Camera Comparison: Samsung S24 Ultra vs iPhone 15 Pro Max
Samsung came out with its 2024 flagship smartphone lineup in January, with the new devices competing directly with the iPhone 15, ‌iPhone 15‌ Plus, ‌iPhone 15‌ Pro, and ‌iPhone 15‌ Pro Max. Samsung's high-end S24 Ultra adopts some Apple-like features like a titanium chassis and a 5X zoom lens, but it also has standout additions that set it apart. We have an S24 Ultra, and thought we'd see how one main feature compares to the ‌iPhone 15‌ Pro Max -- the camera.
The Galaxy S24 Ultra has a 200-megapixel wide-angle camera (Apple's Wide lens is 50 megapixels), a 12-megapixel ultra wide camera (equal to Apple's), a 10-megapixel 3x telephoto lens, and a 50-megapixel 5x telephoto lens (Apple has a single 12-megapixel Telephoto lens). A higher pixel count equates to a higher resolution for printing and cropping in, but it doesn't necessarily make for better images because the size of the sensor is more important.
samsung galaxy 24 1x Keybank
In the sample images, you'll see that there's not too much of a difference between the ‌iPhone 15‌ Pro Max and the S24 Ultra. The S24 Ultra is a little bit more saturated and the highlights are brightened, so the S24 images can look brighter in straight from the camera comparisons. The iPhone images tend to be sharper for the most part, but Samsung's algorithm works well for night mode images.
samsung galaxy 24 25x keybank s24
Samsung primarily focused on AI this year, so the S24 Ultra camera is almost identical to the S23 Ultra camera, but the telephoto lens is a major difference. Samsung ditched its 10x telephoto lens and opted instead for a 5x telephoto lens that more closely matches the 5x telephoto lens on the ‌iPhone‌. Telephoto images are close to the same, but in Portrait mode, Samsung's photos come out crisper.
samsung galaxy s24 street
There are two telephoto lenses in Samsung's smartphone, so it supports up to 10x optical zoom, and Samsung has long had the edge when it comes to digital zoom. The S24 Ultra can zoom in up to 100x, and while the ‌iPhone‌'s digital zoom is good, it's not able to zoom in to that level.
samsung galaxy 24 portrait 1x
On the topic of AI, Samsung added some AI-supported features for post processing. You can use generative fill to remove objects from images and change the crop, cut down on noise with remastering, add slow motion to any video, and record with both the front and rear-facing cameras at the same time. We may see camera-related AI additions on the iPhone 16 models or in iOS 18, but for now, Samsung has the edge when it comes to fun AI-based tools.
samsung galaxy 24 rock hall low light
No smartphone is able to measure up to the ‌iPhone‌ when it comes to video quality because of its stabilization and resolution, but the Galaxy S24 Ultra is the closest competitor, and it has an edge when it comes to microphone quality. The S24 Ultra's microphone has great noise isolation and clarity, and the Cinematic mode looks nice, though Samsung's Cinematic mode overdoes it on the blur. 4K video is supported at 30 and 60fps, but not 24fps, which is problematic for those who want to shoot high-quality 24fps video. On ‌iPhone‌, there is a setting for recording 4K video at 24fps.
samsung galaxy 24 sign 5x portrait low light
As smartphone cameras get better and better, it gets more difficult to distinguish which smartphone takes superior images. Both the ‌iPhone 15‌ Pro Max and the Galaxy Ultra S24 take excellent quality pictures, and it's impossible to pick an overall winner. We think these cameras are about on par.
samsung galaxy 24 uw keybank
Samsung and Apple are using different algorithms and processing for image capture and to make pictures look sharper in lower light, so you'll see some differences in brightness, white balance, saturation, and similar parameters, and "better" becomes a matter of preference.
Which images do you prefer? Let us know in the comments below.
Popular Stories
Alleged iOS 19 Icons Front Page Tech
iOS 19 Leak Reveals Alleged New Design With Rounder App Icons, Floating Tab Bar, and More
Monday April 7, 2025 3:13 pm PDT by
YouTube channel Front Page Tech is back today with another video that provides a closer look at iOS 19's alleged design changes. The video contains re-created renders of iOS 19, which are allegedly based on real footage of the software update, provided by sources within Apple. Overall, iOS 19 is expected to have a more glass-like, visionOS-inspired design, with added translucency for user...
iPhone 17 Pro's New Rear Camera Bar 'Same Color As Rest of Device'
Monday April 7, 2025 2:09 am PDT by
Apple's upcoming iPhone 17 Pro models will feature a redesigned rear camera panel that spans the width of the device, but it will be the same color as the iPhone itself, rather than being part of a two-tone design. That's according to Bloomberg's Mark Gurman. Writing in his latest Power On newsletter, the reporter says the iPhone 17 Pro won't have a two-toned back, as some renders have...
