How Apple Watch Series 8's Body Temperature Feature Is Expected to Work
Body temperature sensing technology is believed to be the headline upgrade offered by the Apple Watch Series 8 when it debuts at Apple's "Far out" event next week. Thanks to a variety of reports from reliable sources, we have a fairly good idea of how the body temperature health features are expected to work.
series6ledsThe Apple Watch Series 6's rear sensor array that introduced blood-oxygen sensing.
Body temperature monitoring for the Apple Watch has long been rumored by sources like Apple analyst Ming-Chi Kuo, but over the past year rumors have crystalized around the feature finally debuting on the Apple Watch Series 8 later this year. Contrary to the hopes of some observers hoping to be able to check their body temperature or get notifications if they have a fever, it looks like the feature may be significantly more limited at launch.
Reports from the Wall Street Journal and Bloomberg's Mark Gurman state that the body temperature sensor is primarily designed to aid fertility planning, giving women insights into their ovulation cycle, and could be used to improve the detection of patterns when tracking sleep. Apple significantly bolstered the Apple Watch's sleep tracking capabilities in watchOS 9, so further improvements in this area aided by hardware this year seem plausible.
Apple Watch Body Temperature FinishedMacRumors Apple Watch concept depicting exact body temperature reading capabilities, a feature that is unlikely to be present on the Apple Watch Series 8.
Apple is also said to have plans to enable the body temperature sensor to detect when a user has a fever, but it seems unlikely that this feature will be available upon the launch of the Apple Watch Series 8. Gurman believes that further in the future, Apple Watch models could determine if a user has a higher than normal body temperature, but it is still unlikely to show an exact measurement. All in all, this suggests that the body temperature sensor that comes with the Apple Watch Series 8 may not be quite what some users have come to expect.
According to Kuo, Apple originally intended to offer a body temperature measurement feature with the ‌Apple Watch Series 7‌ models, but the company shelved the plans when the body temperature algorithm it had developed failed to meet requirements before the device entered the engineering validation testing (EVT) phase last year.
The problems Apple has experienced relating to body temperature measurement purportedly relate to the fact that skin temperature quickly varies based on the environment, and since a smartwatch cannot monitor core body temperature using hardware, the feature is heavily dependent on an algorithm that produces accurate results. This likely explains why the body temperature sensing capabilities of the Apple Watch may be limited when the Series 8 launches later this year.
Last month, the United States Patent and Trademark Office granted Apple a patent for a temperature sensing system conspicuously related to the Apple Watch, including a "high-precision and high-accuracy absolute temperature sensor." Apple's patent protects an electronic device housing that encloses a temperature sensing system comprising a temperature sensor and a differential temperature probe.
apple watch temperature sensor patentIllustration from Apple's "Temperature gradient sensing in electronic devices" patent filing.
The system works by calculating the difference between two ends of a probe. One end touches the surface to be measured, while the other is connected to a temperature sensor. The voltage delta across the different ends of the probe can then be correlated to a differential temperature measurement.
It is not clear if the exact technology outlined in the patent is related to the body temperature sensor that is expected to be used in the Apple Watch Series 8. It is also possible that Apple plans to use a proprietary system from Rockley Photonics, a British health technology startup that has created a sensor system designed for wearable devices that includes a core body temperature sensor.
RPS Wristband Reverse SideRockley Photonics' advanced digital sensor system.
Last year, it was revealed that Apple is the largest customer of Rockley Photonics. Rockley's financial filings said that Apple accounted for the majority of its revenue over the last two years and that it has an ongoing "supply and development agreement" with the company, under which it expects to continue to heavily rely on Apple for most of its revenue. Rockley previously said that it expects its technology to be used in consumer smartwatches in 2022, which could align to the launch of the Apple Watch Series 8.
Beyond a body temperature sensor, the Apple Watch Series 8 is expected to feature the S8 chip and a Low Power Mode to prolong battery life. The device is highly likely to be unveiled at Apple's event on Wednesday, September 7.
