iPhone 14 Plus vs. iPhone 14 Pro Max Buyer's Guide
The iPhone 14 Plus and ‌iPhone‌ 14 Pro Max are among Apple's newest ‌iPhone‌ models and follow 2021's ‌iPhone‌ 13 mini and ‌iPhone‌ 13 Pro Max. Now that Apple offers two iPhones with 6.7-inch displays, how different are the two models, and what exactly does a "Pro" device give you?
iphone 14 pro max deep purple
Last year, the biggest differences between the iPhone 13 and iPhone 13 Pro were ProMotion, 2GB of memory, three hours of battery life, and rear cameras with different apertures. With ‌iPhone‌ 14 Plus and ‌iPhone‌ 14 Pro Max, both devices share new features like Emergency SOS via satellite, Crash Detection, Action mode, 6GB of memory, Photonic Engine, and an upgraded 12-megapixel TrueDepth front camera with autofocus, but Apple's "Pro" and non-Pro ‌iPhone‌ models are more different than ever.
Our guide helps to answer the question of how to decide which of these two ‌iPhone‌ models is best for you, and serves as a way to clearly see what additional features and upgrades the ‌iPhone‌ 14 Pro Max brings to the table.
Key Differences
‌iPhone‌ 14 Plus ‌iPhone‌ 14 Pro Max
Aerospace-grade aluminum design with glass back Surgical-grade stainless steel design with frosted glass back
ProMotion with adaptive refresh rates up to 120Hz
Always-on display
800 nits max brightness (typical) 1,000 nits max brightness (typical)
1,200 nits peak brightness (HDR) 1,600 nits peak brightness (HDR) and 2,000 nits peak brightness (outdoor)
"Notch" TrueDepth camera array TrueDepth camera array with Dynamic Island
A15 Bionic chip A16 Bionic chip
"Advanced" dual-camera system "Pro" camera system
2x optical zoom range (2x optical zoom out, digital zoom up to 5x) 6x optical zoom range (3x optical zoom in, 2x optical zoom out, digital zoom up to 15x)
12-megapixel Main camera with ƒ/1.5 aperture 48-megapixel Main camera with ƒ/1.78 aperture
12-megapixel Ultra Wide camera with ƒ/2.4 aperture 12-megapixel Ultra Wide camera with ƒ/2.2 aperture
12-megapixel Telephoto camera with ƒ/2.8 aperture
Sensor-shift optical image stabilization Second-generation sensor-shift optical image stabilization
True Tone flash Adaptive True Tone flash
LiDAR scanner
Night mode portraits
Macro photography
Apple ProRAW
ProRes video recording up to 4K at 30 fps (1080p at 30 fps for 128GB capacity)
Macro video recording, including slo‑mo and time‑lapse
160.8mm height 160.7mm height
77.6mm width 78.1mm width
7.80mm thickness 7.85mm thickness
Weight of 203 grams Weight of 240 grams
26-hour battery life (during video playback) 29-hour battery life (during video playback)
128GB, 256GB, and 512GB storage options 128GB, 256GB, 512GB, and 1TB storage options
Available in Blue, Purple, Midnight, Starlight, and PRODUCT(RED) Available in Deep Purple, Space Black, Silver, and Gold
Starts at $899 Starts at $1,099
Final Thoughts
The ‌iPhone‌ 14 Pro Max offers a large number of upgrades over the ‌iPhone‌ 14 Plus. With just $200 difference to obtain a brighter display with ProMotion and always-on functionality, the ‌Dynamic Island‌, the A16 Bionic chip, and a radically different rear camera set up, not to mention longer battery life and a more premium design, many customers will be able to justify getting the ‌iPhone‌ 14 Pro Max over the ‌iPhone‌ 14 Plus. Due to the scale and breadth of the ‌iPhone‌ 14 Pro Max's improvements and features, customers should actively choose the high-end model in most cases.
It will only be worth getting the ‌iPhone‌ 14 Plus over the ‌iPhone‌ 14 Pro Max if you want a lighter device, do not care for the "Pro" rear camera setup or features like ProMotion and the always-on display, or cannot afford the $200 to upgrade to the high-end model. In this instance, you will still benefit from shared features like Emergency SOS via satellite. The ‌iPhone‌ 14 Plus is still a very well-rounded device, especially for customers coming from a much older model that want a larger screen size.
Related Forum: iPhone
Popular Stories
iOS 18 Siri Personal Context
Report Reveals Internal Chaos Behind Apple's Siri Failure
Thursday April 10, 2025 7:15 am PDT by
A new report from The Information today reveals much of the internal turmoil behind Apple Intelligence's revamped version of Siri. Apple apparently weighed up multiple options for the backend of Apple Intelligence. One initial idea was to build both small and large language models, dubbed "Mini Mouse" and "Mighty Mouse," to run locally on iPhones and in the cloud, respectively. Siri's...
Apple 2025 Thumb 1
M6 MacBook Pro Feature 1
maxresdefault
Alleged iOS 19 Icons Front Page Tech
iOS 19 Leak Reveals Alleged New Design With Rounder App Icons, Floating Tab Bar, and More
Monday April 7, 2025 3:13 pm PDT by
YouTube channel Front Page Tech is back today with another video that provides a closer look at iOS 19's alleged design changes. The video contains re-created renders of iOS 19, which are allegedly based on real footage of the software update, provided by sources within Apple. Overall, iOS 19 is expected to have a more glass-like, visionOS-inspired design, with added translucency for user...
Apple Northbrook
Apple Store in Chicago Area Permanently Closing Later This Month
Wednesday April 9, 2025 9:56 am PDT by
Apple will be permanently closing its store at the Northbrook Court shopping mall in the Chicago suburb of Northbrook on April 26, the company has announced. Apple has added the following notice to the store's web page:Thank you Northbook. Apple Northbrook is closing on April 26 at 7pm. We're still here for you. Please visit apple.com/retail to find your nearest store.Apple Northbrook opened ...
iOS 18
iOS 18.5 Includes Two Changes So Far
Wednesday April 9, 2025 9:09 am PDT by
Apple released the first beta of iOS 18.5 last week, and so far the software update includes only two minor changes. The changes are in the Mail and Settings apps. In the Mail app, you can now easily turn off contact photos directly within the app, by tapping on the circle with three dots in the top-right corner. In the Settings app, there is some new AppleCare+ information. For ...
apple intelligence black
NYT: Apple's AI Struggles Began with 2023 Chip Budget Dispute
Friday April 11, 2025 4:33 am PDT by
Apple's current struggles with Apple Intelligence and Siri began in early 2023 when AI head John Giannandrea sought approval from CEO Tim Cook to purchase more AI chips for development, according to a new report from The New York Times. Cook initially approved doubling the team's chip budget, but CFO Luca Maestri reportedly reduced the increase to less than half that amount, and instead...
