iPhone Ultra's Two Selfie Cameras Could Sit in the Same Corner - MacRumors
Skip to Content
With Apple's upcoming iPhone Ultra there's been a lingering question over the exact placement of the selfie cameras in the device's folded and unfolded states – but today we may have stumbled upon the answer.
foldable iphone dummy sonny dickson
Dummy units have suggested a top-centered cut-out for the selfie camera on the outer display of Apple's foldable, while locating the selfie camera for the inner display in the outermost top-left corner. That presents an asymmetry untypical of Apple's designs.
However, screen protectors for the iPhone Ultra that surfaced online today suggest the device's selfie cameras on the inner and outer displays may be located in the same corner of the same half, with one facing out and one facing in.
dummy iphone ultra open sonny
The screen protectors show a selfie camera cutout on the top-right corner of the outer display when the device is closed. Taken together, the two leaks could imply one front-facing camera zone in a single corner.
foldable iphone screen protectors
Such an arrangement – two slightly offset lenses – could let Apple confine the cutouts and camera modules to a single region of a 4.5mm thick chassis, rather than having them spaced out in different places, which would fit for a device where internal space is at a premium.
Now, accessory makers typically work from leaked CAD files of sometimes dubious accuracy, so a pair of screen protectors can't be considered to provide definitive evidence of a device's design. Our reading also assumes the dummy iPhone Ultra models had one camera placement correct (the top-left inner selfie camera) and one out of whack (the centered outer camera). Even so, the side-by-side internal placement could make sense.
We'll know one way or another soon enough. The iPhone Ultra is expected to be unveiled next month, featuring a 5.5-inch cover display and a 7.8-inch inner display, the A20 Pro chip, Touch ID integrated into the Side button in lieu of Face ID, and a 5,000mAh battery, along with a 48-megapixel dual rear camera system.
Related Roundup: iPhone Fold
Popular Stories
iPhone X 2022 Upload
'iPhone Ultra' to 'Repeat the iPhone X Story'
Tuesday July 14, 2026 6:42 am PDT by
Apple will likely "repeat the iPhone X story" by unveiling its foldable iPhone at the same time as the iPhone 18 Pro and iPhone 18 Pro Max, but starting foldable iPhone pre-orders at a later date, according to analyst Ming-Chi Kuo. Kuo said manufacturing challenges have limited early production of the foldable iPhone, which will reportedly be named iPhone Ultra. As a result, he believes the...
Z Fold8 with iOS Is it Worth It Thumb 1
Galaxy Z Fold8 Review: What Samsung's New Foldable Tells Us About the iPhone Ultra
Wednesday July 29, 2026 11:48 am PDT by
Samsung announced its latest foldable smartphones last week, and the lineup included the Galaxy Z Fold8, a device that's close to what we're expecting Apple's foldable "iPhone Ultra" to look like when it comes out later this year. MacRumors videographer Dan Barbera has been testing Samsung's new foldable, and the wider 4:3 display bodes well for the iPhone Ultra. Subscribe to the MacRumors ...
Four iPhone 18 Pro Colors Mock Feature
iPhone 18 Pro and iPhone Ultra: When is the Next Apple Event?
Thursday July 30, 2026 4:59 am PDT by
July is nearly over, meaning that Apple's annual iPhone event is fast approaching. Below, we look back at when Apple typically announces iPhone events. This September, Apple is expected to unveil the iPhone 18 Pro, iPhone 18 Pro Max, and an all-new foldable iPhone that will reportedly be named the iPhone Ultra. The regular iPhone 18, a lower-end iPhone 18e, and the iPhone Air 2 are not...
Top Rated Comments
deuxani Avatar
6 hours ago at 09:50 am
I don't think this is physically possible. The entire module is probably 3mm thick or more. The device will be 4.5mm thin, how would they put 2 lenses and 2 sensors in the exact same spot on top of each other? Either the dummy is wrong or the screen protector is wrong.
winxmac Avatar
7 hours ago at 09:30 am
There's no point in having a camera on the inner display. Just use the main camera and the front display.
I'm not the target market but I believe I should still voice out my opinion.
awshucks Avatar
7 hours ago at 09:25 am
If these are thinner selfie cameras that means more room for an UW camera in the Air 2.
MasterControlProgram Avatar
7 hours ago at 09:20 am
Quite a good placement perhaps, as that means widescreen video content won't have a black circle through them. That said all the old 4:3 stuff I watch won't be as lucky! 😅
Cuesca Avatar
7 hours ago at 09:16 am
It would be interesting if the device only have 1 selfie camera then uses a small mirror to reflect the camera for whatever screen(inner/outer) you want to take a selfie on.
MrENGLISH Avatar
5 hours ago at 10:34 am
I was thinking that too. Only way possible is if they are side-by-side facing opposite directions. No way they are stacked on top of each other.
