Skip to Content
iPhone Air 2 Could Get an 11% Battery Capacity Boost
Apple is reportedly working on a second-generation iPhone Air that's expected to launch in spring 2027, and one of Apple's main aims is to improve battery life. We now have the first rumor suggesting what kind of improvement could be coming.
iphone air camera
In a post on Weibo listing supply chain predictions, serial leaker Digital Chat Station said the iPhone Air 2 is expected to feature a 3,500mAh battery. That's up from the 3,149mAh battery in the current iPhone Air, indicating around a 11% increase in raw capacity.
A larger battery capacity usually implies either a physically larger battery or a denser one, but it does not automatically mean a bigger phone. Apple may also be able to improve internal packaging to fit a larger battery in the same chassis. Either way, it's going to be another tight squeeze.
Multiple prior rumors have suggested Apple is adding a second camera to the ‌iPhone Air‌ to address the main customer complaint about the device. The current model has a single rear Wide lens, which makes it less versatile compared to the more affordable iPhone 17 in terms of photography. Reports suggest Apple will add an Ultra Wide lens to the iPhone Air 2 to address this.
Multiple technologies are housed in the plateau of the iPhone Air to maximize space for the battery, so Apple would presumably need to redesign the internals considerably to fit in another camera. Whether that will impact the battery packaging design remains to be seen.
The device will use an A20 chip built on Apple's new 2nm process, so it could feature better efficiency, which should help battery life regardless of any change in battery capacity. In addition, according to a separate report, Apple is said to be adopting a Samsung-made OLED technology called CoE (Color Filter on Encapsulation), which could make the iPhone Air 2's display thinner. That could allow Apple to slide in a slightly larger battery while retaining the same device dimensions.
The iPhone Air 2 is expected to launch in the first half of 2027, alongside the regular iPhone 18 and the lower-cost iPhone 18e.
Related Roundup: iPhone Air
Buyer's Guide: iPhone Air (Caution)
Popular Stories
iphone air camera
'iPhone 20 Pro' Rumored to Be Based on iPhone Air
Monday November 16, 2026 5:40 am PST by
Next year's "iPhone 20 Pro" models will use the same glass design as the iPhone Air, but with more pronounced curvature along all four sides, according to the leaker known as "Fixed Focus Digital." In a new post on Weibo, the leaker said the device would use the same glass material as the iPhone Air, adjusted to have greater curvature and produce a four-sided curved effect. The accompanying...
iphone air 2 and iphone 18 dummy models
First Look at iPhone Air 2 and iPhone 18 Revealed By Dummy Models
Friday November 20, 2026 5:31 am PST by
New images of dummy models offer an early look at the purported designs of the iPhone Air 2 and iPhone 18, showing a new dual rear camera arrangement for the Air and a largely unchanged appearance for the standard model. In a new post on X, leaker Sonny Dickson highlights the iPhone Air's move from one rear camera to two as the biggest change. The standard iPhone 18, he says, retains a...
iphone 17e notch
iPhone 18e Could Get Two Key Upgrades While Keeping 60Hz Display
Tuesday October 27, 2026 3:41 am PDT by
Apple's upcoming iPhone 18e model will retain a 60Hz display but could gain an upgraded front-facing camera, according to the leaker known as "Digital Chat Station." In a new post on Weibo, the leaker said that the device will feature a 6.12-inch OLED display using low-temperature polycrystalline silicon (LTPS) technology, the A20 chip, and a single 48-megapixel rear camera. They were less...
Top Rated Comments
manhattanboy Avatar
20 weeks ago
The iPhone Air is still the most underrated iPhone. Using it with a carbon fiber case it is the best phone I’ve ever owned, so thin and light compared to the ProMax that I came from.
Personally, I don’t care for the ultra wide camera addition (I would have preferred a telephoto ). The extra battery would be a welcome addition.
Score: 25 Votes (Like | Disagree)
klasma Avatar
20 weeks ago
I’d prefer an 11% size and weight reduction.
Score: 12 Votes (Like | Disagree)
Jmausmuc Avatar
20 weeks ago
Definitely needs battery improvement. Thought the battery was fine during the Fall/Winter months, but now with this hot summer, the battery dies quicker and the Air heats up too much compared to my former 16 Pro or my wife's 17 Pro Max. Also - screen dims too easily during hot days too. Still really like the Air, but those are important drawbacks, as is the camera.
