iPhone 17 Pro Machined Parts Leak Reflects Camera Redesign Rumors
Apple's upcoming iPhone 17 Pro models are expected to feature a significant design overhaul, and a new image apparently taken on an assembly line for the unreleased devices appears to confirm the biggest rumored change.
iPhone 17 Pro Render Front Page Tech
Render of an iPhone 17 Pro model shared by Jon Prosser
The iPhone 17 Pro and iPhone 17 Pro Max are rumored to adopt a horizontal camera bar reminiscent of Google's Pixel series, and this bar is expected to span the width of the device's back, housing the triangular triple-camera setup on the left, and the flash, microphone, and LiDAR sensor on the right. It is not clear why Apple would use this design, nor what the extra space would be used for, but it has shown up several times now.
The image below, shared on X (Twitter) by leaker Majin Bu, purports to show CNC-machined aluminum or titanium chassis components for the iPhone 17 Pro Max that mirror these expected changes, while the large circular openings likely correspond to areas for internal components like the MagSafe coil or battery. The stacked-together parts look precision-milled with visible CNC tool paths, suggesting they are freshly machined structural elements ready for further processing.
There have been reports that Apple may revert to using aluminum frames for the iPhone 17 Pro, moving away from the titanium used in the previous iPhone 15 Pro and iPhone 16 Pro models.
Rumors suggest Apple plans to use a half glass, half aluminum build, which would increase durability. The glass would allow wireless charging to continue to be available, but a partial aluminum frame would be less prone to breakage.
There is said to be a glass section around the Apple logo that's integrated into an overall metal chassis, so the circular openings in the image could also be related to this change. Then again, the openings could be associated with a new wireless reverse charging feature.
Apple has apparently tested a 7.5W reverse wireless charging for the iPhone 17 Pro, which would allow the iPhone to provide wireless power to other Apple devices like AirPods and Apple Watch. Current iPhones are able to provide 4.5W of power to the Apple Watch and AirPods over USB-C, but there is no option for reverse wireless charging.
According to one rumor, the body thickness of the iPhone 17 Pro Max will increase to 8.725mm, up from the 8.25mm of the iPhone 16 Pro Max, which may be to fit a bigger battery.
iphone 17 pro cad majin bu
Another CAD image shared by Majin Bu
The camera module redesign extends to the new iPhone 17 Air model, which is set to replace the Plus variant in Apple's lineup. This thinner device will allegedly feature a similar horizontal camera bar design, though it will accommodate just a single camera lens.
In contrast, the base iPhone 17 is expected to maintain the current camera design language seen in the iPhone 16 series, helping to further differentiate Apple's premium and standard offerings. Apple is expected to unveil the iPhone 17 series next September. Are you excited by the expected design changes? Let us know in the comments.
Related Roundup: iPhone 17 Pro
Popular Stories
iOS 18 Siri Personal Context
Report Reveals Internal Chaos Behind Apple's Siri Failure
Thursday April 10, 2025 7:15 am PDT by
A new report from The Information today reveals much of the internal turmoil behind Apple Intelligence's revamped version of Siri. Apple apparently weighed up multiple options for the backend of Apple Intelligence. One initial idea was to build both small and large language models, dubbed "Mini Mouse" and "Mighty Mouse," to run locally on iPhones and in the cloud, respectively. Siri's...
M6 MacBook Pro Feature 1
Apple 2025 Thumb 1
Alleged iOS 19 Icons Front Page Tech
iOS 19 Leak Reveals Alleged New Design With Rounder App Icons, Floating Tab Bar, and More
Monday April 7, 2025 3:13 pm PDT by
YouTube channel Front Page Tech is back today with another video that provides a closer look at iOS 19's alleged design changes. The video contains re-created renders of iOS 19, which are allegedly based on real footage of the software update, provided by sources within Apple. Overall, iOS 19 is expected to have a more glass-like, visionOS-inspired design, with added translucency for user...
Apple Northbrook
Apple Store in Chicago Area Permanently Closing Later This Month
Wednesday April 9, 2025 9:56 am PDT by
Apple will be permanently closing its store at the Northbrook Court shopping mall in the Chicago suburb of Northbrook on April 26, the company has announced. Apple has added the following notice to the store's web page:Thank you Northbook. Apple Northbrook is closing on April 26 at 7pm. We're still here for you. Please visit apple.com/retail to find your nearest store.Apple Northbrook opened ...
iOS 18
iOS 18.4.1 Update Coming Soon for iPhones
Wednesday April 9, 2025 8:56 am PDT by
Apple employees are testing iOS 18.4.1 for iPhones, according to the MacRumors visitor logs, which have been a reliable indicator of upcoming iOS versions. The software update will likely be released in a week or two, if not sooner. As the version number implies, iOS 18.4.1 will obviously be a minor update that addresses software bugs and/or security vulnerabilities. There are no...
iOS 18
iOS 18.5 Includes Two Changes So Far
Wednesday April 9, 2025 9:09 am PDT by
Apple released the first beta of iOS 18.5 last week, and so far the software update includes only two minor changes. The changes are in the Mail and Settings apps. In the Mail app, you can now easily turn off contact photos directly within the app, by tapping on the circle with three dots in the top-right corner. In the Settings app, there is some new AppleCare+ information. For ...
iPhone 17 Pro's New Rear Camera Bar 'Same Color As Rest of Device'
Monday April 7, 2025 2:09 am PDT by
Apple's upcoming iPhone 17 Pro models will feature a redesigned rear camera panel that spans the width of the device, but it will be the same color as the iPhone itself, rather than being part of a two-tone design. That's according to Bloomberg's Mark Gurman. Writing in his latest Power On newsletter, the reporter says the iPhone 17 Pro won't have a two-toned back, as some renders have...
5 Biggest Changes Rumored for iPhone 17 Pro
Tuesday April 8, 2025 2:38 am PDT by
Later this year, Apple will introduce the iPhone 17 series, which includes the iPhone 17 Pro and the iPhone 17 Pro Max, two new high-end flagship devices that will be sold alongside the regular iPhone 17 and an all-new ultra-thin iPhone 17 Air. If you have been holding out for the iPhone 17 Pro or its bigger sibling, here are five of the biggest changes, informed by the latest reports and...
Top Rated Comments
Veinticinco Avatar
4 weeks ago
Never forget…
Score: 20 Votes (Like | Disagree)
titanium69 Avatar
4 weeks ago
Ugly Products, Buggy Software & High Prices
Are we in the timeline where Tim Apple is a samsung double agent?
Score: 19 Votes (Like | Disagree)
User 6502 Avatar
4 weeks ago
Sadly the rumours about this seem to be true. Apple nowadays seem to be truly committed on designing ugly products.
Score: 15 Votes (Like | Disagree)
YourBoss Avatar
4 weeks ago
Never forget…
But Apple didn't put that in. Apple was forced to put that in.
Score: 12 Votes (Like | Disagree)
Unggoy Murderer Avatar
4 weeks ago
I'm still really surprised that this design is somehow actually going to happen.
Also, just a reminder that Jon Prosser is a duplicitous grub who has a track record of not paying people who work / contract for him. He's been due people money for concepts and renders for literally years.
[MEDIA=twitter]1899302377137782963[/MEDIA]
Score: 11 Votes (Like | Disagree)
Ctrlos Avatar
4 weeks ago
Those metal plates look at least an inch thick in some places which makes me think they are perhaps casting parts for a glass back rather than the actual phone chassis.