iphone x front back
Apple Planning 'Bold' New 20th Anniversary Design for 2027 iPhone Pro
Monday April 7, 2025 2:46 am PDT by
Apple is preparing a "major shake-up" for the iPhone's 20th anniversary in 2027, according to Bloomberg's Mark Gurman. iPhone X released in 2017 for 10th anniversary Writing in his latest Power On newsletter, Gurman says that Apple plans to launch a foldable iPhone alongside a "bold" new iPhone Pro model that makes more extensive use of glass. Could this mean Apple plans to realize former...
iOS 18 Siri Personal Context
Report Reveals Internal Chaos Behind Apple's Siri Failure
Thursday April 10, 2025 7:15 am PDT by
A new report from The Information today reveals much of the internal turmoil behind Apple Intelligence's revamped version of Siri. Apple apparently weighed up multiple options for the backend of Apple Intelligence. One initial idea was to build both small and large language models, dubbed "Mini Mouse" and "Mighty Mouse," to run locally on iPhones and in the cloud, respectively. Siri's...
iPhone Assembly
Trump Believes Apple Could Manufacture iPhones in the U.S.
Tuesday April 8, 2025 12:08 pm PDT by
U.S. President Donald Trump "absolutely" believes that Apple could manufacture its iPhones and other devices in the United States, Press Secretary Karoline Leavitt said today during a media briefing. Leavitt was asked whether Trump thought that iPhone manufacturing is the kind of technology that could move to the U.S. "Absolutely, he believes we have the labor, we have the workforce, we have ...
5 Biggest Changes Rumored for iPhone 17 Pro
Tuesday April 8, 2025 2:38 am PDT by
Later this year, Apple will introduce the iPhone 17 series, which includes the iPhone 17 Pro and the iPhone 17 Pro Max, two new high-end flagship devices that will be sold alongside the regular iPhone 17 and an all-new ultra-thin iPhone 17 Air. If you have been holding out for the iPhone 17 Pro or its bigger sibling, here are five of the biggest changes, informed by the latest reports and...
iphone 16 pro colors 1
Is Now the Time to Upgrade Apple Devices Before Tariffs Lead to Price Increases?
Friday April 4, 2025 3:41 pm PDT by
If you have an older Apple device that you've been considering upgrading, you're probably wondering how the newly announced tariffs might impact prices going forward, and whether it's worth buying now before there's a price hike. Given analyst and economist responses to the tariffs, market panic, and Trump's stance on the current financial chaos, the answer is that making a purchase...
iPhone 17 Pro Models Rumored to Offer Dual Video Recording Feature in Camera App
Tuesday April 8, 2025 7:23 am PDT by
YouTube channel Front Page Tech on Monday shared renders of iOS 19's alleged new design. The end of the video also revealed a new feature that is supposedly planned for the iPhone 17 Pro models later this year: dual video recording. According to Front Page Tech host Jon Prosser, the iPhone 17 Pro and iPhone 17 Pro Max will allow users to record video with the front and rear cameras...
Apple Vision Pro 2 Feature 2
Vision Pro 2 May Now Be in Production Ahead of Launch Later This Year
Tuesday April 8, 2025 9:13 am PDT by
The second-generation Apple Vision Pro may now be in mass production ahead of its rumored launch later this year, Chinese website IT Home today claims. Reporting on information from an unknown source, the website says that key components of the new Vision Pro, including panels, housings, and circuitry, have moved into mass production ahead of the product's purported release later in 2025....
Top Rated Comments
Motawa Avatar
16 months ago
These little tiny images are perfect to compare it. Oh and thanks for the frame
Score: 43 Votes (Like | Disagree)
coffeemilktea Avatar
16 months ago
I feel like I'm comparing Coke and Pepsi at this point. o_O
Score: 14 Votes (Like | Disagree)
fel10 Avatar
16 months ago
Galaxy looks better. Take the fanboy glasses off, and you can also see it.
Score: 13 Votes (Like | Disagree)
icanhazmac Avatar
16 months ago
When can we stop referring to these devices as phones and start calling them, more accurately, cameras capable of making and receiving calls. iCamera15 Pro is a far more logical name. Camera features seem to be the lion's share of upgrades from year to year besides the processor.
How long till the back of the iCamera has 10 lenses?
ghostface147 Avatar
16 months ago
They both are strong in some, less in others. Can’t go wrong with either choice. It’s a preference of OS at this point.
7thson Avatar
16 months ago
The photos of the woman are a stark contrast. They almost don’t look like the same woman but I’ll chalk that up the hair part making the face look longer in the iPhone pic. The left/iPhone has better color and the right/Samsung looks washed out.
I’m sure either phone will take excellent photos for the vast majority of people, so it’ll come down operating system presences most likely.
