AirPods 5 vs. AirPods 5 With Wireless Charging Case Buyer's Guide - MacRumors
Skip to Content
Apple offers two versions of the AirPods 5: a $129 model with a USB-C Charging Case and a $149 model with a Wireless Charging Case. The extra $20 also buys longer battery life, swipe volume controls, and additional Find My features, so there are differences between the earbuds themselves as well as their cases.
airpods 5 new blue
Both models include Active Noise Cancellation as standard, the H2 chip, the same open-ear design, and the same redesigned acoustic architecture with updated Adaptive EQ. They also share Transparency mode, Adaptive Audio, Conversation Awareness, Personalized Spatial Audio, Voice Isolation, studio-quality audio recording, and IP57 dust, sweat, and water resistance. Both support Live Translation when paired with a compatible iPhone with Apple Intelligence enabled, in supported languages and regions.
The earbuds have identical dimensions and weight. The cases are also the same size, although the Wireless Charging Case is slightly heavier. There are still some notable differences to justify the price difference. Our guide helps to answer the question of how to decide which of these sets of AirPods is best for you.
AirPods 5 AirPods 5 With Wireless Charging Case
Force sensor Force sensor with swipe volume controls
Up to four hours of listening time on a single charge with Active Noise Cancellation enabled (up to six hours with noise control off) Up to five hours of listening time on a single charge with Active Noise Cancellation enabled (up to seven hours with noise control off)
Up to 20 hours of listening time with the charging case with Active Noise Cancellation enabled Up to 22 hours of listening time with the charging case with Active Noise Cancellation enabled
Charging Case (USB-C) Wireless Charging Case (USB-C) with support for the Apple Watch charger and Qi-certified chargers
Case speaker for Find My and charging and battery status sounds
Find My with last-connected location and sound playback on the earbuds Find My network tracking, sound playback on the earbuds, separate locations for each earbud and the case, and individual Lost Mode support
Charging case weighs 32.3 grams (1.14 ounces) Charging case weighs 34.7 grams (1.22 ounces)
$129 $149
For most people, the AirPods 5 with Wireless Charging Case are clearly the better buy. The extra $20 is a very small premium for conveniences you are likely to appreciate if you use your AirPods regularly. Longer listening time is useful for travel and extended sessions, while swipe volume controls let you make adjustments without reaching for your iPhone or asking Siri.
The higher-end model is worth considering even if you plan to charge exclusively over USB-C. Wireless charging becomes more useful if you already have a Qi charger or Apple Watch charger. Its additional Find My features are valuable if you tend to misplace your AirPods, allowing you to locate the earbuds and case separately and use the Find My network when they are beyond your device's range. The case speaker also helps when it slips between cushions or gets buried in a bag.
The standard AirPods 5 make more sense if you are on a very strict budget, want a secondary pair, or mostly listen for short periods. You still get the same audio technology and noise cancellation, so saving $20 does not mean compromising on those core features. You simply need to be comfortable with USB-C charging, shorter battery life, fewer controls, and more limited Find My functionality.
The charging cases are not interchangeable between the two models. If you buy the standard AirPods 5, you cannot add wireless charging later by purchasing the other model's case, making it worth deciding which features you want before buying.
Before buying, compare prices using our Deals roundup, since discounts can change the price gap between the two models.
If you're considering an upgrade from AirPods 4 or want to see what changed between generations, our AirPods 4 vs. AirPods 5 Buyer's Guide compares the improvements and explains whether upgrading is worthwhile.
Related Roundup: AirPods 5
Buyer's Guide: AirPods (Buy Now)
Related Forum: AirPods
Popular Stories
AirPods Pro Beta Firmware 2
Apple Releases New AirPods Firmware With iOS 27 Features
Monday September 14, 2026 11:42 am PDT by
Apple today released new firmware for the AirPods Pro 2, AirPods Pro 3, AirPods 4, and AirPods Max 2. The firmware is available for all of the above devices, and it will enable support for new iOS 27 features. The firmware has a build number of 9A348. In iOS 27, iPadOS 27, and macOS Golden Gate, Apple is adding a new AirPods interface, a slider for Adaptive mode, and support for custom EQ....
