Satechi today added to its USB-C hub lineup with the launch of the Aluminum Type-C Pro Hub with Ethernet.
Designed for 2016 and 2017 13 and 15-inch MacBook Pro models, the new Pro Hub with Ethernet comes equipped with a Gigabit Ethernet port, an HDMI port, a USB-C Power Delivery port that supports 87W of power, two type-A USB 3.0 ports, and a micro SD card slot.
satechiethernet1
Like other Satechi USB-C hubs, the Pro Hub with Ethernet comes in a brushed aluminum that's available in either silver or Space Gray to match Apple's notebooks.
satechiethernethub2
The Pro Hub with Ethernet's integrated Gigabit Ethernet port is invaluable in a situation where Wi-Fi is either unavailable or unreliable. It supports 10/100/1000Mb/s.
In addition to an Ethernet connection, the Pro Hub supports a 4K monitor through the HDMI port and the USB-C port allows for power delivery. The microSD card slot can be used for importing images and files, while the two USB 3.0 ports allow for data transfer from USB-A accessories.
satechiethernet3
Satechi's new Aluminum Type-C Pro Hub with Ethernet can be purchased today from the Satechi website or from Amazon for $99.99.
Tag: Satechi
Top Rated Comments
lilrush Avatar
91 months ago
It's sad that these are products. The simple fact there is a market for products like this demonstrates that Apple took away ports the users need.
Score: 23 Votes (Like | Disagree)
ateslik Avatar
91 months ago
God that’s an arse ugly wart. FFS just put ports back into the mother f’ing computer Johnny!!
Score: 14 Votes (Like | Disagree)
robertcoogan Avatar
91 months ago
I bought a USB Type C hub for my 2016 MBP not long ago from Amazon. It cost me almost $70, and I am still using it to this day, but I can't connect any external hard drives to it.
The problem with USB Type C isn't in the speed (it is really fast), it is with the poor quality of the hardware component. The very design of USB Type C connector and port isn't very sturdy. Even my pricey USB Type C hub wobbles in the port, causing any connected devices to disconnect, then reconnect, then disconnect, etc. This has also happened with much cheaper hubs I have bought, so price (read: quality) isn't an issue here. It only compounds the dongle hell issue that a lot of 2016 MBP owners experience.
So with Satechi's new hub (if I were to buy it), I can now expect Ethernet to disconnect, then reconnect, then disconnect, etc. I would hope that they and other hub manufacturers would design some sort of clip that would secure it more firmly to the MBP, so the wobble would hopefully go away. I really hope that USB Type C goes the way of the dodo very soon, or the connector and port are redesigned to make them more sturdy.
jameswilby Avatar
91 months ago
Soooo close to perfect... Just needed that full size SD card slot. But I'm still really tempted by this
mrzz Avatar
91 months ago
..and all these ugly and expensive hubs just because of Apple how decided to prefer design over functionality. If they don't return back a single USB3.1 to MBP 2018 it will be a fail again. Who TF needs 4xUSB-C even in 2018?? 5% of all the MBP users? Apple just totally screwed 2016&17 MBP (ports/keybord/magsafe removal/...) and extended that dongles' hell (my opinion is that they just did it on purpose to force people buy another overpriced dongles .. I doubt they didn't find a place e.g. for a single USB3.1.
dirt_farmer Avatar
91 months ago
So so so insane.
They removed the features that are necessary to the usage of the device, all in the name of "design".
Prediction: Next generation Macbook Pro has no display.
You view it via dongles and aftermarket adapters.
You read it here first!
Popular Stories
Beyond iPhone 13 Better Triad
maxresdefault
CarPlay Hero
iOS 19 Roundup Feature
iphone 16 pro models 1
AirPods Pro 3 Mock Feature
Apple 2025 Thumb 1
iOS 18
Apple Releases iOS 18.4.1 With Bug Fixes
Wednesday April 16, 2025 10:11 am PDT by
Apple today released iOS 18.4.1 and iPadOS 18.4.1, minor updates to the iOS 18 and iPadOS 18 operating systems that came out last September. iOS 18.4.1 and iPadOS 18.4.1 come two weeks after the launch of iOS 18.4 and iPadOS 18.4. The new software can be downloaded on eligible iPhones and iPads over-the-air by going to Settings > General > Software Update. There have been complaints about ...
iPhone 6s MacRumors YouTube
Apple Says These Products Are Now Vintage
Tuesday April 15, 2025 9:53 am PDT by
Apple today updated its vintage products list to add the 2018 Mac mini and the iPhone 6s, devices that will get more limited service and repairs now that they are considered vintage. The iPhone 6s initially launched in 2015, but Apple kept it around as a low-cost device until 2018, which is why it is only now being added to the vintage list. The iPhone 6s had Apple's A9 chip, and it was...
