iPhone 12 Pro vs. iPhone 12 Pro Max Buyer's Guide
In 2020, Apple unveiled the iPhone 12 Pro and iPhone 12 Pro Max as the successors to the popular ‌iPhone‌ 11 Pro and iPhone 11 Pro Max, with a new squared-off industrial design, the A14 Bionic chip, a LiDAR Scanner, and MagSafe. As Apple's premium flagship offerings from 2020, the ‌iPhone‌ 12 Pro and ‌iPhone 12 Pro Max‌ were the most fully-featured iPhones available until the launch of the ‌iPhone‌ 13 Pro and ‌iPhone‌ 13 Pro Max.
iphone12prowaterresistance
The ‌iPhone‌ 12 Pro started at $999 and the ‌iPhone 12 Pro Max‌ started at $1,099, and while Apple has now discontinued them, customers may still find them available for much lower prices from third-party stores. Although the two phones share the vast majority of features, there are actually a number of differences between the devices besides just screen size. Our guide highlights the differences between the ‌iPhone‌ 12 Pro and 12 Pro Max, and helps to answer the question of how to decide which of these two iPhones is best for you.
Comparing the iPhone 12 Pro and the iPhone 12 Pro Max
The ‌‌iPhone‌ 12‌ Pro and ‌‌iPhone‌ 12‌ Pro Max share virtually all of the same key features. Both phones have the same OLED Super Retina XDR display technology, A14 Bionic processor, 5G connectivity, a "pro" camera setup with 12MP Ultra Wide, Wide, and Telephoto lenses, LiDAR Scanner, and are available in the same colors. More interesting is where the two devices differ.
Differences
iPhone 12 Pro
  • 6.1-inch OLED Super Retina XDR display with 2532-by-1170-pixel resolution
  • Telephoto lens with ƒ/2.0 aperture
  • 2x optical zoom in, 2x optical zoom out; 4x optical zoom range
  • Digital zoom up to 10x
  • Dual optical image stabilization
  • Battery life with 17 hours of video playback
  • Weight of 6.66 ounces (189 grams)
  • Originally priced at $999, $1099, $1299 for 128GB/256GB/512GB
iPhone 12 pro Max
  • 6.7-inch OLED Super Retina XDR display with 2778-by-1284-pixel resolution
  • Telephoto lens with ƒ/2.2 aperture
  • 2.5x optical zoom in, 2x optical zoom out; 5x optical zoom range
  • Digital zoom up to 12x
  • Sensor-shift optical image stabilization
  • Battery life with 20 hours of video playback
  • Weight of 8.03 ounces (228 grams)
  • Originally priced at $1099, $1199, $1399 for 128GB/256GB/512GB
Aside from physical size, Apple has added a few more camera improvements into the Max. Read on for a closer look at each of these aspects, and see where exactly the ‌‌iPhone‌ 12‌ Pro contrasts with its larger sibling.
Display Size
The most noticeable difference between the ‌‌iPhone‌ 12‌ Pro and ‌‌iPhone‌ 12‌ Pro Max is the display size. The ‌‌iPhone‌ 12‌ Pro has a size of 6.1 inches, and the 12 Pro Max has a size of 6.7 inches. This means that the larger phone will be able to display more content, with the UI elements of apps spaced further apart, and items such as the keyboard will be much bigger. The smaller phone, however, will be much more pocketable and easy to use with one hand.
iphone 12 safari size b
iPhone 12 mini vs 12 Pro vs 12 Pro Max screen sizes in Xcode.
Ad-free MacRumors subscription available here.
The displays themselves use the exact same technologies and have the same features, but the main reason to prefer the ‌‌iPhone‌ 12‌ Pro will be because of its better fit in the hand and easier one-handed use. Likewise, those that prefer a larger display, to the point that it may begin to cannibalize the 7.9-inch iPad mini, will clearly prefer the ‌iPhone 12 Pro Max‌.
Dimensions and Weight
As a smaller phone, the ‌‌iPhone‌ 12‌ Pro obviously has a lesser height and width than the ‌‌iPhone‌ 12‌ Pro Max. The ‌‌iPhone‌ 12‌ Pro is 14.1mm shorter and 6.6mm narrower than the ‌‌iPhone‌ 12‌ Pro Max. However, both phones have the same thickness of 7.4mm. The ‌‌iPhone‌ 12‌ Pro is also 39 grams (1.38 ounces) lighter than its larger counterpart, at just 189 grams (6.66 ounces) in total.
iphone12prodesignback
Cameras
The camera is another key area of separation between the devices. The two iPhones have very similar rear camera arrays, with three 12MP cameras, including an Ultra Wide, Wide, and Telephoto, and a LiDAR Scanner, and many of the same software features, such as Smart HDR 3, Night mode, Deep Fusion, and Apple ProRAW. However, the larger size of the 12 Pro Max has allowed Apple to add three additional camera features.
