Belkin Debuts First MFi-Certified Power Bank With Lightning Input
Belkin today is launching the first power bank with Lightning input to be officially certified under Apple's MFi licensing program, assuring that the product meets Apple's standards for quality and compatibility. Belkin's BOOST↑­CHARGE Power Bank 10K with Lightning Connector, priced at $59.99, offers 10,000 mAh of charging power and is recharged over a Lightning connector using either a USB-to-Lightning cable or a compatible Lightning dock sold separately.
belkin lightning 10k colors
On the output side, the Power Bank 10K with Lightning includes a pair of USB-A ports, one at 2.4A for faster charging of iPhones and iPads and one at 1A for slower charging. A button-activated set of four LEDs on the top of the Power Bank shows the current charge level, and the button also lets you toggle between charging input and output modes if needed.
belkin lightning 10k 1
While power banks most commonly use micro-USB for charging input and a few are shifting over to USB-C, Lightning offers the benefit of needing only a single cable to both charge the battery pack and use the battery pack to charge your phone. If you've got a Lightning dock on your desk, you may also be able to use that to recharge the power bank, although it is significantly thicker than an iPhone so not all docks will be able to accommodate the power bank.
belkin lightning 10k dock
Charging on an Apple Lightning dock
The Power Bank 10K measures about 6 inches long, around 2.75 inches wide, and a little under 0.75 inches thick, so it's slightly smaller but substantially thicker than a Plus-sized iPhone. It weighs a little over 8 ounces, about 25 percent more than a Plus-sized iPhone.
In my testing, the power bank worked well, efficiently charging an iPhone connected to the 2.4A USB port. It also appeared to be able to maintain rated charging speeds with devices connected to both USB ports simultaneously. Recharging the power bank took three hours or so when connected to an iPad charger.
belkin lightning 10k 2
Beyond standard power banks, the launch of the first MFi-certified Lightning battery may also bode well for future similar accessories from other manufacturers, including the possibility of iPhone battery cases with Lightning input, a product family long requested by users.
Belkin's $59.99 BOOST↑­CHARGE Power Bank 10K with Lightning Connector will be available in black or white and is available for pre-order starting today through Belkin. It should begin shipping around the beginning of August.
For peace of mind, the BOOST↑­CHARGE Power Bank 10K with Lightning Connector includes Belkin's $2500 Connected Equipment Warranty, offering protection for any equipment damaged by power spikes or surges while properly connected to the power bank.
Note: Belkin provided a sample of the Power Bank 10K with Lightning Connector to MacRumors free of charge for the coverage purposes. No other compensation was received. MacRumors is an affiliate partner with Belkin and may earn commissions on purchases made through links in this article.
Tag: Belkin
Popular Stories
Beyond iPhone 13 Better Triad
iOS 19 Roundup Feature
CarPlay Hero
iphone 16 pro models 1
Apple 2025 Thumb 1
iOS 18
Apple Releases iOS 18.4.1 With Bug Fixes
Wednesday April 16, 2025 10:11 am PDT by
Apple today released iOS 18.4.1 and iPadOS 18.4.1, minor updates to the iOS 18 and iPadOS 18 operating systems that came out last September. iOS 18.4.1 and iPadOS 18.4.1 come two weeks after the launch of iOS 18.4 and iPadOS 18.4. The new software can be downloaded on eligible iPhones and iPads over-the-air by going to Settings > General > Software Update. There have been complaints about ...
iPhone 6s MacRumors YouTube
Apple Says These Products Are Now Vintage
Tuesday April 15, 2025 9:53 am PDT by
Apple today updated its vintage products list to add the 2018 Mac mini and the iPhone 6s, devices that will get more limited service and repairs now that they are considered vintage. The iPhone 6s initially launched in 2015, but Apple kept it around as a low-cost device until 2018, which is why it is only now being added to the vintage list. The iPhone 6s had Apple's A9 chip, and it was...
macOS Sequoia Feature
Apple Releases macOS Sequoia 15.4.1 With Bug Fixes
Wednesday April 16, 2025 10:16 am PDT by
Apple today released macOS Sequoia 15.4.1, a minor update to the macOS Sequoia operating system that launched in September. macOS Sequoia 15.4.1 comes two weeks after the launch of macOS Sequoia 15.4. Mac users can download the ‌‌macOS Sequoia‌‌ update through the Software Update section of System Settings. It is available for free on all Macs able to run macOS 15. According to...
Top Rated Comments
Exile714 Avatar
89 months ago
Not an investment I would make in 2018...
USB-C can charge power banks faster, a USB-C to Lightning cable can charge a phone faster, and wireless is starting to take root with the promise of faster charging to come.
I envision a future power bank with a fast Qi charger, but if we’re stuck with Lightning we might as well take advantage of fast charging USB-C tech.
FelixDerKater Avatar
89 months ago
Just in time to be immediately obsolete.
NT1440 Avatar
89 months ago
This doesn’t charge wirelessly? What a waste. So if I want to charge my phone whenever it's in my pocket, I need a mess of cables. No thanks.
How long do you think 10,000mah would take wirelessly at 5 or 7.5w? No thank you.
That said, WHY would they do one port at 1 amp and 1 at 2 amps? WHY make it complicated?
macduke Avatar
89 months ago
The new iPhone is coming with an 18W USB-C to Lightning adaptor. Couldn't that cable be used to charge this, meaning one less cable to carry in a bag?
How so?
Just in time for Apple to kill Lightning in favor of USB-C. Also that is very overpriced for 10K and no USB-C PD output.
Apple is not killing Lightning in favor of USB-C, lol. And they likely won't until they go fully wireless for charging. Apple is using USB-C to Lightning in upcoming iPhone models. Nobody seems to understand that Apple isn't switching to USB-C in iOS devices because USB-C is nearly twice as thick as Lightning and it's a more fragile connector with the center piece that can snap off. Lightning is solid and thin and can take higher charging rates once it's supported in hardware.
Lightning has been around since the iPhone 5 and they're just now getting around to doing this? Why did they wait so long? I would've considered buying one of these three or four years ago for the sake of only having to carry one type of cable, but there's no way I'd buy one today when Lightning probably has a limited time left.
What makes you think Lightning has limited time left? True wireless charging is still several years away at a minimum. Until then we have the Lightning port.
BigMcGuire Avatar
89 months ago
I have to agree with macduke here. After having my MacBook Pro 13' 2017 - I'm not a fan of USB C. I don't think Apple is getting rid of lightning ports anytime soon.
oneMadRssn Avatar
89 months ago
Same reason every other battery charger does, so save money by using off-the-shelf parts.
The basic power control chips that 90% of all these battery packs use only supports a certain maximum output in W. Usually I see 18W max output is the limit on the battery packs of roughly 10,000mah size. So that's 3.6A total at 5V. My bet is the 1A port is actually 1.2A, as they usually are.
Putting in smart switching USB ports adds expense to the control circuit, so they just do the lazy/cheap thing and split it as 1.2A (6W) and 2.4A (12W), which are roughly the power outputs of the stock Apple chargers for iPhone and iPad (5W and 10W).
Splitting it as 9W each, making an equal 1.8A per port doesn't make much sense because it's neither here nor there. It's more power than needed to charge an iPhone at a normal speed but less power than needed to charge an iPad at the normal speed. This way, you have at least one port capable of charging an iPad.
Even good reputable companies like Anker sometimes do this. Their 20,000mah battery pack has a 12W output and an 18W output (2.4A and 3.6A).
Though honestly, for $60, Belkin shouldn't have cheaped out on the controller circuit. They should have both ports supporting 2.4A at least.
