AirPods Pro vs. AirPods Max Buyer's Guide: 30+ Differences Compared
The AirPods Pro and AirPods Max are Apple's highest-end headphone options, so which should you choose?
AirPods Pro vs Max Buyers Guide
Almost three years after the launch of the first-generation ‌AirPods Pro‌, Apple unveiled the second-generation model alongside the iPhone 14 lineup and several new Apple Watches in 2022, and swapped the Lightning port for USB-C a year later in 2023. Although the second-generation ‌AirPods Pro‌ feature the same design as their predecessor, they improve on features like Active Noise Cancellation, in-ear detection, and battery life, while introducing new functionality like Adaptive Transparency, volume adjustment touch controls, and precision finding.
In late 2020, Apple announced the ‌AirPods Max‌, a whole new AirPods variant with an over-ear design. Both the ‌AirPods Max‌ and the ‌AirPods Pro‌ feature Active Noise Cancellation, Personalized Spatial Audio with dynamic head tracking, Hey Siri, and automatic switching. In September 2024, the company refreshed the ‌AirPods Max‌'s selection of color options and swapped the Lightning port for USB-C.
As the two high-end AirPods options, should you consider purchasing the $249 third-generation ‌AirPods Pro‌, or do you need the ‌AirPods Max‌, which still sell for $549? Our guide helps to answer the question of how to decide which of these AirPods are best for you.
‌AirPods Pro‌ 2 (2022, 2023) ‌AirPods Max‌ (2020, 2024)
Plastic design Aluminum, stainless steel, and silicone design
IPX4 sweat and water resistant earbuds and charging case
Available in White only Lightning: Available in Silver, Space Gray, Sky Blue, Pink, and Green
USB-C: Starlight, Midnight, Blue, Purple, and Orange
In-ear fit with silicone ear tips (four size options) Over-ear fit
Clip-on silicone ear tips (four size options) Magnetic fabric ear cups
Skin-detect sensors Optical IR sensors
~10mm custom high-excursion Apple drivers and high dynamic range amplifiers 20mm dynamic Apple drivers and more powerful high dynamic range amplifiers
Dual beamforming microphones and inward-facing microphones Nine microphones (eight used for Active Noise Cancellation, three used for voice pickup)
H2 chips H1 chips
Bluetooth 5.3 Bluetooth 5.0
Lightning: 2.4GHz connectivity
USB-C: 2.4GHz and 5GHz connectivity
2.4GHz connectivity
USB-C: Lossless audio support with Apple Vision Pro
"Hey ‌Siri‌" and "‌Siri‌" voice commands "Hey ‌Siri‌" voice commands
Force sensor for media and listening mode controls Noise control button for listening mode controls
Touch controls for volume adjustment Digital Crown for media controls and volume adjustment
Transparency and Adaptive Transparency Transparency
Adaptive Audio
Conversation Awareness
Conversation Boost
Loud Sound Reduction
Hearing Protection (coming fall 2024)
Hearing Test (coming fall 2024)
Hearing Aid (coming fall 2024)
Lanyard loop
U1 chip for Precision Finding
Speaker in charging case for Find My
Up to 6 hours of listening time on a single charge Up to 20 hours hours of listening time on a single charge
5 minutes in the case provides around 1 hour of listening time 5 minutes of charge time provides around 1.5 hours of listening time
Charge with Apple Watch charger, MagSafe charger, Qi wireless charging mats, and Lightning or USB-C (depending on model) Charge via USB-C or Lightning only (depending on model)
‌MagSafe‌ Charging Case Smart Case to preserve battery charge in ultra-low-power state
$249 $549
While there is some overlap between the ‌AirPods Pro‌ and ‌AirPods Max‌ with features like Active Noise Cancellation and Transparency, the entirely different fit and form factor of the headphones should make it easier for most customers to decide which device they prefer.