Wish the upgrades were coming out this Fall, as Spring is too long, so may end up going back to the the 18 Pro, although will not like having the extra weight and slightly smaller screen.
I can’t really agree. My air has been doing very well, even in the heat.
I have an Air and a 17 (regular) from work. I took both to the beach and noticed the 17 dimming earlier than the Air. That said both (and all other apple phones I have ever used) dim way to early. My Gfs 17 Pro dimmed slightly later but it was not a big difference either.
The biggest gripe I have with the Air is the really bad speaker. I hope this will be fixed with the next iteration, otherwise I’d be disappointed.
In any case, both the 17 and the 17 Pro look and feel really dated next to the Air. I can’t believe more people don’t see the value of the Air it’s really hard to understand.
Score: 11 Votes (Like | Disagree)
anthony13 Avatar
20 weeks ago
Instant buy from me. As long as it doesn’t increase the weight notably.
fatTribble Avatar
20 weeks ago
Yeah, I was surprised to learn from the forum how popular the ultra-wide lens is.
I do use it, but I use the telephoto lens much more.
20 weeks ago
Make these two updates and I am sold. I am already Jealous of my wife's iPhone Air while I lug my 16 Pro Max around. The lightness is the killer feature. A heavy brick seems old fashioned every time I pick it up. Happy to give up the Pro features that I hardly ever use.
Latest Stories
Best Black Friday Streaming Deals on Apple TV, Peacock, HBO Max, and More
13 minutes ago
Threads is Getting an iPad App
18 minutes ago
Developer Turns MacBook Trackpad Into a Speaker Using Haptic Motor
2 hours ago
A Decade Later, Apple Remains Berkshire's Biggest Stock Bet
2 hours ago
Black Friday Video Game Deals Include Rare Sale on Nintendo Switch 2 Mario Kart World Bundle
3 hours ago
M5 MacBook Air Now Starts at $989.10 for Black Friday, Get Up to $310 Off
3 hours ago
Apple Wallet Driver's License Feature Coming to Connecticut
4 hours ago
Coalition of 55,000 EU Businesses Challenges Apple
4 hours ago
Apple Watch Series 12 Drops to $299 on Amazon
4 hours ago
Apple May Be Stuck With Samsung for iPhone Duo Screens
5 hours ago
Jensen Huang Reinstated as Nvidia CEO
5 hours ago
iPhone Air 2 May Not Feature Smaller Dynamic Island
6 hours ago
iPad Mini 8 Gets First Major Discount for Black Friday at $100 Off
6 hours ago
AirPods Pro 3 Plunge to $149 for Black Friday ($100 Off)
6 hours ago
Apple Explores Using Light to Move Data Between Server Chips
7 hours ago
iPhone Sales Ban in India Sought by Startup Over NameDrop Feature
8 hours ago
MacBook Neo Could Get New Colors and Upgrades Every Year
8 hours ago
AirPods Pro 3 Drop to $169.99 in Amazon Black Friday Sale
22 hours ago
iPhone Duo Could Get More Lock Screen Widgets, Leak Suggests
23 hours ago
Gurman: Siri Layoffs Spared Newer AI Systems, But Problems Persist
23 hours ago
M6 MacBook Pro Drops to $1,799 in New Black Friday Sale ($200 Off)
1 day ago
Apple Reportedly Plans to Release These Products in February or March
1 day ago
Apple Watch SE 3 Lineup Sees Record Low Prices Starting at Just $179
1 day ago
Apple Black Friday Deals Available Now: AirPods, Apple Watches, MacBooks, and More
10 minutes ago
Apple Store in UK Permanently Closing Today
2 days ago
Siri AI Settlement: Here's How Much Apple Will Pay You
2 days ago
RIP, Apple Support Community
2 days ago
Top Stories: iPhone Duo Face Unlock, HomeView Tidbits, and More
2 days ago
Amazon Takes $120 Off 46mm GPS Apple Watch Series 12 With New Record Low Price [Update: Gone]
2 days ago
Siri Recap Hands-On: Private, But Not Very Useful
3 days ago
