M2 MacBook Air Gets Speed Boost With This Novel Cooling System
Apple's 15-inch MacBook Air doesn't have a fan, and instead uses a passive heat spreader to conduct heat away from Apple's energy efficient M2 chip. Curious to know if performance could be further improved with an active cooling solution, Frore Systems installed its own novel solid-state active cooling system into the laptop and subjected it to several benchmarks, with some impressive results.
15inch macbook air purple
Frore Systems is a startup with $116 million in funding, and its flagship product is the AirJet Mini, a virtually silent thermal solution with a piezoelectric cooling chip that its makers claim performs better than fans. Inside the AirJet are tiny membranes that vibrate at ultrasonic frequencies, pulling air into inlet vents at the top of the AirJet that exits through the bottom as high-velocity pulsating jets.
As shared by The Verge, head-to-head benchmarking tests initially showed the 15-inch ‌MacBook Air‌ with the AirJet Mini installed performed only slightly better than a standard ‌MacBook Air‌, but the modified laptop pulled ahead significantly as the tests wore on and the fanless ‌MacBook Air‌'s throttling kicked in to keep the temperature down.
airjet mini frore difference
Despite its slight dimensions, the 2.8mm thick AirJet took some work to install into the ‌MacBook Air‌'s slim chassis. Frore had to mill 0.3mm off from the laptop's lid to create adequate space for the airflow system, and also removed the speakers, Wi-Fi antenna, and internal keyboard connector in the process. For the rest of us, buying a MacBook Pro with a fan is definitely an easier option.
airjet cooling macbook air
Another issue that wasn't addressed in the tests was the real-world impact of such a system on battery life. The Verge says the AirJet Mini drew five watts from the ‌MacBook Air‌'s USB-C port in the makeshift setup. Frore says its AirJet Mini chips require one watt of power when properly integrated into a laptop, and the system draws as little as 0.1W or 0.2W when idle, with the AirJet Minis themselves staying turned off until or unless they need to blow.
The AirJet system will debut in a $499 barebones Zotac mini-PC that requires constant connection to a power source, a use case in which battery life won't be an issue. But the startup has also prototyped 4K webcams, doorbell cameras, LED light bulbs, and more. It's too early to tell whether Frore's cooling system will be the next big thing in PC cooling tech, but the startup says the AirJet Mini is already in mass production, with larger and smaller versions in development.
Related Roundup: MacBook Air
Related Forum: MacBook Air
Popular Stories
Apple 2025 Thumb 1
iOS 18 Siri Personal Context
Report Reveals Internal Chaos Behind Apple's Siri Failure
Thursday April 10, 2025 7:15 am PDT by
A new report from The Information today reveals much of the internal turmoil behind Apple Intelligence's revamped version of Siri. Apple apparently weighed up multiple options for the backend of Apple Intelligence. One initial idea was to build both small and large language models, dubbed "Mini Mouse" and "Mighty Mouse," to run locally on iPhones and in the cloud, respectively. Siri's...
M6 MacBook Pro Feature 1
maxresdefault
iPad Pro iPadOS
apple intelligence black
NYT: Apple's AI Struggles Began with 2023 Chip Budget Dispute
Friday April 11, 2025 4:33 am PDT by
Apple's current struggles with Apple Intelligence and Siri began in early 2023 when AI head John Giannandrea sought approval from CEO Tim Cook to purchase more AI chips for development, according to a new report from The New York Times. Cook initially approved doubling the team's chip budget, but CFO Luca Maestri reportedly reduced the increase to less than half that amount, and instead...
Top Rated Comments
Pressure Avatar
18 months ago
5% difference in the end.
Apple absolutely made the right choice.
This is just Frore Systems salivating at the thought of being bought out by Apple.
Score: 17 Votes (Like | Disagree)
iBluetooth Avatar
18 months ago
This reads like an Ad. Who would pick the Air for long running extensive workloads? I use it for programming and the compilation is short enough to not hit a thermal limit.
Score: 13 Votes (Like | Disagree)
darngooddesign Avatar
18 months ago
How is this an ad? "Hey Apple, this basic optimization in your hardware design would make your laptop much better."
The only reason they don't properly cool the Air's is because that would harm the value of the Pro.
Meh, if you need a laptop with a fan, buy a MacBook Pro. If you want the thinnest and lightest Mac laptop, buy a MacBook Air. Heck, you can even get the base MBP for only $200 more than the equivalent Air And that thing comes with more than $200 in upgrades.
erikkfi Avatar
18 months ago
This seems like a public tech demo that the company has rolled out to news and social media channels to try and get some publicity, and it worked! I'm sure they'll attract a manufacturer. It's unlikely to be Apple, but watch this space for a Samsung laptop (or phone) with an "AirJet" installed ;)
No, in order for Samsung to use it, Apple would have to use it first. Then Samsung would run ads making fun of them. Then they’d use it.
MacBuddyz Avatar
18 months ago
Lol, removing 15W of heat and using 3W of power (twice the MBA idle power consumption), while fan can remove three times more heat while using one third to half the power.
Everyone upvoting this has to go back to school. There's a reason no one bought their tech.
polyphenol Avatar
18 months ago
Is the ultrasound at frequencies which affect animals - such as dogs?
(Very expensive as a dog repellent!)
