Apple Reiterates: Force Quitting iOS Apps Doesn’t Help Battery Life
It's been a long-standing belief in some circles that using the multitasking feature of iOS to force quit apps can help save an iPhone's battery life, or improve the speediness of the software when the smartphone becomes slow. Earlier in the week, an iPhone user decided to email Apple CEO Tim Cook to put the issue to bed once and for all, and instead got a reply from Craig Federighi, Apple's senior VP of Software Engineering (via 9to5Mac).
Asked specifically whether Cook quits apps to save battery and if it's truly "necessary for battery life," Federighi jumped in with a concise "no and no." Although far from an official condemnation of the force quit belief by Apple, it is the most the company has directly said about the myth in the six years since multitasking became available in iOS 4.
multitasking battery email
Image via 9to5Mac
The simplistic nature of swiping apps off of the multitasking landing pad, and subsequently "quitting" them, helped create a widespread belief that an iPhone's battery could be preserved for a little longer. But as many have pointed out over the years, doing so could in fact do the complete opposite: you could be shortening the battery life of your iPhone.
A few exceptions can be made to certain processes, but for the most part when an app is pushed into the background it becomes completely frozen and ceases to use any of an iPhone's battery power. As relayed by a former Genius Bar technician, Scotty Loveless, force quitting an app purges all of its code from the RAM of the iPhone, requiring it to be re-loaded upon the next time you visit the app.
If it's an app you're going to often -- a weather or traffic experience, for example -- all of the forced closing and re-opening actually can worsen the life of an iPhone. Exceptions can be made by toggling off a feature called "Background App Refresh," which the Facebook app was found to be suspiciously circumventing in recent months, but in all other occurrences the process of force quitting each app to prolong battery life is erroneous.
Plus, iOS closes apps automatically as it needs more memory, so you're doing something your device is already doing for you. You are meant to be the user of your device, not the janitor. The truth is, those apps in your multitasking menu are not running in the background at all: iOS freezes them where you last left the app so that it's ready to go if you go back.
Unless you have enabled Background App Refresh, your apps are not allowed to run in the background unless they are playing music, using location services, recording audio, or the sneakiest of them all: checking for incoming VOIP calls , like Skype. All of these exceptions, besides the latter, will put an icon next to your battery icon to alert you it is running in the background.
In the case of the Facebook app, the company's mobile app was discovered to be the cause behind cases of dramatic battery drain, even when Background App Refresh was turned completely off. The social network site eventually implemented a fix for the problem, citing the major culprits as "CPU spin" in the app's code and silent background audio continuing to emanate from the service's auto-play videos after the app was closed.
That was a rare case, however, and users should stick closer to Federighi's succinct advice today instead of continuing to put long-term strain on the smartphone. If you're ever really concerned about daily battery usage, Apple offers a simple but useful tool to keep on top of things. Go to Settings > Battery > and scroll down to Battery Usage. "Last 24 Hours" and "Last 7 Days" can give you a full picture at where the heaviest-hitting battery life apps are coming from.
You can also restrict specific app access to Background App Refresh -- or turn it off altogether, although that can drastically hinder certain apps' key features -- in Settings > General > Background App Refresh.
Related Forum: iOS 9
Popular Stories
Apple iPhone 16e Feature
Apple Announces iPhone 16e With A18 Chip and Apple Intelligence, Pricing Starts at $599
Wednesday February 19, 2025 8:02 am PST by
Apple today introduced the iPhone 16e, its newest entry-level smartphone. The device succeeds the third-generation iPhone SE, which has now been discontinued. The iPhone 16e features a larger 6.1-inch OLED display, up from a 4.7-inch LCD on the iPhone SE. The display has a notch for Face ID, and this means that Apple no longer sells any iPhones with a Touch ID fingerprint button, marking the ...
iphone 17 pro asherdipps
iPhone 17 Pro Models Rumored to Feature Aluminum Frame Instead of Titanium Frame
Tuesday February 18, 2025 12:02 pm PST by
Over the years, Apple has switched from an aluminum frame to a stainless steel frame to a titanium frame for its highest-end iPhones. And now, it has been rumored that Apple will go back to using aluminum for three out of four iPhone 17 models. In an investor note with research firm GF Securities, obtained by MacRumors this week, Apple supply chain analyst Jeff Pu said the iPhone 17, iPhone...
apple launch feb 2025 alt
Here Are the New Apple Products We're Still Expecting This Spring
Thursday February 20, 2025 5:06 am PST by
Now that Apple has announced its new more affordable iPhone 16e, our thoughts turn to what else we are expecting from the company this spring. There are three product categories that we are definitely expecting to get upgraded before spring has ended. Keep reading to learn what they are. If we're lucky, Apple might make a surprise announcement about a completely new product category. M4...
iPhone 17 Roundup Feature 2
iPhone Design to Change 'Significantly' This Year
Monday February 17, 2025 7:09 am PST by
Apple is set to "significantly change" the iPhone's design language later this year, according to a Weibo leaker. In a new post, the user known "Digital Chat Station" said that the iPhone's design is "starting to change significantly" this year. The "iPhone 17 Air" reportedly features a "horizontal, bar-shaped" design on the rear, likely referring to an elongated camera bump. On the other...
