Apple Vision Pro Battery Isn't Hot-Swappable, Switching Requires Restart
The Apple Vision Pro headset comes with an external battery pack with a capacity of 3,166 mAh, compared to the 3,274 mAh battery found in the iPhone 15 Pro, although the voltages are different so the measurement alone can't be considered equivalent. Reviewers have also reported that there are significant size and weight differences between the two.
vision pro battery pack
According to Daring Fireball's John Gruber, the Vision Pro battery is about the width and height of an iPhone 15 Pro, but thicker. Weight-wise, it is also heavier: About 325g, compared to 187g for an iPhone 15 Pro. "It's closer in thickness and weight to two iPhone 15's than it is to one," according to Gruber.
Marques Brownlee in his unboxing video also described the battery as "pretty heavy," and compared it to phones with larger capacity 5,000+ mAh batteries that feel "much lighter." We'll probably have to wait for a teardown to find out what the additional weight can be attributed to.
The external battery pack that comes with the Vision Pro is silver, has a proprietary connector for attaching to the headset, and a USB-C port for charging via the included 30W wall charger. The proprietary connector is connected to the Vision Pro by rotating it a quarter turn to lock it into place.
For those considering buying an additional $200 battery pack, one thing to bear in mind is that Vision Pro batteries are not hot-swappable: As Gruber notes, there is no built-in reserve battery in the headset, so when the power cable is disconnected, Vision Pro immediately powers off. A manual reboot is therefore required to switch batteries.
Apple says the Vision Pro provides up to two hours of battery life overall, and up to 2.5 hours for 2D video playback specifically. However, several reviewers claim to have gotten up to three hours out of a single charge in general use, with one reviewer saying they were able to watch a three-hour movie on a single charge.
In terms of battery life, it doesn't make sense to compare the Vision Pro to the iPhone 15 Pro, given that the former undoubtedly draws a lot more juice to power an array of much more sophisticated cameras, sensors, displays, speakers, and microphones.
Apple Vision Pro launches in the U.S. on Friday, February 2. Apple has said the Vision Pro will launch in additional countries later this year.
Article updated to remove phrasing that implied mAh measurement alone is equivalent without an indication of voltage. Apologies for the error.
Related Roundup: Apple Vision Pro
Buyer's Guide: Vision Pro (Neutral)
Related Forum: Apple Vision Pro
Popular Stories
Apple 2025 Thumb 1
iPad Pro iPadOS
M6 MacBook Pro Feature 1
maxresdefault
top stories 2025 04 12
Top Stories: iOS 19 and iPhone 17 Pro Rumors, Siri Revamp Turmoil, and More
Saturday April 12, 2025 6:00 am PDT by
It was a big week for leaks and rumors in the Apple world, with fresh claims about iOS 19, the iPhone 17 Pro, and even the 20th anniversary iPhone coming a couple of years from now. Sources also spilled the tea on the inner turmoil at Apple around the Apple Intelligence-driven Siri revamp that has seen significant delays, so read on below for all the details on these stories and more! iOS ...
iPhone 16e Feature
iPhones, Macs, and Other Apple Devices Exempted From Trump Tariffs
Saturday April 12, 2025 9:44 am PDT by
Apple and other electronics manufacturers have received a break from Trump's reciprocal tariffs, with the U.S. Customs and Border Protection agency sharing a long list of products excluded from the levies last night. iPhones, Macs, iPads, Apple Watch, and other Apple devices will not be subject to the 125 percent tariffs that have been put in place on imported Chinese goods, nor will Apple...
Top Rated Comments
Apple_Robert Avatar
16 months ago
Up to 2hrs battery for a $3500 product is terrible, in my opinion.
Score: 46 Votes (Like | Disagree)
Muero Avatar
16 months ago
This article is awful. Watt hours (Wh) is a more accurate and consistent way to compare the total amount of energy that similar types of batteries can store. The iPhone 15 Pro's battery is 12.7Wh, while the Vision Pro's battery is 35.9Wh. This article's headline is a lie.
Score: 45 Votes (Like | Disagree)
Rudy69 Avatar
16 months ago
You guys posted a tweet with all the information basically saying this whole article is wrong…. Hilarious
The battery outputs 13v not the same as the iPhone. The battery is much bigger than the iPhone’s battery
Score: 33 Votes (Like | Disagree)
pacificblue Avatar
16 months ago
Jesus Christ what an incompetent article. You don’t compare mAh if the voltage isn’t the same. Embarrassing.
a m u n Avatar
16 months ago
Say you don’t understand voltage without actually saying it.
Score: 30 Votes (Like | Disagree)
iMacDragon Avatar
16 months ago
More like 3-4x iPhone battery. You don't compare mah you compare wh
Score: 29 Votes (Like | Disagree)
