Skip to Content
Nomad Launches New 4-Port Wireless Charging Hub With Support for Fast Charging
by
Nomad today announced the launch of its new Wireless Charging Hub, which is designed to be the ultimate desktop hub for iPhone X, iPhone 8, and iPhone 8 Plus users.
The top of the Hub is a wireless charging pad that offers up to 7.5W of wireless charging power for Apple's glass-backed iPhones, and underneath, there are four additional ports.
nomadhubdesign
Three are USB-A ports meant for charging all kinds of devices, and one is a USB-C port that offers 15W of power for fast charging the iPhone X, 8, or 8 Plus with a USB-C to Lightning cable.
Ahead of the launch of the Wireless Charging Hub, I was able to spend some hands-on time with it. The hub a bit larger than the average wireless charger, but it doesn't take up too much space on my desk. The top, where the wireless charging coil is located, is covered with a rubber material that's designed to add a bit of grip to prevent the iPhone from sliding off from vibrations and bumps.
nomadhubdesignempty
Five LEDs on the top of the hub let you know exactly what's plugged in and what's still charging. LEDs are green when charging has been completed and orange while power is still being delivered to one of your devices. There's an ambient light sensor that dims the LEDs in a dark room, which is a nice feature.
With support for 7.5W wireless charging, the hub offers the faster wireless charging speeds that were introduced with iOS 11.2, and if you need a lot of juice in a pinch, you can use the USB-C port to fast charge Apple's latest iPhones. USB-C fast charging with a USB-C to Lightning cable can charge your iPhone from 0 to 50 percent in a half an hour.
nomadhubwirelesscharging
This is a 15W USB-C port (3A x 5V), so while it's suitable for your iPhone and other USB-C smartphones or devices, it's not enough power for a MacBook or MacBook Pro. Three other 2.1A USB-A ports are included so you can charge up all of your devices and accessories at once. The hub itself is powered by an adapter that plugs into the wall.
nomadhubunderneath
One thing to note -- the Wireless Charging Hub does not come with cables and it does not feature any built-in cable hiding mechanism, which is a negative. If you're using this on a desktop, you're probably going to want to purchase smaller Lightning cables to use with it, because it was a huge mess of cables on my desk with the 1m and 0.5m Apple cables.
Nomad recommends its 0.3m Universal Cables with micro-USB, USB-C, and USB-A, but I don't think most people are going to want to pay $30 per cable. Luckily, Amazon has options for affordable shorter iPhone cables that will work well on the desktop. Unfortunately, there are no Apple certified USB-C to Lightning cables that are shorter in length, so you'll need to use the standard 0.5m cable.
nomadhubcords
When paired with the appropriate cables, the Wireless Charging Hub is a convenient desktop charging accessory. If your iPhone just needs a bit of a top up, it's easy to plunk it down on the wireless charging pad, and if you need more power in a hurry, it's great having an easily accessible USB-C fast charging port.
This isn't a cheap accessory at $80, and you're going to want to make sure you have shorter cables if you want a neat and organized desktop, which can add an additional cost, but it does offer unmatched versatility and convenience if you don't mind the price tag.
You can purchase the new Wireless Charging Hub from Nomad's website for $79.95.
Note: Nomad provided MacRumors with a Wireless Charging Hub for the purpose of this review. No other compensation was received. This post contains affiliate links and MacRumors may earn commissions on purchases made using those links.
Tag: Nomad
Top Rated Comments
116 months ago
The charger is nice, but it's the wallpaper I want. Anyone know if I can find it?
Its Broken Top mountain in Oregon US
https://www.imaiges.com/photo/broken-top-volcano-mountain-moon-66802
hrrsn Avatar
116 months ago
Found a better higher res version I found with some deep googling. - https://static.wixstatic.com/media/150e2f_b2d1418ee5e54a5a9d1f7b11c3789fda~mv2_d_4096_2730_s_4_2.jpg
Registered here to post it :)
jmgregory1 Avatar
116 months ago
I just got an email from Nomad touting how this new hub eliminates desktop cord clutter - but having 4 USB cords, plus a power cord going into/out of the hub doesn't sound to me like it's eliminating cord clutter.
Aside from that, I'm surprised that we're not seeing more stand-type inductive chargers hitting the market, as the hockey puck style certainly doesn't work for using an iPhone X, unless you're planning on being hunched over the puck when you want to use it (to look at and read notifications for example).
I've used an acrylic stand I designed back in 2011, made to hold both an iPhone and iPad side by side, with openings through the tray they sit on for the then 30pin plugs to fit in, so you could keep both devices plugged in and have them positioned so you are looking at them much like the screen of a laptop. Now with the X I have, I've simply double sided taped the Mophie charger to the stand and I now have a wireless stand that allows me to just glance at my X any time a notification pops up.
