Meross Launches Modular Smart LED Floor Lamp With HomeKit Support
Meross this week added a height adaptable LED Floor Lamp to its smart home lineup offering Apple HomeKit support.
meross smart led floor lamp lifestyle 2Note: MacRumors is an affiliate partner with Amazon. When you click a link and make a purchase, we may receive a small payment, which helps us keep the site running.
Boasting a modular three-piece design, the slim black lamp can be adjusted to a height of 54.7 inches (139cm) for placement on a floor, or 22 inches (56cm) for desk use via the included base or clamp mount.
The flexible gooseneck can be tilted and rotated 360 degrees, and though it doesn't feature color changes, the brightness, warmness and coolness of the light can be adjusted between 2700 to 6000K.
The 12-Watt lamp features a peak brightness of 650 lumens and is fully dimmable using the integrated touch panel on the lamp stem, the included remote, or via the mobile app.
meross smart led floor lamp lifestyle 6
In addition to ‌HomeKit‌, the Meross Smart LED Floor Lamp is compatible with Amazon's Alexa, Google Assistant, and the Meross app when connected to 2.4GHz Wi-Fi.
The Meross MSL610HK Smart LED Floor Lamp is available now on Amazon for $79.99, but Meross is currently offering a $25 discount that can be found on the Amazon product listing.
(Via iMore.)
Popular Stories
CarPlay Hero
Beyond iPhone 13 Better Triad
iOS 19 Roundup Feature
maxresdefault
iphone 16 pro models 1
AirPods Pro 3 Mock Feature
iOS 18
Apple Releases iOS 18.4.1 With Bug Fixes
Wednesday April 16, 2025 10:11 am PDT by
Apple today released iOS 18.4.1 and iPadOS 18.4.1, minor updates to the iOS 18 and iPadOS 18 operating systems that came out last September. iOS 18.4.1 and iPadOS 18.4.1 come two weeks after the launch of iOS 18.4 and iPadOS 18.4. The new software can be downloaded on eligible iPhones and iPads over-the-air by going to Settings > General > Software Update. There have been complaints about ...
tvOS 18 Thumb 1
Apple Releases tvOS 18.4.1
Wednesday April 16, 2025 10:04 am PDT by
Apple today released tvOS 18.4.1, a minor update to the tvOS 18 operating system that came out last September. tvOS 18.4.1 comes two weeks after Apple released tvOS 18.4, and it is available for the Apple TV 4K and Apple TV HD models. tvOS 18.4.1 can be downloaded using the Settings app on the ‌Apple TV‌. Open up Settings and go to System > Software Update to get the new software....
iPhone Security Feature 25
Five iPhone Security Features You Should Be Using
Wednesday April 16, 2025 4:15 pm PDT by
Apple has quite a few security features that it's added to iPhones, iPads, and Macs over the years. Now more than ever, it's important to make sure you're taking advantage of the built-in security tools that are available to keep yourself and your data safe, so we've rounded up a list of the most important options. If you don't already have these enabled, you might want to consider turning...
Top Rated Comments
matrix07 Avatar
49 months ago
Go up to lamp, switch it on
I don't have to do that for some time now. Automation is the word.
MTShipp Avatar
49 months ago
I won’t trust it. I have a house full or Meross switches and have an unsolvable issue where they periodically decide to reboot themselves and whatever is attached loses power for a moment. Freaks the dog with lights cycling, resets the TV and clocks if connected, etc. I love how they respond so much faster and have more range than the BT HK devices but support is unresponsive about this problem.
Mac Fly (film) Avatar
49 months ago
Looks like a dental lamp.
jhollington Avatar
49 months ago
I think some things should just stay dumb. Go up to lamp, switch it on, change the brightness or color or whatever, but having to connect it, pair it, unpair it, reboot it, firmware update it, get the app, sign in, sign out, sign back in again, forgot your password, restart your router, say a prayer... just to turn on a lamp is a bit silly.
Heh, you make that sound a lot more complicated than it is. While there's a pairing process to set up a new HomeKit accessory, once you've done that it pretty much just works.
In my case, the ability to use those lamps as part of scenes and scheduled routines is where the benefit really comes in. For example, I can know that all of my lights will be properly switched off when I leave my house, or go to bed at night, without having to patrol every room and see if I forgot to turn something off manually.
Plus, I have two bedside lamps in my bedroom that are paired with a wall switch and a motion sensor (Hue bulbs, Hue Dimmer, Hue Motion), so that I can easily turn them on and off when I enter or leave the room, rather than either needlessly turning on the ceiling light or stumbling to the other side a darkened room just to find the manual switches on each lamp.
That said, I rarely use my actual iPhone to turn things on or off — especially when I'm near them — and I've always insisted that all of my HomeKit accessories be paired with a manual option. For instance, that's why I use Lutron wall switches for my light fixtures, rather than putting in Hue bulbs. People have been turning on light switches the old fashioned way for 50+ years. Automation can be a great enhancement to that, but it's not a replacement.
twistedpixel8 Avatar
49 months ago
Why on earth is a smart lamp a thing? I really, really, don’t understand this
Me neither. All my lamps are dumb but have smart bulbs. Bulb blows: buy new bulb, not a whole new lamp.
baryon Avatar
49 months ago
What's the benefit? If you're using a lamp you're near it anyway, chances are your phone or Amazon thingy will be further than the lamp itself. It's just complexity (and cost) for the sake of it. You can get a lamp like this in IKEA for the price of lunch.