The Wide camera of the ‌iPhone 12 Pro Max‌ features a 47 percent larger sensor with bigger pixels, which lets in a lot more light than the Wide-angle camera of the ‌iPhone‌ 12. Low-light photos taken with the ‌iPhone 12 Pro Max‌ are 87 percent better, according to Apple, with images also featuring more detail and better color.
The Telephoto lens on the ‌iPhone‌ 12 Pro has an f/2.0 aperture while the Telephoto lens of the ‌iPhone 12 Pro Max‌ has an f/2.2 aperture, but the ‌iPhone 12 Pro Max‌ has a 65mm focal length and 2.5x zoom lens that is superior to the 52mm focal length and 2x zoom lens in the ‌iPhone‌ 12 Pro, allowing for a 5x optical zoom range.
iphone12protriplelenscamera
The ‌iPhone 12 Pro Max‌ also has sensor-shift optical image stabilization on its Wide lens instead of lens-shift optical image stabilization. This means that the camera sensor moves to counteract shake, rather than the lens. The result is improved optical image stabilization.
Increased zoom in, better low-light performance, and sensor-shift optical image stabilization are noteworthy, if not especially groundbreaking, camera improvements. Nevertheless, if you heavily use your ‌iPhone‌ for photography and videography, the advancements on the 12 Pro Max will likely be appreciated.
Battery Life
The ‌iPhone‌ 12 Pro and 12 Pro Max also differ when it comes to battery life. The ‌‌iPhone‌ 12‌ Pro can deliver up to 17 hours of video playback, according to Apple. However, since the ‌‌iPhone‌ 12‌ Pro Max is much larger, it can accommodate a larger battery and therefore offer a longer battery life. This means that the ‌‌iPhone‌ 12‌ Pro Max can reportedly deliver up to 20 hours of video playback. Real-world battery life for both devices is likely to be lower than Apple's estimates, as mixed usage tends to be a bit heavier than video playback alone.
iphone12proside
If battery life is a priority for you, the ‌‌iPhone‌ 12‌ Pro Max offers excellent battery life. If you choose to get the ‌‌iPhone‌ 12‌ Pro, it will still have a fair battery life, but it does not reach the capability of the 12 Pro Max.
Other iPhone Options
With an original a starting price of $999, if the ‌iPhone‌ 12 Pro is outside your comfortable spending range, you should definitely consider its cheaper counterpart, the ‌iPhone‌ 12 ($599/$699), or even the ‌iPhone‌ 11 ($499).
iphone size comparisons d
Final Thoughts
The most obvious decision point between the ‌iPhone‌ 12 Pro and ‌iPhone 12 Pro Max‌ falls comes down to screen size. The camera enhancements of the ‌iPhone 12 Pro Max‌ also make it the best ‌iPhone‌ for photography and videography. Likewise, heavy battery users will value the added capacity.
The ‌iPhone 12 Pro Max‌ represents the most you can get out of an ‌iPhone‌ in all areas, but that does not necessarily translate into a worthwhile purchase for all users. A large 6.7-inch phone is not for everyone. Some may consider the ‌iPhone 12 Pro Max‌'s size excessive or uncomfortably large, while others will love the larger display for consuming media.
Screen size is ultimately a matter of personal preference, and Apple offers the ‌‌iPhone‌ 12‌ and ‌iPhone‌ 12 Pro lineup in three different sizes to meet all users' needs. Since the ‌‌iPhone‌ 12‌ Pro and ‌‌iPhone‌ 12‌ Pro Max share almost all features except for some camera hardware, it comes down to individual taste. The added $100 in price seems a fair trade for the added size, battery life and camera features.
Related Forum: iPhone
Popular Stories
iOS 18 Siri Personal Context
Report Reveals Internal Chaos Behind Apple's Siri Failure
Thursday April 10, 2025 7:15 am PDT by
A new report from The Information today reveals much of the internal turmoil behind Apple Intelligence's revamped version of Siri. Apple apparently weighed up multiple options for the backend of Apple Intelligence. One initial idea was to build both small and large language models, dubbed "Mini Mouse" and "Mighty Mouse," to run locally on iPhones and in the cloud, respectively. Siri's...
M6 MacBook Pro Feature 1
Apple 2025 Thumb 1
Alleged iOS 19 Icons Front Page Tech
iOS 19 Leak Reveals Alleged New Design With Rounder App Icons, Floating Tab Bar, and More
Monday April 7, 2025 3:13 pm PDT by
YouTube channel Front Page Tech is back today with another video that provides a closer look at iOS 19's alleged design changes. The video contains re-created renders of iOS 19, which are allegedly based on real footage of the software update, provided by sources within Apple. Overall, iOS 19 is expected to have a more glass-like, visionOS-inspired design, with added translucency for user...
