Skip to Content
Apple Reveals 'Scale to Fit' Setting to Prevent a Mac App's Menu Bar Items From Being Hidden Under Notch
Apple today shared a new support document that explains how users can ensure that an app's menu bar items do not appear hidden behind the notch, or the "camera housing" as Apple calls it, on the new 14-inch and 16-inch MacBook Pro models.
scale to fit notch setting macos
In the support document, Apple says users can turn on "scale to fit below built-in camera" for an app to adjust the active area of the display, ensuring that the app's menu bar items appear below the notch and are always visible.
Menu bar items appearing hidden behind the notch was demonstrated by Quinn Nelson, host of the YouTube channel Snazzy Labs.
To turn on "scale to fit below built-in camera" for an app on the new MacBook Pro models, open the Finder app and click on Applications in the sidebar. Then, right click on the desired app and select "Get Info." In the Info window that opens, check off the "scale to fit below built-in camera" box and the display will automatically adjust when the app is open.
The setting was demonstrated in a tweet by Joseph Angelo Todaro, a design advocate for Sketch.
Apple notes that developers can update their app to work better with the notch, in which case the "scale to fit below built-in camera" setting no longer appears.
Related Roundup: MacBook Pro
Buyer's Guide: MacBook Pro (Buy Now)
Related Forum: MacBook Pro
Popular Stories
Apple MacBook Pro with PROLED XDR Display family lineup feature
Apple Announces OLED MacBook Pro With Touch Display
Wednesday October 28, 2026 10:11 am PDT by
Apple today announced a new high-end MacBook Pro, which is available in 14-inch and 16-inch sizes. The new device has a PROLED XDR display that supports touch gestures, and a glowing rear Apple logo. Pricing on the MacBook Pro starts at $2,899 for the 14-inch model and $3,399 for the 16-inch model. Apple says the MacBook Pro has the "world's best display in a pro laptop." The PROLED...
Apple MacBook Pro 14 in with M6 hero
Apple Announces New 14-Inch MacBook Pro With M6 Chip
Tuesday October 27, 2026 6:01 am PDT by
Apple today announced a refreshed 14-inch MacBook Pro featuring the M6 chip, upgraded connectivity specifications, and more. The M6 chip in the MacBook Pro features a 12-core CPU with 2 super cores, 4 performance cores, and 6 efficiency cores, paired with a 12-core GPU. This is up from the M5 chip with a 10-core CPU with 4 super cores and 6 efficiency cores, paired with a 10-core GPU. M6...
World Travel Adapter Kit Feature with Charger
Apple Releases Redesigned Mac Chargers and 'World Travel Adapter Kit'
Wednesday October 28, 2026 11:29 am PDT by
Apple today began selling updated versions of its 70W Power Adapter, 140W Power Adapter, and Power Adapter Extension Cable, all with a new "AC Connector 2." The updated power adapters and extension cable are available on Apple's online store in the U.S. and many other countries around the world. Apple also released an updated version of its World Travel Adapter Kit that had disappeared...
Top Rated Comments
66 months ago
Did you notice that “scale to fit” restores the bezels of the previous generation MBP on the left and right side as well (not just the top of the screen)? This is how it maintains the aspect ratio. It is literally scaling down the whole screen
Yep. This is literally the worst possible solution.
Score: 34 Votes (Like | Disagree)
66 months ago
Lol, a terrible solution to a problem we didn't had before. Nice job.
Score: 22 Votes (Like | Disagree)
66 months ago
The video shows the entire screen shrinking at the same aspect ratio, bizarre. I would have expected the menubar to simply slide down the same number of pixels as the notch is tall, making it the same total aspect ratio as previous MBPs
This is going to be annoying for pixel critical work that designers (and artists, etc) do, as it's no longer a perfect 2x multiple PPI (for the default scale resolution, at least). Scaling the entire screen down a bit means you're no longer integer scaling the display.
Score: 21 Votes (Like | Disagree)
Superhappytree Avatar
66 months ago
When you have to have settings, dark modes and apps to appease the notch and yet you have floods of people on here defending it as “great design, well done Apple”.
It’s a massive design fail that interferes with UX and UI.
Score: 19 Votes (Like | Disagree)
66 months ago
Why not just give an option for the system to ignore the notch area, and simply put the menu bar below the notch…
Essentially maintaining the scale but just making the screen shorter?
Score: 18 Votes (Like | Disagree)
macpot Avatar
66 months ago
Notch gonna lie, that is amazing!
It makes every one happy, bezel lovers will find themself at home now.
Score: 17 Votes (Like | Disagree)
Latest Stories
AirPods Pro 3 for $149 is One of The Best Black Friday Deals This Year
21 minutes ago
1Password Security Breach: What Was Accessed and What Wasn't
2 hours ago
WhatsApp Finally Adds Scheduled Messages
3 hours ago
Get Apple's Cheapest iPad for $379 During Amazon's Black Friday Sale
3 hours ago
Rumor: iOS 28 to Revamp Notifications
3 hours ago
iPhone 18 Pro Max Battery Exhausts a Toy Cyclops in New Apple Ad
6 hours ago
$799 Smart Glasses Promise Vision Pro-Style Controls in a 45g Frame
6 hours ago
How To Get an iPhone Duo or iPhone 18 Pro at No Cost Through T-Mobile for Black Friday
7 hours ago
Apple Has an iPhone Notifications Problem
7 hours ago
Amazon Sweetens Black Friday Deals on PROLED MacBook Pro
8 hours ago
Apple Has iPads Running macOS Internally, Says Gurman
10 hours ago
Apple Is Far From Done With 2026: Here's What's Still Coming
11 hours ago
Threads App for iPad Now Available
12 hours ago
Claude Now Lets You Install Artifacts as Desktop Apps
13 hours ago
Tidal Bans AI Music, While Apple Music Sticks to Labels
23 hours ago
Add Holiday Lights and Snow to Your Mac With Festivitas
1 day ago
Meta's Muse AI Agent Comes to Instagram DMs
1 day ago
Google Says Apple's iOS Browser Rules Offer 'Choice on Paper, Not in Practice'
1 day ago
Walmart App Rolls Back Apple Pay Support After Just Weeks
1 day ago
Black Friday Discount Hits 512GB MacBook Neo at $699 ($100 Off)
1 day ago
Disney+ Black Friday Deal is Here: Bundle With Hulu for Just $4.99/Month for a Year
1 day ago
Signal Now Blocks AI Screen Access to Protect Chats
1 day ago
Things 3.25 for Mac Gains Touch Gestures
1 day ago
AirTag in (PRODUCT)RED?
1 day ago
M6 iMacs Get First Major Discounts With Up to $111 Off at Amazon
1 day ago
Apple to Celebrate 20 Years of (RED) With Special Event in New York
1 day ago
Hidden Coupon Deal Knocks M6 MacBook Pro to $1,779 on Amazon
1 day ago
Apple to Release Four (RED) Products by Next Week
1 day ago
iPhone Air 2 and iPhone 18 Rumored to Feature Thicker Cameras
1 day ago
EU in Talks With Apple Over Barriers to Rival iPhone Browsers
1 day ago
