Leaked iPhone 12 Pro Max Schematics Show Thinner Design, Smaller Bezels, LiDAR Camera, and More
YouTube channel EverythingApplePro and Max Weinbach have shared what they're claiming is a sneak peek of Apple's hitherto unreleased "iPhone 12 Pro Max," based on alleged leaked CAD designs.
The key thing about the CADs is they line up with rumors suggesting that Apple's new iPhone will take many design cues from the iPad Pro. The schematics show a squared-edged stainless steel frame between two pieces of glass, replacing the rounded stainless steel frame of the ‌iPhone‌ 11 series.
In order to house the bigger 6.7-inch OLED screen, the device will be slightly wider and taller, and the bezels have been shaved to an impressive 1.55mm, compared to 2.52mm on the 6.5-inch iPhone 11 Pro Max.
They also mirror rumors that the new ‌iPhone 12 Pro Max‌ will have a thickness of 7.4mm, which would be quite a bit thinner than the 8.1mm thick ‌iPhone 11 Pro Max‌. However, the camera bump is said to be slightly thicker, 1.26mm rather than 1.21mm, although the cameras themselves don't protrude as much.
iphone 12 pro max renders everythingapplepro
One oddity in the designs is that the size of the notch is the same as the one found on Apple's current ‌iPhone‌ lineup. Previous rumors suggest Apple has designed a smaller notch, although Weinbach claims that these details weren't finalized when the CAD was made, which is a genuine possibility.
Other key takeaways from the video:
  • Fourth camera sensor for the LiDAR Scanner.
  • Slightly increased diameter of camera lenses.
  • Thicker antenna lines on sides of handset for 5G.
  • SIM card tray relocated to other side of device.
  • Smart Connector-esque input where SIM card try used to be.
  • One less speaker hole on right side speaker grille.
  • 10 to 15 percent louder speakers.
  • Power button sits slightly lower on device.
  • New colors could include light blue, violet, and light orange.
Weinbach has accurately revealed a new ‌iPhone‌ color in the past, and has previously claimed that the ‌iPhone‌ 12 in Navy Blue could replace the Midnight Green finish available for ‌iPhone‌ 11 Pro models.
iphone 12 pro max renders everythingapplepro 2
Weinbach also accurately predicted that the volume HUD would become less obtrusive in iOS 13, but he has also shared several Apple-related rumors that did not pan out, including the iPad getting a native Calculator app in iOS 13 and the HomePod launching in Austria and Italy within 2019. Weinbach has a more established track record with Android-related rumors, but this could be set to change.
Apple is expected to offer four iPhones in three different sizes this year: A 5.4-inch ‌iPhone‌, a 6.7-inch ‌iPhone‌, and two 6.1-inch iPhones. One 6.1-inch model and the 6.7-inch model will be higher-end iPhones, while the other 6.1-inch ‌iPhone‌ and the 5.4-inch ‌iPhone‌ will be lower-end models and successors to the ‌iPhone‌ 11.
Related Forum: iPhone
Popular Stories
Apple 2025 Thumb 1
iPad Pro iPadOS
M6 MacBook Pro Feature 1
maxresdefault
top stories 2025 04 12
Top Stories: iOS 19 and iPhone 17 Pro Rumors, Siri Revamp Turmoil, and More
Saturday April 12, 2025 6:00 am PDT by
It was a big week for leaks and rumors in the Apple world, with fresh claims about iOS 19, the iPhone 17 Pro, and even the 20th anniversary iPhone coming a couple of years from now. Sources also spilled the tea on the inner turmoil at Apple around the Apple Intelligence-driven Siri revamp that has seen significant delays, so read on below for all the details on these stories and more! iOS ...
iPhone 16e Feature
iPhones, Macs, and Other Apple Devices Exempted From Trump Tariffs
Saturday April 12, 2025 9:44 am PDT by
Apple and other electronics manufacturers have received a break from Trump's reciprocal tariffs, with the U.S. Customs and Border Protection agency sharing a long list of products excluded from the levies last night. iPhones, Macs, iPads, Apple Watch, and other Apple devices will not be subject to the 125 percent tariffs that have been put in place on imported Chinese goods, nor will Apple...
Top Rated Comments
bbzzz Avatar
65 months ago
silly having a camera bump, may as well make the phone that thickness all over and have even more battery
Score: 39 Votes (Like | Disagree)
SpitUK Avatar
65 months ago
Take my money!
Although would prefer a slightly thicker phone with more battery.
Score: 31 Votes (Like | Disagree)
nickgovier Avatar
65 months ago
B4U Avatar
65 months ago
So the Arnold case will finally look movie-correct instead of missing one of the launcher?
Attachment Image
Score: 29 Votes (Like | Disagree)
profets Avatar
65 months ago
Couple screenshots from the video. Looks promising.
Attachment Image
Attachment Image
Score: 16 Votes (Like | Disagree)
itsmilo Avatar
65 months ago
I already cannot wait, the iPhone 5 design is still my favorite design when it comes to the grip. Totally a first world problem but I am also looking forward to that additional camera that I will probably never use, just to have the cameras properly aligned again. I hope i will be still able to afford it by the time it comes out lol
I also welcome that the power button is a little further down. I ALWAYS press it by mistake when i want to change the volume
Score: 14 Votes (Like | Disagree)