Apple Northbrook
Apple Store in Chicago Area Permanently Closing Later This Month
Wednesday April 9, 2025 9:56 am PDT by
Apple will be permanently closing its store at the Northbrook Court shopping mall in the Chicago suburb of Northbrook on April 26, the company has announced. Apple has added the following notice to the store's web page:Thank you Northbook. Apple Northbrook is closing on April 26 at 7pm. We're still here for you. Please visit apple.com/retail to find your nearest store.Apple Northbrook opened ...
iOS 18
iOS 18.4.1 Update Coming Soon for iPhones
Wednesday April 9, 2025 8:56 am PDT by
Apple employees are testing iOS 18.4.1 for iPhones, according to the MacRumors visitor logs, which have been a reliable indicator of upcoming iOS versions. The software update will likely be released in a week or two, if not sooner. As the version number implies, iOS 18.4.1 will obviously be a minor update that addresses software bugs and/or security vulnerabilities. There are no...
iOS 18
iOS 18.5 Includes Two Changes So Far
Wednesday April 9, 2025 9:09 am PDT by
Apple released the first beta of iOS 18.5 last week, and so far the software update includes only two minor changes. The changes are in the Mail and Settings apps. In the Mail app, you can now easily turn off contact photos directly within the app, by tapping on the circle with three dots in the top-right corner. In the Settings app, there is some new AppleCare+ information. For ...
iPhone 17 Pro's New Rear Camera Bar 'Same Color As Rest of Device'
Monday April 7, 2025 2:09 am PDT by
Apple's upcoming iPhone 17 Pro models will feature a redesigned rear camera panel that spans the width of the device, but it will be the same color as the iPhone itself, rather than being part of a two-tone design. That's according to Bloomberg's Mark Gurman. Writing in his latest Power On newsletter, the reporter says the iPhone 17 Pro won't have a two-toned back, as some renders have...
5 Biggest Changes Rumored for iPhone 17 Pro
Tuesday April 8, 2025 2:38 am PDT by
Later this year, Apple will introduce the iPhone 17 series, which includes the iPhone 17 Pro and the iPhone 17 Pro Max, two new high-end flagship devices that will be sold alongside the regular iPhone 17 and an all-new ultra-thin iPhone 17 Air. If you have been holding out for the iPhone 17 Pro or its bigger sibling, here are five of the biggest changes, informed by the latest reports and...
Top Rated Comments
farewelwilliams Avatar
59 months ago
The Telephoto lens on the ‌iPhone 12 Pro‌ Max has a larger ƒ/2.2 aperture, rather than the ƒ/2.0 aperture of the ‌iPhone 12 Pro‌.
I think that's wrong. f/2.0 allows more light. Pro Max has a longer telephoto lens which is unable to let in more light.
Also, Pro Max sensor has a larger sensor for the wide camera with larger pixels which Pro doesn't have I believe. Pro Max's wide camera will have better low light performance than Pro.
Score: 28 Votes (Like | Disagree)
Ds6778 Avatar
59 months ago
Attachment Image
Score: 22 Votes (Like | Disagree)
840quadra Avatar
59 months ago
I don't like that Apple is taking steps backwards, making a divide in their flagship phone camera systems. If size (especially depth) is a factor, make the dang smaller phone 1-2 mm thicker. Was always frustrating being a small phone user, but (back in the day) not being included in having a telephoto lens. The iPhone X changed all of that, and here we are starting to separate the two flagship sizes yet again.
Score: 20 Votes (Like | Disagree)
lakaiordie Avatar
59 months ago
Idk if your camera specs are right. But f2.0 allows more light in than 2.2. So that part is wrong
Score: 18 Votes (Like | Disagree)
citysnaps Avatar
59 months ago
I was torn between the mini and the pro max. Now I’m torn the mini, pro and pro max. Upgrading from the XR and am interested in iPhone Photgraphy.
I think any of the three iPhone 12 models will produce outstanding photos, depending on what you like to photograph. While there are some improvements at the Pro Max end, I don't think they'd be deal-killers not having them.
I was first going to order the Pro Max, mostly for increased battery life and better wide sensor. But after making a Pro Max model out of wood and using for half a day pretending it was a phone and camera, it was clear, for me, I'd be frustrated using it due to its size. The 12 Pro, being similar in size to my three year old X, is the one I decided on as my X has been a joy to use having made many thousands of photographs.
Ocean Beach, San Francisco:
Attachment Image
Score: 16 Votes (Like | Disagree)
Taz Mangus Avatar
59 months ago
It's been six years since the iPhone 7 came out and the iPhone 12 is only marginally better. At this rate, (of diminishing returns) the iPhone 19 looks like the next iPhone to wait for.. Seven more years
The 2/3 camera system in the iPhone 12 is only marginally better the the single camera system in the iPhone 7? I am going to have to disagree with that.
Score: 11 Votes (Like | Disagree)
