Images purporting to depict a new battery designed for the iPhone 16 Pro today leaked online, showing a new metal casing and a slightly larger capacity.
The images come from the leaker known as "Kosutami," who has disseminated accurate information about Apple's plans in the past. If authentic, the images are the first to be shared of the iPhone 16's components.
The battery is said to be designed for an early stage iPhone 16 Pro prototype with a 3,355 mAh capacity. The iPhone 15 Pro contains a 3,274 mAh battery, meaning that prototype iPhone 16 Pro models currently feature a battery that is just 2.5% larger. The new battery also features a redesigned connector.
Battery of early stage iPhone 16 Pro Proto Features glossy metal shell, 3355mAh Capacity(13.02Wh), LCV 4.48V(Limited Charge Voltage) Current stage prototype has changed some design: from glossy surface to frosted metal shell, and with a redesigned connector#Apple#appleinternalpic.twitter.com/QvguZ7CrtL
— Kosutami (@KosutamiSan) November 20, 2023
The most significant change is the transition from a black foil casing, the likes of which have been used on every iPhone model thus far, to a frosted metal shell. This change improves the thermal efficiency of the battery, with no significant impact on the component's weight. The Apple Watch used to feature batteries with black foil casing, but starting with the 40mm Apple Watch Series 7, Apple began adopting metal shells for improved thermals.
The new and old Apple Watch battery designs (via iFixit).
The early component images appear to confirm information shared last week that said Apple plans to introduce a new thermal system on the iPhone 16 to reduce overheating. In addition to batteries with metal shells on the iPhone 16 Pro models, the entire iPhone 16 lineup is rumored to feature a graphene heat-sink to reduce overheating. Graphene has high thermal conductivity, surpassing that of copper, which is currently used in iPhone heat-sinks. Apple has been interested in graphene for thermal management for some time, filing patents related to its exploration of the material for heat dissipation in portable devices.
The moves appear to come partly in response to widely encountered overheating issues experienced with the iPhone 15 Pro, which Apple ostensibly addressed through a software update earlier this year.
While the iPhone 17 Pro and iPhone 17 Pro Max are not expected to launch until September, there are already plenty of rumors about the devices.
Below, we recap key changes rumored for the iPhone 17 Pro models as of April 2025:
Aluminum frame: iPhone 17 Pro models are rumored to have an aluminum frame, whereas the iPhone 15 Pro and iPhone 16 Pro models have a titanium frame, and the iPhone ...
Apple may have updated several iPads and Macs late last year and early this year, but there are still multiple new devices that we're looking forward to seeing in 2025. Most will come in September or October, but there could be a few surprises before then.
We've rounded up a list of everything that we're still waiting to see from Apple in 2025.
iPhone 17, 17 Air, and 17 Pro - We get...
A new report from The Information today reveals much of the internal turmoil behind Apple Intelligence's revamped version of Siri.
Apple apparently weighed up multiple options for the backend of Apple Intelligence. One initial idea was to build both small and large language models, dubbed "Mini Mouse" and "Mighty Mouse," to run locally on iPhones and in the cloud, respectively. Siri's...
Thursday April 10, 2025 4:19 am PDT by Tim Hardwick
Apple in October 2024 overhauled its 14-inch and 16-inch MacBook Pro models, adding M4, M4 Pro, and M4 Max chips, Thunderbolt 5 ports on higher-end models, display changes, and more. That's quite a lot of updates in one go, but if you think this means a further major refresh for the MacBook Pro is now several years away, think again.
Bloomberg's Mark Gurman has said he expects only a small...
On this week's episode of The MacRumors Show, we catch up on the latest iOS 19 and watchOS 12 rumors, upcoming devices, and more.
Subscribe to The MacRumors Show YouTube channel for more videos
Detailed new renders from leaker Jon Prosser claim to provide the best look yet at the complete redesign rumored to arrive in iOS 19, showing more rounded elements, lighting effects, translucency, and...
A common complaint about the iPad Pro is that the iPadOS software platform fails to fully take advantage of the device's powerful hardware.
That could soon change.
Bloomberg's Mark Gurman today said that iPadOS 19 will be "more like macOS."
Gurman said that iPadOS 19 will be "more like a Mac" in three ways:Improved productivity
Improved multitasking
Improved app window management...
Apple's current struggles with Apple Intelligence and Siri began in early 2023 when AI head John Giannandrea sought approval from CEO Tim Cook to purchase more AI chips for development, according to a new report from The New York Times.
Cook initially approved doubling the team's chip budget, but CFO Luca Maestri reportedly reduced the increase to less than half that amount, and instead...
It was a big week for leaks and rumors in the Apple world, with fresh claims about iOS 19, the iPhone 17 Pro, and even the 20th anniversary iPhone coming a couple of years from now.
Sources also spilled the tea on the inner turmoil at Apple around the Apple Intelligence-driven Siri revamp that has seen significant delays, so read on below for all the details on these stories and more!
iOS ...
Chinese company Anker is one of many companies that will be raising prices due to the tariffs put in place by U.S. President Donald Trump, and prices are already starting to go up on Amazon.
As noted by Reuters, Anker has increased pricing on about a fifth of its products since Thursday of last week. Prices are up approximately 18 percent, and there is a possibility for further increases. A...
Sounds like a minor improvement at best, while searching for better battery tech, such as graphene or solid state.
BUT: Can you believe anything you read on X these days? It's a cesspool of lies, disinformation and the lowest forms of human behavior, all of it heartily endorsed by its owner.
What kind of nonsense is this. Did Elon musk post this rumor or did he hack this account which had been there before he took over . What a stupid comment. Also I am pretty sure the same people i follow did not become a bunch of liars because of the person that owns it. Maybe you should follow better people
I don't follow anyone on X. I've never had an X account, and never will. Your angry response just confirms my belief that X is only populated with angry extremists, who will brook no dissenting opinions.
So you never had an account, followed one single person or anything on there and never posted but you can think you can make a judgement about a platform you never used. And somehow I am an angry extremist because I accurately called your post nonsense.
‘Can’t wait for this’, ‘can’t wait for that’; it won’t do anything differently from current models. The watch 8 didn’t significantly improve battery life over the 7 moving to metallic battery casing. So, I definitely don’t believe there’s going to be anything radically different from what we have now, despite all the technical, environmental and ‘ethical’, mambo-jambo Apple would try to throw at us.
If anything they’d charge more. That, I’m sure! They took away leather cases and brought sh*tty woven nonsense - which costs more - that you use and discard the next day.
