TSMC's A9 Chip Outperforming Samsung's in Early iPhone 6s Battery Benchmarks
Following the launch of the iPhone 6s and 6s Plus last month, it was discovered that Apple is dual sourcing the A9 chip for the new devices from both TSMC and Samsung, with the chips from the two companies measuring at slightly different sizes due to different processes used in manufacturing the chips. As users began to determine which chips were used in their devices, data began to point toward a 60/40 split in favor of TSMC, although the ratio has shifted toward 50/50 as more data has been obtained.
Benchmarks have suggested there is little if any difference in chip performance between the two A9 variants, but some recent battery testing (via Engadget) is hinting at the possibility of significantly better battery life for models with the TSMC-manufactured A9 chip.
We should caution that data points remain few at this time and controlling for variables to accurately focus the comparison only on the differences in the A9 is difficult, but these limited tests are generating significant amounts of interest in our discussion forums and elsewhere.
Perhaps the most dramatic result comes from a reddit poster who compared Samsung and TSMC versions of the iPhone 6s Plus using the battery life test included in Geekbench 3, finding the TSMC version lasting nearly two hours longer than the model with Samsung A9 chip.
geekbench_tsmc_samsung_a9
Geekbench battery tests on TSMC (left) and Samsung (right) iPhone 6s Plus variants
Ran this test a couple times and results were consistent. Always about a 2 hour difference in duration. Both phones were tested using the same backup, same settings. Also tried testing them as new phones and results were similar.
We asked John Poole of Primate Labs, the developers of Geekbench, for any insight into the dramatic differences being observed in some cases, and he noted there have been rumors of TSMC's 16-nanometer process being "superior" to Samsung's 14-nanometer process in power consumption. He was, however, surprised by the amount of difference in observed battery life considering the various components have essentially identical performance benchmarks. Ideally, further controlled testing can be performed to offer a more accurate comparison between the variants.
More signs of a battery life difference between TSMC and Samsung variants come from Chinese site MyDrivers (via reddit), which ran a series of tests [Google Translate] comparing otherwise identical phones as they performed JavaScript and video playback tasks and watched the rates of battery depletion. As with the Geekbench testing, MyDrivers saw measurably faster battery drain on the Samsung iPhone 6s compared to the TSMC version. Follow-up testing [Google Translate] using AnTuTu Benchmark also showed the Samsung model tending to run up to a few degrees hotter than the TSMC version.
antutu_tsmc_samsung_a9
TSMC iPhone 6s (left) benchmarking slightly higher and with more battery remaining (77% vs. 71%) than Samsung version (right) after 12 runs of AnTuTu Benchmark
While these early synthetic benchmarks and processor-intensive tests do hint at the possibility of somewhat better power efficiency for the TSMC A9 over the Samsung A9, any impact on real-world performance has yet to be firmly established. Posters in our forums are sharing their general impressions based on their testing and daily usage, yielding a mixture of opinions. Users will no doubt continue their testing, however, in attempting to determine just how visible or invisible these internal variations in the latest iPhones really are in daily use.
Those interested in seeing which variant of the A9 is included in their new iPhones can use an app such Lirum Device Info Lite, which displays on the Model Information screen whether the device has a Samsung (N66AP for 6s Plus or N71AP for 6s) or TSMC (N66mAP for 6s Plus or N71mAP for 6s) chip.
Tags: A9, Samsung, TSMC
Related Forum: iPhone
Popular Stories
Apple iPhone 16e Feature
Apple Announces iPhone 16e With A18 Chip and Apple Intelligence, Pricing Starts at $599
Wednesday February 19, 2025 8:02 am PST by
Apple today introduced the iPhone 16e, its newest entry-level smartphone. The device succeeds the third-generation iPhone SE, which has now been discontinued. The iPhone 16e features a larger 6.1-inch OLED display, up from a 4.7-inch LCD on the iPhone SE. The display has a notch for Face ID, and this means that Apple no longer sells any iPhones with a Touch ID fingerprint button, marking the ...
