Part leaks claimed to be for the next-generation iPhone continue to surface as the all-but-confirmed September 12 media event introduction approaches, with the latest batch of photos showing what appears to be the most completely assembled front panel seen yet. The new photos, which were highlighted by Apple.pro [Google translation], were posted to a Photobucket account that previously posted photos of measurements showing that the third-generation iPad would be thicker than the iPad 2, as well as the first leaked photo of the next-generation iPhone front panel in white.
Assembled front panel complete with LCD frame, front camera, and home button
The latest set of photos posted to the account shows a nearly fully assembled front panel with even more parts than seen in last week's leak of the front panel with the LCD attached. The new photos show not only the LCD attached to the front panel but also the home button installed and secured by a metal bracket, the shielding frame for the display that was first seen as a standalone part earlier this month, and the front-facing camera installed behind additional shielding.
Closeups of top portion showing flex cables for display and front camera
Increasing numbers of parts are leaking in ever more complete states of assembly, offering good looks at the overall appearance and layout of the next-generation iPhone.
While the front of the device will appear very similar to the iPhone 4S/4 with the exception of a taller screen and slight tweaks in the locations of the camera and sensors, it is the rear of the device that seems to be generating the most discussion. The forthcoming iPhone appears to incorporate a unibody design that will incorporate a two-toned rear/side shell featuring a large metal section in the center paired with two strips of glass or plastic at the top and bottom that will allow for transmission of the numerous types of signals necessary for the device's operation.
Closeup of home button installed behind metal bracket
Note: Watermarks have been obscured due to political statements contained within them.
Update: Mac Otakara points out that the unknown square-shaped feature visible at the top may be a near field communications (NFC) chip.
While the iPhone 17 Pro and iPhone 17 Pro Max are not expected to launch until September, there are already plenty of rumors about the devices.
Below, we recap key changes rumored for the iPhone 17 Pro models as of April 2025:
Aluminum frame: iPhone 17 Pro models are rumored to have an aluminum frame, whereas the iPhone 15 Pro and iPhone 16 Pro models have a titanium frame, and the iPhone ...
Apple may have updated several iPads and Macs late last year and early this year, but there are still multiple new devices that we're looking forward to seeing in 2025. Most will come in September or October, but there could be a few surprises before then.
We've rounded up a list of everything that we're still waiting to see from Apple in 2025.
iPhone 17, 17 Air, and 17 Pro - We get...
Tuesday April 15, 2025 6:31 am PDT by Tim Hardwick
Apple is preparing a "bold" new iPhone Pro model for the iPhone's 20th anniversary in 2027, according to Bloomberg's Mark Gurman. As part of what's being described as a "major shake-up," Apple is said to be developing a design that makes more extensive use of glass – and this could point directly to the display itself.
Here's the case for Apple releasing a truly all-screen iPhone with no...
Apple's upcoming foldable iPhone (or "iPhone Fold") will feature two screens as part of its book-style design, and a Chinese leaker claims to know the resolutions for both of them.
According to the Weibo-based account Digital Chat Station, the inner display, which is approximately 7.76 inches, will use a 2,713 x 1,920 resolution and feature "under-screen camera technology." Meanwhile, the...
A common complaint about the iPad Pro is that the iPadOS software platform fails to fully take advantage of the device's powerful hardware.
That could soon change.
Bloomberg's Mark Gurman today said that iPadOS 19 will be "more like macOS."
Gurman said that iPadOS 19 will be "more like a Mac" in three ways:Improved productivity
Improved multitasking
Improved app window management...
Apple is working on a new version of the Vision Pro with two key advantages over the current model, according to Bloomberg's Mark Gurman.
Specifically, in his Power On newsletter today, Gurman said Apple is developing a new headset that is both lighter and less expensive than the current Vision Pro, which starts at $3,499 in the U.S. and weighs up to 1.5 pounds.
Gurman said Apple is also...
The first iOS 19 beta is less than two months away, and there are already a handful of new features that are expected with the update.
Apple should release the first iOS 19 beta to developers immediately following the WWDC 2025 keynote, which is scheduled for Monday, June 9. Following beta testing, the update should be released to the general public in September.
Below, we recap the key...
Apple has confirmed that it will be permanently closing its retail store in the heart of Bristol, England, and there is no replacement in sight.
Apple Bristol in 2023
Apple Bristol will be closing its doors on Saturday, August 9, due to redevelopment plans at the Cabot Circus Shopping Centre, and the adjacent Bristol Shopping Quarter. According to news reports, and a building application, the ...
Thursday April 10, 2025 4:19 am PDT by Tim Hardwick
Apple in October 2024 overhauled its 14-inch and 16-inch MacBook Pro models, adding M4, M4 Pro, and M4 Max chips, Thunderbolt 5 ports on higher-end models, display changes, and more. That's quite a lot of updates in one go, but if you think this means a further major refresh for the MacBook Pro is now several years away, think again.
Bloomberg's Mark Gurman has said he expects only a small...