The ‌AirPods Max‌ offer a wide range of color options and a more premium design, as well as much longer continuous battery life from a single charge. Owing to its over-ear design and significantly larger drivers, the ‌AirPods Max‌ deliver markedly better audio quality than the ‌AirPods Pro‌, so if your main priority is audio quality, the ‌AirPods Max‌ will undoubtedly be the best choice. If you actively dislike the in-ear design of the ‌AirPods Pro‌, the ‌AirPods Max‌ may also be more comfortable.
On the other hand, the ‌AirPods Pro‌ offer a high-level of convenience and portability due to their small size and charging case. The audio quality of ‌AirPods Pro‌ cannot rival ‌AirPods Max‌, but features like Adaptive Audio, Loud Sound Reduction, and Conversation Boost are ideal for when you're on the go. Due to their lightweight, in-ear design and sweat and water resistance, the ‌AirPods Pro‌ are also perfect for workouts.
The ‌AirPods Pro‌ are much more versatile when it comes to charging, with four different ways to charge, compared to the ‌AirPods Max‌'s obligatory USB-C or Lightning port option, depending on whether you buy the latest version. Due to their size, weight, less durable design, and limited portability, the ‌AirPods Max‌ are best used at home for high-fidelity, prolonged listening sessions, while the ‌AirPods Pro‌ offer a more balanced experience with a high level of convenience and portability.
It is also worth noting that the ‌AirPods Pro‌ have many more features than the ‌AirPods Max‌, such as "‌‌Siri‌‌" voice commands, Precision Finding, Bluetooth 5.3, and lossless audio support, as well as the new hearing protection, testing, and aid features.
AirPods frequently see hefty discounts on Amazon and other third-party retailers, so stepping up to the Max version may be more worth it if you can take advantage of one of those deals. Both sets of AirPods often see solid discounts, so it is always worth seeking the best price using our Deals roundup.
Related Roundups: AirPods Max, AirPods Pro
Related Forum: AirPods
Popular Stories
AirPods Pro 3 Mock Feature
CarPlay Hero
iphone 16 pro models 1
Beyond iPhone 13 Better Triad
maxresdefault
iOS 19 Roundup Feature
top stories 2025 04 19
Top Rated Comments
Steve121178 Avatar
33 months ago
Surely it just comes down to whether you want over-ear or in-ear AirPods? Completely different product categories.
TorbenIbsen Avatar
33 months ago
Comparing the two products is a bit like comparing a boat and a car because they are both "transportation devices". They are very different products.
I have had both products. The Airpods Pro works perfectly, but I had to return the Airpods Max after a couple of days. They simply does not fit large heads and cannot be adjusted to do so. Wearing them was actually painful. - For over-the-ear I replaced them with Bose 700 which is fine as I don't need more than good stereo most of the time. They fit well and does not weigh half an elephant when you are wearing them. And they can be connected to two devices at the same time and switch automatically to the device which has active sound.
JTK Awesome Avatar
26 weeks ago
For me the answer is
APP ear tips aren’t big enough to seal my ear canals, and aftermarket tips suck for APP.
APM are pricey, heavy, and ugly, and the lack of included accessories (cables and a REAL carrying case) for the price is appalling.
Attachment Image
Kirkster Avatar
26 weeks ago
As a really long time Apple user I was looking forward to the AirPod Max2. Frankly USB-C and some different colors as the only improvements was the biggest miss from Apple in decades. Might have to go back as far as the QuickTake Camera to find a bigger miss. It was super lazy to not even put the H2 chip in there for a refresh.
lanomds1 Avatar
26 weeks ago
It’s underwhelming the fact that they refreshed the APM this year without any new tech built in. No better Bluetooth, no new sensors like U1 or new chips for better fidelity. No better battery capacity, no better and lighter materials. The same old and terrible case. No better ANC. No health features like the APP2. But still more than double the price.
I mean, I love my APM because of its sound quality, was hoping for a solid update this year, but just some new colors, unfortunately.
bookcase Avatar
26 weeks ago
I enjoy both, but my 2024 Max are the best IMO.