iphone 17 pro asherdipps
iPhone 17 Pro Models Rumored to Feature Aluminum Frame Instead of Titanium Frame
Tuesday February 18, 2025 12:02 pm PST by
Over the years, Apple has switched from an aluminum frame to a stainless steel frame to a titanium frame for its highest-end iPhones. And now, it has been rumored that Apple will go back to using aluminum for three out of four iPhone 17 models. In an investor note with research firm GF Securities, obtained by MacRumors this week, Apple supply chain analyst Jeff Pu said the iPhone 17, iPhone...
apple launch feb 2025 alt
Here Are the New Apple Products We're Still Expecting This Spring
Thursday February 20, 2025 5:06 am PST by
Now that Apple has announced its new more affordable iPhone 16e, our thoughts turn to what else we are expecting from the company this spring. There are three product categories that we are definitely expecting to get upgraded before spring has ended. Keep reading to learn what they are. If we're lucky, Apple might make a surprise announcement about a completely new product category. M4...
iPhone 17 Roundup Feature 2
iPhone Design to Change 'Significantly' This Year
Monday February 17, 2025 7:09 am PST by
Apple is set to "significantly change" the iPhone's design language later this year, according to a Weibo leaker. In a new post, the user known "Digital Chat Station" said that the iPhone's design is "starting to change significantly" this year. The "iPhone 17 Air" reportedly features a "horizontal, bar-shaped" design on the rear, likely referring to an elongated camera bump. On the other...
Generic iOS 18
Here's When Apple Will Release iOS 18.4
Wednesday February 19, 2025 11:38 am PST by
Following the launch of the iPhone 16e, Apple updated its iOS 18, iPadOS 18, and macOS Sequoia pages to give a narrower timeline on when the next updates are set to launch. All three pages now state that new Apple Intelligence features and languages will launch in early April, an update from the more broader April timeframe that Apple provided before. The next major point updates will be iOS ...
Tim Cook Teases an 'Apple Launch' Next Wednesday
Thursday February 13, 2025 8:07 am PST by
In a social media post today, Apple CEO Tim Cook teased an upcoming "launch" of some kind scheduled for Wednesday, February 19. "Get ready to meet the newest member of the family," he said, with an #AppleLaunch hashtag. The post includes a short video with an animated Apple logo inside a circle. Cook did not provide an exact time for the launch, or share any other specific details, so...
iOS 18
iOS 18.4 Coming Next Week With These New Features for Your iPhone
Friday February 14, 2025 6:18 am PST by
The first iOS 18.4 beta for iPhones should be just around the corner, and the update is expected to include many new features and changes. Bloomberg's Mark Gurman expects the iOS 18.4 beta to be released by next week. Below, we outline what to expect from iOS 18.4 so far. Apple Intelligence for Siri Siri is expected to get several enhancements powered by Apple Intelligence on iOS...
Apple 2025 Thumb 1
Two of Apple's Oldest Products Are Finally Getting Updated This Year
Friday February 14, 2025 6:03 am PST by
Apple released the HomePod mini in November 2020, followed by the AirTag in May 2021, and both still remain first-generation products. Fortunately, rumors suggest that both the HomePod mini and the AirTag will finally be updated at some point this year. Below, we recap rumors about the HomePod mini 2 and AirTag 2. HomePod mini 2 In January 2025, Bloomberg's Mark Gurman said Apple is ...
Top Rated Comments
ck2875 Avatar
122 months ago
Remember a week ago when everyone was saying they were going to return their TSMC devices for Samsung devices?
Score: 84 Votes (Like | Disagree)
MysteriousStain Avatar
122 months ago
So much for all the whining about wanting the Samsung.
Score: 71 Votes (Like | Disagree)
Icaras Avatar
122 months ago
This thread is going to be popcorn worthy.
Score: 56 Votes (Like | Disagree)
Nunyabinez Avatar
122 months ago
People without a background in statistics should not use the term significant so causally. With an N of 1 you can't claim a statistically significant difference. There may be real differences, but anecdotal crap like this just fuels clicks and wild irresponsible posting.
Score: 44 Votes (Like | Disagree)
D.T. Avatar
122 months ago
The phones with the Samsung sourced A9 also bend easier.
Score: 40 Votes (Like | Disagree)
jeffreyscurtis Avatar
122 months ago
HMMM.... One phone has a SIM installed and is activated on cellular and one has no SIM.
Score: 31 Votes (Like | Disagree)
