OS X Mavericks Tidbits: System Requirements, Redesigned Activity Monitor, App Battery Monitoring, and More
At yesterday's Worldwide Developers Conference, Apple unveiled its next generation operating system, OS X Mavericks. While Mavericks incorporates a number of significant changes like a redesigned Finder, a Safari overhaul, and new Compressed Memory settings, there are also a number of other, smaller changes that MacRumors forum readers and other sources have unearthed.
AppNap Settings - AppNap, which is designed to conserve battery by sending apps into a hibernation mode, can be disabled on a per app basis by developers.
New Activity Monitor - The Activity Monitor has been redesigned, offering new charts and graphs that show bytes/packets sent/received. It also includes a new energy tab that shows the energy impact of apps and includes a built-in system diagnostics tool.
activitymonitor2
Design Updates - Along with some app redesigns, Apple has removed much of the linen look that was introduced with Mountain Lion. Both Dashboard and the log-in screen have a new background. Launchpad folders also have a new translucent background, and Mavericks users will notice new fade in and fade out behaviors. Finally, Finder selections have new rounded corners and the dock has a new look.
Notification Center - The standard gray linen background has been removed from Notification Center, in favor of a plain, dark background. Notification Center also includes a new Messages sharing option, allowing users to send messages without opening the app. It functions similarly to current Facebook and Twitter integration.
Battery Status - The Battery dropdown menu has received a new category in Mavericks, displaying apps that are using a significant amount of power.
batterypower
Offline Dictation - Mavericks introduces a new “Enhanced Dictation” feature that allows users to use dictation without an internet connection. It also includes live feedback, which displays input before the enter key is pressed. The setting includes a 785MB download to enable the feature.
Automatic App Updates - Automatic app updates are a new iOS 7 feature that has also been introduced to OS X with Mavericks. With this setting enabled, Mac App Store updates will be automatically installed in the background.
LinkedIn Integration - OS X Mavericks includes native LinkedIn support.
Do Not Disturb - While the Mac Notification Center already has a Do Not Disturb setting, Mavericks adds a new timer option that lets users schedule set times for the feature to be activated, similar to how the setting functions in iOS.
Open GL 4 - Apple has updated OpenGL support in Mavericks and the OS will be available with the Open GL 4.1 Core Profile for Macs that support the feature.
Text Shortcuts - Text shortcuts that were previously only available on iOS have been added with Mavericks. For example, "omw" is replaced with "On my way!" as in iOS.
Skeuomorphism - While the Notes and Calendar apps have been redesigned with a new interface that removes some of the previous skeuomorphic design elements, Messages, Reminders, and Game Center have not been updated with a new design.
notesredesign
The redesigned Notes app
iCloud Folder - Finder has a new iCloud folder, which displays documents that are stored in the cloud.
iBooks Store - On its website, Apple has begun referring to the iBookstore as the "iBooks Store", which may be indicative of an upcoming branding change.
System Requirements - According to AppleInsider, Mavericks will run on most machines that are capable of running Mountain Lion, including some systems dating back to 2007. Notably, all MacBook Airs after late 2008 can run the software, as well as mid/late 2007 15-inch MacBook Pros, mid–2009 or later 13-inch Pros, and late 2007 or later 17-inch Pros.
These are just a small fraction of the numerous changes that will likely be introduced with OS X Mavericks. Additional updates to the beta software will undoubtedly include even more new features, which are being noted in a thread on the MacRumors forums.
Apple made OS X Mavericks available for developers yesterday. While there is no current expected public release date, the final version of OS X Mavericks is expected in the fall.
Related Forum: OS X Mavericks
Popular Stories
iPhone 17 Pro Dual Tone Horizontal 1
iPhone 17 Pro Launching This Year With These 8 New Features
Tuesday January 28, 2025 11:48 am PST by
While the iPhone 17 Pro and iPhone 17 Pro Max are not expected to launch until September, there are already plenty of rumors about the devices. iPhone 17 Pro concept based on rumors Below, we recap key changes rumored for the iPhone 17 Pro models as of January 2025: More aluminum: iPhone 17 Pro models are rumored to have an aluminum frame, whereas the iPhone 15 Pro and iPhone 16 Pro models ...
m3 macbook pro blue
Apple Explains How to Keep Your Mac From Turning on When Opening Lid
Thursday January 30, 2025 4:14 pm PST by
Apple designed Macs with Apple silicon chips to automatically turn on and start up when the Mac's lid is opened or when the Mac is connected to power, but there is a workaround in macOS Sequoia if you don't like this behavior. In a new support document, Apple provided separate instructions on how to prevent an Apple silicon Mac from turning on when the lid is opened or when it's connected to ...