Generic iOS 18
Here's When Apple Will Release iOS 18.4
Wednesday February 19, 2025 11:38 am PST by
Following the launch of the iPhone 16e, Apple updated its iOS 18, iPadOS 18, and macOS Sequoia pages to give a narrower timeline on when the next updates are set to launch. All three pages now state that new Apple Intelligence features and languages will launch in early April, an update from the more broader April timeframe that Apple provided before. The next major point updates will be iOS ...
Tim Cook Teases an 'Apple Launch' Next Wednesday
Thursday February 13, 2025 8:07 am PST by
In a social media post today, Apple CEO Tim Cook teased an upcoming "launch" of some kind scheduled for Wednesday, February 19. "Get ready to meet the newest member of the family," he said, with an #AppleLaunch hashtag. The post includes a short video with an animated Apple logo inside a circle. Cook did not provide an exact time for the launch, or share any other specific details, so...
iOS 18
iOS 18.4 Coming Next Week With These New Features for Your iPhone
Friday February 14, 2025 6:18 am PST by
The first iOS 18.4 beta for iPhones should be just around the corner, and the update is expected to include many new features and changes. Bloomberg's Mark Gurman expects the iOS 18.4 beta to be released by next week. Below, we outline what to expect from iOS 18.4 so far. Apple Intelligence for Siri Siri is expected to get several enhancements powered by Apple Intelligence on iOS...
Apple 2025 Thumb 1
Two of Apple's Oldest Products Are Finally Getting Updated This Year
Friday February 14, 2025 6:03 am PST by
Apple released the HomePod mini in November 2020, followed by the AirTag in May 2021, and both still remain first-generation products. Fortunately, rumors suggest that both the HomePod mini and the AirTag will finally be updated at some point this year. Below, we recap rumors about the HomePod mini 2 and AirTag 2. HomePod mini 2 In January 2025, Bloomberg's Mark Gurman said Apple is ...
Top Rated Comments
jdillings Avatar
117 months ago
I'm going to email him and ask him what hair product he recommends.
Score: 18 Votes (Like | Disagree)
arggg14 Avatar
117 months ago
In my experience quitting apps that are running in the backdrop absolutely improves battery life...
Score: 16 Votes (Like | Disagree)
mpe Avatar
117 months ago
Better answer would be: No and no, unless the app you are closing is Facebook.
Killing facebook is the only known way how to avoid it sucking battery in the background. (turning off background refresh won't help)
Score: 12 Votes (Like | Disagree)
mpe Avatar
117 months ago
My Facebook battery stats are:
8 minutes on screen, 3 hours in the background.
Federighi is wrong. Killing apps that would otherwise run in the background absolutely helps with battery life.
Score: 11 Votes (Like | Disagree)
pika2000 Avatar
117 months ago
As such I have uninstalled Facebook. Apple should mark the Facebook app as malware at this point since it is behaving like one, and Facebook's refusal to actually do anything about it.
ChrisCW11 Avatar
117 months ago
This is one feature I can't stand about iOS. While I am confident that apps suspended in the background are not necessarily consuming battery life I can't stand the idea of going to the app switcher view and seeing every app that I have ever used on iOS hanging out there. Seriously some app that I used once 6 months ago should not be shown in the app switcher even if it not going to consume even one tiny fraction of extra battery. Having to sit there an swipe shut every suspended app that I have ever used is absolutely ridiculous.
Simply put a time and count limit on the apps shown in the app switcher. Only show the last X apps used in the last Y amount of time. If I open up more than X apps, then the least accessed and oldest app is removed from the app switcher view. This doesn't mean the app loses its current state, just that you have to access it by "launching" from its icon. Any open app that hasn't been used after Y amount of time should just disappear from the app switcher.
NOBODY uses the app switcher to go back to an app they suspect they used once a year ago possibly sometime, they simply relaunch the app from its icon. Just restore its previous state and end this ******** by keeping it shown indefinitely on the app switcher.
I think fixing this stupid concept this will address a lot of the FUD around the app switcher and people thinking all these apps are consuming battery in the background. Personally the idea of having to "manage" the app switcher is one of the dumbest features that Apple ever implemented and someone with half a brain at Apple needs to re-engineer this feature as they have done it WRONG on iOS and now TVOS and OS X.