Popular Stories
iPhone Top Left Hole Punch Face ID Feature Purple
iPhone 18 Pro Launching Later This Year With These 12 New Features
Thursday January 15, 2026 10:56 am PST by
While the iPhone 18 Pro and iPhone 18 Pro Max are not expected to launch for another eight months, there are already plenty of rumors about the devices. Below, we have recapped 12 features rumored for the iPhone 18 Pro models, as of January 2026: The same overall design is expected, with 6.3-inch and 6.9-inch display sizes, and a "plateau" housing three rear cameras Under-screen Face ID...
Apple MacBook Pro M4 hero
These 5 Apple Products Will Reportedly Be Upgraded With OLED Displays
Friday January 16, 2026 7:07 pm PST by
Apple plans to upgrade the iPad mini, MacBook Pro, iPad Air, iMac, and MacBook Air with OLED displays between 2026 and 2028, according to DigiTimes. Bloomberg's Mark Gurman previously reported that the iPad mini and MacBook Pro will receive an OLED display as early as this year, but he does not expect the MacBook Air to adopt the technology until 2028 at the earliest. A new iPad Air is...
iOS 27 Mock Quick
iOS 27 Will Add These 8 New Features to Your iPhone
Sunday January 18, 2026 3:51 pm PST by
iOS 27 is still many months away, but there are already plenty of rumors about new features that will be included in the software update. The first beta of iOS 27 will be released during WWDC 2026 in June, and the update should be released to all users with a compatible iPhone in September. Bloomberg's Mark Gurman said that iOS 27 will be similar to Mac OS X Snow Leopard, in the sense...
Apple Wallet ID Illinois
Apple Plans to Expand iPhone Driver's Licenses to These 7 U.S. States
Friday January 16, 2026 12:12 pm PST by
In select U.S. states, residents can add their driver's license or state ID to the Apple Wallet app on the iPhone and Apple Watch, and then use it to display proof of identity or age at select airports and businesses, and in select apps. The feature is currently available in 13 U.S. states and Puerto Rico, and it is expected to launch in at least seven more in the future. To set up the...
14 inch MacBook Pro Keyboard
MacBook Pro Buyers Now Facing Up to a Two-Month Wait Ahead of New Models
Sunday January 18, 2026 6:50 pm PST by
MacBook Pro availability is tightening on Apple's online store, with select configurations facing up to a two-month delivery timeframe in the United States. A few 14-inch and 16-inch MacBook Pro configurations with an M4 Pro chip are not facing any shipping delay, but estimated delivery dates for many configurations with an M4 Max chip range from February 6 to February 24 or even later. At...
Top Rated Comments
ian87w Avatar
44 months ago
Most accurate body temp is measured rectally, so I expect accessory dongles for the new Apple Watch.
Score: 37 Votes (Like | Disagree)
TVreporter Avatar
44 months ago
Schiller: “Can't innovate anymore, my ass!”
Score: 21 Votes (Like | Disagree)
TVreporter Avatar
44 months ago
I can see the next ad… opens with someone lying in bed sounding congested
cue a Foreigner song starts
“Well I’m hot blooded…
“Check it and see…
(Zoom into the watch) and it flashes
“I’ve got a fever of 103…”
Voiceover: Apple Watch 8… just what the doctor ordered.
Score: 11 Votes (Like | Disagree)
stevet Avatar
44 months ago
MacRumors Apple Watch concept depicting exact body temperature reading capabilities, a feature that is unlikely to be present on the ‌Apple Watch Series 8‌.
But we're going to post it anyway...
ct2k7 Avatar
44 months ago
So the primary use is limited to around half of the population at launch and potentially new headlining usage later?
From an upgrade perspective, it’s probably wiser to go with a series 7 if once doesn’t have it than an 8 at this point? What else does the Series 8 offer?
willyx Avatar
44 months ago
Sounds like a super useful feature
/s
