh up these factors in your personal use case. This shrinks to a $100 price difference if you normally buy a 256GB model.
iphone 15 pro gray
If you normally purchase a 128GB ‌iPhone‌ "Pro Max" model, it may be time to look at the smaller model this year, since getting the larger model will necessitate spending $100 more than usual and getting 256GB of storage, which you may not use up. On the other hand, if you always purchase an ‌iPhone‌ with 256GB of storage, you may be more inclined to buy the ‌iPhone 15‌ Pro Max.
Likewise, a larger, heavier 6.7-inch ‌iPhone‌ is not for everyone. Some may find the ‌iPhone 15‌ Pro Max's size excessive or uncomfortably large to hold, while others will love the larger display for consuming media. Screen size is ultimately a matter of personal preference, and since the ‌‌iPhone 15‌ Pro and ‌‌iPhone 15‌ Pro Max share most of their other features, it comes down to individual taste.
The most important decision point when choosing between the ‌iPhone 15‌ Pro and ‌iPhone 15‌ Pro Max is undoubtedly screen size, but comfort, pocketability, weight, battery life, and camera technology are also important considerations that will depend based on your personal needs and preferences. If you are hesitant about the size and weight of the ‌iPhone 15‌ Pro Max, it may be better to stick with the ‌iPhone 15‌ Pro, but it otherwise unlikely to disappoint, especially if price is not an issue.
Popular Stories
iPhone 17 Pro 34ths Perspective
iPhone 17 Pro Launching Later This Year With These 10 New Features
Sunday March 23, 2025 10:00 am PDT by
While the iPhone 17 Pro and iPhone 17 Pro Max are not expected to launch until September, there are already plenty of rumors about the devices. Below, we recap key changes rumored for the iPhone 17 Pro models as of March 2025: Aluminum frame: iPhone 17 Pro models are rumored to have an aluminum frame, whereas the iPhone 15 Pro and iPhone 16 Pro models have a titanium frame, and the iPhone ...
iOS 18
iOS 18.4 Expected Next Week - Here Are the Release Notes
Friday March 28, 2025 2:01 pm PDT by
With the second release candidate of iOS 18.4 that Apple seeded out today, the company finally provided us with release notes that give a full rundown on what to expect. There's an Apple Vision Pro app, new Apple Intelligence features for notifications and additional language support, plus an Apple News Food feature for Apple News+ subscribers, and several updates that should improve the...
macbook pro blue green
When Will Apple Release the M5 MacBook Pro?
Wednesday March 26, 2025 4:53 pm PDT by
Apple regularly refreshes the MacBook Pro models, and a new version that uses M5 series chips is in the works. Apple just finished refreshing most of the Mac lineup with M4 chips, and now it's time for the M5. Rumors suggest that we could see the first M5 MacBook Pro models this fall. Design There have been no rumors of a design update for the M5 MacBook Pro models that are coming this...
Facebook Feature
Facebook's New iPhone App Feature Turns the Clock Back to 2007
Thursday March 27, 2025 1:59 pm PDT by
In the mid-to-late 2000s, Facebook was all about staying connected with friends and family. However, as the social media platform added new features and grew over time, that core experience began to get drowned out. That changes starting now, according to Meta, which today introduced a new feature that will "bring back the joy" of classic Facebook. Specifically, Meta has redesigned the...
Magic Mouse Green
What to Expect From the Magic Mouse 3
Saturday March 29, 2025 10:15 am PDT by
Apple is reportedly working on a new Magic Mouse. Below, we recap what to expect. The two key rumors for the Magic Mouse 3 so far include a relocated charging port, along with a more ergonomic design. It was briefly rumored that the Magic Mouse 3 would also feature voice control, but that was misinterpreted information. Relocated Charging Port While the Magic Mouse switched from...
