iPad Air OLED Panel Orders Could Be Split With BOE in 2027 - MacRumors
Skip to Content
BOE wants a share of the OLED supply chain for Apple's next iPad Air, aiming to land a secondary sourcing role behind primary supplier Samsung Display, according to a report from South Korea's The Elec.
m3 ipad air mint
Sources cited by The Elec say the Chinese panel maker is building out its iPad Air ‌OLED‌ effort at its B12 fab in Chongqing, home to BOE's sixth-generation ‌OLED‌ production line, ahead of the launch of a redesigned ‌iPad Air‌ that isn't expected to launch until the first half of 2027. Samsung Display already holds the lead supply role for that panel and is on track to begin ramping production toward the end of this year or the start of next, as previously reported.
BOE still has to clear Apple's qualification process. Samples reportedly still need to be submitted for evaluation, and a verdict on whether the company wins any commercial orders is not expected until closer to the end of the year. Even a favorable outcome may only translate into modest volume at first, with output confined to ‌iPad Air‌ units destined for the Chinese market or to refurbished devices, rather than the entire global launch.
The sources put BOE's qualification decision at some point in November or December, noting Apple typically finalizes production approval just one to two months ahead of mass production actually starting. Should BOE fall short of that bar, Samsung Display will end up carrying the entire initial production run by itself.
Becoming a supplier for the ‌OLED‌ ‌iPad Air‌ would be a meaningful expansion for BOE, which has experience providing ‌OLED‌ panels for the iPhone, but has struggled to break into larger ‌OLED‌ products. Samsung Display and LG Display have held onto that ground in tablets specifically, and BOE has lost, rather than gained, footing elsewhere in Apple's ‌OLED‌ lineup recently; its utilization on Apple-dedicated lines reportedly slid from roughly 82% in 2024 to about 48% earlier this year as Apple is set to lean on Samsung instead for the upcoming ‌OLED‌ iPad mini.
The redesigned ‌iPad Air‌ is expected in 11 inch and 13 inch sizes, with a hybrid ‌OLED‌ panel pairing a glass substrate with thin film encapsulation, a single stack RGB emissive layer, and an LTPS backplane, with a refresh rate of 60Hz. That keeps it below the iPad Pro's tandem stack ‌OLED‌ panel on cost, while still moving the ‌iPad Air‌ away from an LCD.
BOE is also reportedly pursuing a secondary supplier role for Apple's ‌OLED‌ MacBook Pro from its 8.6 generation B16 fab in Chengdu, but persistent yield problems there make commercial shipments to Apple unlikely soon. Industry sources do not expect BOE to enter that supply chain until sometime after 2028.
Related Roundup: iPad Air
Buyer's Guide: iPad Air (Buy Now)
Related Forum: iPad
Popular Stories
ipad mini 7 feature red and blue
OLED iPad Mini: Release Date, Pricing, and What to Expect
Tuesday July 14, 2026 5:45 am PDT by
According to the latest rumors, Apple is close to launching its next-generation iPad mini. So what should we expect from the successor to the iPad mini 7 that Apple released over 20 months ago. Read on to find out. Processor and Performance Apple is working on a next-generation version of the iPad mini (codename J510/J511) that features the A19 Pro chip, according to information found in...
OLED iPad Mini Feature 2
Upcoming OLED iPad Mini Allegedly Uses 60Hz 8.4-Inch Display Panel
Tuesday July 14, 2026 5:36 am PDT by
Apple is allegedly using a 60Hz 8.4-inch display panel in the upcoming OLED iPad mini, which is expected to be released later this year. The information comes courtesy of a hit-and-miss tipster running the account "yeux1122" on the Korean Naver blog. The leaker claims to have been told by a source in Apple's supply chain that the unreleased iPad mini is equipped with a low-temperature...
Apple iMac M4 hero feature
iMac Update Expected This Year, Model With OLED Display Also in Works
Wednesday July 22, 2026 9:10 am PDT by
Apple has finished development of a new iMac that it plans to release later this year, according to a report today from Bloomberg's Mark Gurman. The updated iMac is one of 11 new Mac models that Apple plans to release over the next two years or so. The next iMac will unsurprisingly have a newer chip, but the report did not indicate if Apple plans to use the existing M5 chip or the upcoming...
Top Rated Comments
10 hours ago at 04:44 am
BOE Display is like a TEMU version of Samsung Display 😬 it’s okay if they use BOE if they made an iPad Neo
Apple should not use subpar displays on premium devices 😤
Taq'aix Avatar
Ah yes, the iPad lottery. No one with a functioning brain wants BOE.
10 hours ago at 04:41 am
might make it cheaper for......Apple.
for the consumer...not so much.
7 hours ago at 07:01 am
Meanwhile the standard iPhone 17 has an OLED 120Hz display that's just as good as the 17 Pro. They really seem to go out of their way to make the Air feel inferior.
Aoligei Avatar
6 hours ago at 08:32 am
Samsung displays are the best. Not surprising to see Apple having multiple suppliers for display or any component.
It is depends. Samsung screen used on iPhone still use PMW dimming with 480Hz.
While Chinese display maker are making screen with
3840Hz / 4320Hz PWM dimming. This is huge bonus for people with sensitive eyes.
I wish iPhone uses higher PWM dimming rate.
snipr125 Avatar
8 hours ago at 06:06 am
Personally I would have preferred Apple to just use the same Promotion LCD panel as the iPP M2 for the next iPad Air. Thats all the iPad Air needs, Promotion.