I'll likely design a new version and buy a raw charging coil to incorporate into a stand, but for now it's a great way to make using and charging my iPhone X.
Attachment Image
116 months ago
I modded the wallpaper for iPhone X. Here: https://www.dropbox.com/s/czjkh1ffme7zj86/Nomad_Wall.jpeg?dl=0
Kingofclouds Avatar
116 months ago
Why all these LED lights on these pads that are sometimes used in the bedroom?! I don’t want a light show beside my bed. Not good design
116 months ago
80 dollars?! They're crazy! :confused:o_O
Popular Stories
apple design award 2025
Apple Announces 2025 Design Award Winners Ahead of WWDC 2025
Tuesday June 3, 2025 10:14 am PDT by
As we wait for WWDC to kick off next Monday, Apple today announced the winners of its annual Apple Design Awards, recognizing apps and games for their innovation, ingenuity, and technical achievement. The 2025 Apple Design Award winners are listed below, with one app and one game selected per category: Delight and Fun - CapWords (App) and Balatro (Game) Innovation - Play (App) and PBJ -...
1password deal blue
1Password Security Breach: What Was Accessed and What Wasn't
Wednesday November 25, 2026 1:09 pm PST by
Popular password management app 1Password today said it experienced a security breach earlier this month. 1Password says some customer names and email addresses were accessed, but no customer vault contents were compromised. On November 19, 1Password saw indications that an employee's GitHub account had been breached and began investigating. The company says the breached GitHub account was...
apple store down feature
Here's Why the Apple Store is Going Down
Thursday November 26, 2026 5:49 am PST by
Apple's online store is going down for a few hours on a rolling country-by-country basis right now, but do not get your hopes up for new products. Apple takes its online store down for a few hours ahead of Black Friday every year to tease its annual gift card offer with the purchase of select products. The store is down in Australia, New Zealand, and Thailand, right now, and it will...
Latest Stories
The 50+ Best Apple Black Friday Deals Still Available on AirPods, iPads, and More
2 hours ago
Apple's M6 and PROLED MacBook Pro Reach New Low Prices for Black Friday
9 hours ago
The MacRumors Show: iPhone Air 2 and iPhone 18 Are Coming
9 hours ago
Apple Store in Brisbane Reopening Next Month With New Design
10 hours ago
The 60+ Best Black Friday Accessory Deals on iPhone Chargers, TVs, Headphones, and More
11 hours ago
GTA VI Now (Barely) Running on Apple Silicon Macs
11 hours ago
The Best Black Friday Streaming Deals on Apple TV, Disney+, and More
11 hours ago
Apple TV's 'Carême' Wins International Emmy for Best Drama
12 hours ago
iPhone 18 Production Delay Leaves Apple Little Time Before Launch
13 hours ago
The Best Black Friday AirPods Deals Still Available
5 hours ago
The Best Black Friday Deals on Apple Home Products
13 hours ago
The Best Black Friday iPhone Deals Still Available
5 hours ago
The Best Black Friday iPad Deals Still Available
5 hours ago
The Best Black Friday Apple Watch Deals Still Available
5 hours ago
The Best Black Friday AirTag Deals Still Available
5 hours ago
The Best Black Friday Mac Deals Still Available
5 hours ago
iPhone Share of US Smartphone Market Hits 57% as Rivals Slip
15 hours ago
iPhone 20 Pro Rumored to Feature 3D-Printed Titanium Frame
16 hours ago
Apple's Official 2026 Black Friday Offer Starts Rolling Out
1 day ago
Halide Adds Fill Light Feature for iPhone Duo
1 day ago
MacBook Air Black Friday Deals Now Live With Massive $399 Savings
1 day ago
Amazon Discounts All MacBook Neo Models by $99 for Black Friday
2 days ago
Kodak Launches Unique AirTag Rival With E-Ink Display
2 days ago
2 days ago
Apple Still Working on Giant Foldable iPad That Could Cost $5,000
2 days ago
iPhones Dominate China's Weak Singles' Day Smartphone Sales
2 days ago
iPhone 20 Pro Could Feature Ceramic in Limited-Edition Model
2 days ago
Apple Faces Korean Regulator Review Over iPhone 16 AI Advertising
2 days ago
Apple Watch Ultra 4 Hits New Best-Ever Price of $649.99 for Black Friday
2 days ago
New Apple Store Opening in India, Download the Special Wallpaper Now
2 days ago