Six Things to Know About Apple's Upcoming Foldable iPhone
Friday March 28, 2025 3:54 pm PDT by
We've been hearing rumors about a foldable iPhone for almost a decade now, but it looks like we might finally see the device come to fruition in 2026. We're going to be waiting many more months for the foldable iPhone, but so far we're hearing good things. Apple wants to make it creaseless. It's taken Apple multiple years to design a foldable iPhone that it's satisfied with because Apple ...
top stories 2025 03 29
Top Stories: WWDC 2025 Announced, iPhone 17 Pro and iOS 19 Rumors, and More
Saturday March 29, 2025 6:00 am PDT by
Apple's big developer event is a little over two months away, and rumors about what we can expect to see in Apple's next major operating system updates are becoming increasingly frequent. A public release of iOS 18.4 is also imminent with a number of updates and improvements, although we won't be getting the major Apple Intelligence Siri upgrades that had reportedly been planned for this...
iOS 18 4 Ambient Music Control Center
How to Use iOS 18.4's New Ambient Music Feature in Control Center
Thursday March 27, 2025 7:45 am PDT by
The upcoming iOS 18.4 update for the iPhone adds an Ambient Music feature to Control Center. Below, we take a closer look at how it works. iOS 18.4 is currently in beta, so the Ambient Music feature is not widely available yet. The update will likely be released to the general public next week. To use the feature on iOS 18.4, open Control Center and tap on the plus sign in the top-left...
Foldable iPhone 2023 Feature 1
'iPhone Fold' to Feature Metallic Glass Hinge That Resists Deformation
Thursday March 27, 2025 4:21 am PDT by
Last week, we covered a report claiming that Apple's book-style foldable iPhone (or "iPhone Fold," as we are provisionally calling it here) will use liquid metal hinges to improve durability and help minimize screen creasing. Today, a Chinese leaker provided more details on the properties of this hinge material that help to clarify why Apple chose it for its first foldable device. According...
Top Rated Comments
BradWI Avatar
20 months ago
Being able to access the entire screen one-handed on the Pro outweighs any of the Max advantages for me.
Score: 20 Votes (Like | Disagree)
Zeddi92 Avatar
20 months ago
We all know that the zoom range up to 2x uses the main camera lens, shot at 48 MP then "binned" to 24 MP to create the image.
What happens in higher focal lengths between 2x and 5x? Is it shooting with telephoto lens at 48 MP then "binned" to lower megapixel to create the image? Or is the telephoto lens capable of optically zooming to those focal length? Or is it a combination digital interpolation with the main lens and telephoto lens?
Since the iPhones have no moving part you can guess the answer. But you dont have to guess, there are already reviews online. The iPhone 15 Pro Max shoots everything between 1x an 5x fl with the main camera and digital zoom. That makes images with eg 3x fl way better with a Pro than with a Pro Max. On the other hand the Pro Max starts to shine onwards the 5x fl, as even the digital zoom is way crisper for a 10x fl. In the end it matters what you personally prefer.
jonnysods Avatar
20 months ago
The value of the 256gb Pro is challenging when compared to the base Max specs. I’m coming from a 13 mini and don’t want a phone that big, but I didn’t really think through the value proposition. Now I’m a little indecisive!
Mac-ajs Avatar
20 months ago
10 "important differences" that amount to size and camera
I'm sorry MacRumors but this article has clickbait written all over it. It's preposterous to count screen size AND then height, width and weight as separate factors. Battery life is a function of size. Price is a function of size. Three different camera specs == camera difference. 10 == two (you forgot to mention that you are counting in binary)
Mitsjke Avatar
20 months ago
Don’t forget that you have to choose between 3x or 5x optical zoom.
There is no 3x optical zoom on the iPhone 15 Pro Max.
So if you find yourself needing 3x more often than 5x you better take the normal 15 Pro.
Because then you get native optical zoom. With the Pro Max you get the same digital zoom as the digital 15x in the current pro’s.
Love-hate ? relationship Avatar
20 months ago
Honestly even with the pro it's quite hard. 5.9" would be neat ;)