50 New iPhone Features Apple Added Since iOS 18 1
50 iPhone Features Apple Added to iOS 18 Since September
Thursday January 30, 2025 2:41 am PST by
Since iOS 18 was released in September 2024, Apple has introduced an unprecedented number of new features and improvements across several point updates. With iOS 18.1, 18.2, and 18.3, users have seen a host of tweaks and changes designed to enhance everything from the Mail app to Camera Control on the iPhone 16. Below, we've listed 50 of the features and changes that have been rolled out...
iPhone 17 Air Size Feature
iPhone 17 Air Design, Specs, and More: All the Rumors So Far
Wednesday January 29, 2025 4:00 am PST by
This year, Apple is expected to discontinue the iPhone "Plus" device in its iPhone 17 lineup to make way for an iPhone "Air," so-called because of its thin profile. Below is a compilation of every rumor and leak we have registered from reputable sources thus far about Apple's new entry in its flagship smartphone lineup. iPhone 17 "Air"? About the Name There has been some uncertainty...
airpods 4 blue
Apple Finally Explains How to Install New Firmware on Your AirPods
Monday January 27, 2025 11:17 am PST by
Apple regularly releases new firmware for the AirPods, AirPods Pro, and AirPods Max, but the company has historically provided limited information on how to initiate an update. That changed today, and Apple updated its AirPods firmware support page with more specific instructions. Prior to today, here's what Apple said on the subject: Firmware updates are delivered automatically while your...
Generic iOS 18
When Will Apple Release the iOS 18.4 Beta?
Wednesday January 29, 2025 3:11 pm PST by
On January 27, Apple released iOS 18.3, iPadOS 18.3, and macOS Sequoia 15.3, which means we're now ready for a new round of beta testing. The next betas are rumored to have important new Siri Apple Intelligence features, so when can we expect the software? There are typically few pauses between beta updates, and Apple often seeds a new beta just a day or two after new software comes out....
Apple CEO Tim Cook: There's a 'Lot of Innovation' Left for Future iPhone Development
Thursday January 30, 2025 2:43 pm PST by
During today's earnings call covering the first fiscal quarter of 2025, Apple CEO Tim Cook was asked about whether he felt there was room for form factor innovation in future iPhone models, with the question hinting perhaps spurred by rumors of the upcoming "iPhone 17 Air." Cook often declines to provide insight into future products during earnings calls, but he did give an encouraging...
windows 11 iphone start menu
Windows 11 Now Lets You Access Your iPhone from the Start Menu
Thursday January 30, 2025 1:21 am PST by
Microsoft has announced an update to Windows 11 that allows iPhone users to access their devices directly from the Start menu, bringing feature parity with its existing Android phone integration. The new functionality lets you view your device's battery status, cellular connectivity, and recent activities without leaving the Windows environment. You can also access messages, calls, and file...
Top Rated Comments
ECUPeeDee14 Avatar
152 months ago
Support for machines from 2007 is pretty impressive.
Score: 38 Votes (Like | Disagree)
Ventilatedbrain Avatar
152 months ago
You could sense in the keynote and even see it in Tims face.. Apple is definitely going full force and I couldnt help but smile for for most part..
A little confession
I even clapped when I saw the iOS 7 vid even though I was home alone
Score: 36 Votes (Like | Disagree)
Slix Avatar
152 months ago
Why is the OS name plural anyway? OS X releases have always had singular names... Tiger, Panther, Lion, Leopard, etc... now... Mavericks?
OS X Maverick would have sounded nicer.
Also, moving from felines to livestock? Kind of a downgrade I think...
http://en.wikipedia.org/wiki/Mavericks_(location)
Apple said the new naming scheme will be places that inspire them from California.
Score: 15 Votes (Like | Disagree)
napabar Avatar
152 months ago
The new Dock looks pathetic. But following the hideous iOS 7, it is no surprise that the MacOS will be destroyed as well...
Dock looks the same. iOS 7 isn't hideous. Got anything else?
Score: 12 Votes (Like | Disagree)
macs4nw Avatar
152 months ago
Why is the OS name plural anyway? OS X releases have always had singular names... Tiger, Panther, Lion, Leopard, etc... now... Mavericks? OS X Maverick would have sounded nicer.
I don't think that was their intention. California locations is what they had in mind. Some suggestions:
La Brea (runs like molasses)
San Andreas (catastrophically unstable)
Tahoe (freezes regularly)
Lombard (pretty but slow)
Sacramento (dysfunctional)
Telegraph (keeps begging you for money)
Alcatraz (the most locked-down OS yet)
Pasadena (shuts down every night at 8:30)
Atherton (open only to the wealthiest customers)
San Fernando (optimized for porn)
Donner (cannibalizes other Apple products)
Zabriskie (spontaneously combusts)
Cupertino (assumes you don't know what you want until it shows it to you)
source: http://www.slate.com/blogs/future_tense/2013/06/10/apple_os_x_mavericks_for_what_california_location_should_apple_name_its.html
I suggest, with tongue firmly in cheek: Big Sur.
zorinlynx Avatar
152 months ago
There's a truck next to Dropbox. Has Apple finally given us a new version of Font/DA Mover?
:D
That truck is put there by an app, Transmit.
It's a rather excellent (IMHO) FTP/SFTP client.