First iPhone 18 Pro Apple Watch Series 12 Apple Watch Ultra 4 and AirPods 5 Orders Arriving to Customers Feature
First iPhone 18 Pro, Apple Watch Series 12, Apple Watch Ultra 4 and AirPods 5 Orders Arriving to Customers
Thursday September 17, 2026 2:59 pm PDT by
It's Friday, September 18 in Australia and New Zealand, which means customers who pre-ordered are beginning to receive their new devices. The iPhone 18 Pro, iPhone 18 Pro Max, Apple Watch Series 12, Apple Watch Ultra 4, and AirPods 5 are launching today. Apple fans who ordered an iPhone, Apple Watch, or AirPods will soon be sharing first impressions on Instagram, Reddit, the MacRumors...
Apple Releases New AirPods Beta Firmware
Tuesday September 29, 2026 11:38 am PDT by
Apple today released new beta firmware for the AirPods Pro 2, AirPods Pro 3, AirPods 4, AirPods 5, and AirPods Max 2. The firmware has a build number of 9B5042a and is rolling out for developers and public beta testers. There's no word on what's included in the firmware update because Apple doesn't offer notes for AirPods beta releases. When the AirPods are connected to an iPhone, iPad,...
Top Rated Comments
30 minutes ago at 08:08 am
I would go for the wireless charging version. Slightly better battery is good. Not much of a price difference between the two and the added convenience of wireless charging alone makes it a no brainer for me.
Latest Stories
38 minutes ago
Accessory Deals This Weekend: Save on TVs, Headphones, and Smart Home Gear
2 hours ago
Apple's All-New Home Hub Will Be Revealed October 13: What to Expect
2 hours ago
Apple Announcing HomePod Mini 2 Next Week With These New Features
2 hours ago
A New Apple TV 4K is Finally Coming on Tuesday
2 hours ago
Top Stories: Apple's 'Welcome Home' Launch on October 13 and More
3 hours ago
Apple Stores Will Add Your Name to iPhone Duo's Startup Screen
16 hours ago
SpaceX Inches Closer to Becoming a U.S. Carrier
17 hours ago
Apple Potentially Behind 'HomeView' Trademark Filed Alongside 'homeOS' Last Year
19 hours ago
Mark Your Calendar: Six Important Apple Dates Coming Up This Month
20 hours ago
MacRumors Giveaway: Win an Apple Watch Series 12 and a Nylon Band From Southern Straps
22 hours ago
First Apple TV 4K Now 'Vintage' Ahead of New Model Coming on Tuesday
23 hours ago
The MacRumors Show: Apple's Smart Home Products Are Coming
1 day ago
Apple Shares Fall After News of iPhone 18 Pro Order Cuts
1 day ago
Leak Details iPhone Features for Apple's LG Home Accessories
1 day ago
Prime Day Leftover Deals: AirPods Max 2 for $429, Mac Mini for $779.99, and More
1 day ago
Every M5 MacBook Air Now $200 Off on Amazon
1 day ago
Mac Shipments Fall, But Apple Still Gains Ground in Shrinking Market
1 day ago
Apple Reportedly Cuts iPhone 18 Pro Orders After Price Hike Dampens Demand
1 day ago
Apple Signs Hiring and Licensing Deal With AI Podcast Startup Huxe
1 day ago
Apple's October 13 Launch: What's Coming
2 days ago
Anthropic Says Users Can't Be Needlessly Cruel to Claude
2 days ago
Apple to Launch Touchscreen OLED MacBook Pro and OLED iPad mini on October 27
2 days ago
Apple Now Pushing iPhone Users Still on iOS 26 to Install iOS 27
2 days ago
Apple Has a New M&A Chief as Ternus Reshuffles Leadership
2 days ago
Prepare for Apple's New Home Hub With These HomeKit Accessory Deals
2 days ago
Tim Cook Says He's 'Not Meddling' With Apple's New CEO John Ternus
2 days ago
Tim Cook Explains Why He Stepped Down as Apple CEO Before iPhone Duo Launch
2 days ago
Apple Product Launch Announced for October 13: 'Welcome Home'
2 days ago
Amazon Unveils New iPad Rivals With Alexa+ and Google Play
2 days ago
