One of the most frequent reasons for an iPhone to go on a trip to the Apple Store's Genius Bar is because of water damage. Typically, a water damaged iPhone can be replaced for a flat $199 fee, though with the recently launched AppleCare+, that price can be reduced to $49.
Most ultra-durable iPhone cases, like Otterbox's Defender or Case Mate's TANK, are merely water-resistant -- not actually water proof. They might protect an iPhone during a rainstorm, but they can't handle a dunk in the pool or -- perhaps more likely -- a drop in the toilet.
lifeproofcase
LifeProof's iPhone case, however, promises otherwise. The manufacturer claims the case is Waterproof, Dirtproof, Snowproof, and Shockproof -- the video below demonstrates the waterproof claim. The case completely covers the iPhone, using rubber gaskets around each seal to ensure a tight fit. There is an removable screw that plugs the headphone jack, allowing easy access to that port when necessary. LifeProof also sells an adapter that allows waterproof headphones to be hooked up for use while swimming.
It's not for those who like to switch cases frequently, however. The installation manual warns that the gaskets have a limited lifespan and the case shouldn't be removed and reinstalled more than a few dozen times. Further, the installation process is a bit of a pain -- before it is installed, LifeProof recommends that the case be put underwater for an hour, to ensure that there are no leaks in the gaskets.
The $79 LifeProof case comes in black, white, pink and purple. It is available from LifeProof's online store.
Top Rated Comments
Analog Kid Avatar
172 months ago
I wonder how cell reception is 10 feet under water.... I would assume that the water kills the radio signals big time.
AT&T's underwater coverage sucks...
agentkow Avatar
172 months ago
My friend has a LifeProof case and drops in the the hot tub all the time just to freak people out.
swordfish5736 Avatar
172 months ago
Reminds me of when I got the original iPhone and would take people's car keys and try to scratch the screen
soco Avatar
172 months ago
Never again will I fear a game of Plants vs. Zombies on the pooper.
mrxak Avatar
172 months ago
I have been using this case since day one of the 4S release. I use it every day in the shower for listening to music or internet radio, or even checking my email or new sites. I can definitely attest to its waterproofness. The first time I used it in the shower, I was nervous, but now I don't even think about it. The only two problems can't really be helped, and that's misting on the screen from the spray (brush the moisture off or run it under a stream directly to fix), and the capacitive screen stops working underwater since the water is conductive. Just with water splashed or sprayed on there, though, the multitouch still works if your hands aren't too wet so the screen gets confused. As I said, these things can't be helped, they're just part of the physical world we live in.
I never intentionally dropped my phone to test its durability against falls, and so for a while, that aspect of the case went untested, but in the last month or two, I've accidentally dropped the thing onto hard surfaces a few times. No problems, phone is great.
As for sound quality, I do believe it has an effect on the speaker, but it's not that bad. Like I said, I use the speaker every day in the shower, and it's great. Using the ear speaker it sounds normal. In terms of mic quality, it's far away better than the 3G mic with no case on, which is all I have to go by. When I made my first phone call with the new 4S, before I even had a chance to say I had a new phone, the person on the other side remarked that my voice was really clear, so I guess that says something. All the buttons work fine, the camera works fine, the headphone port is covered and the cover needs to be unscrewed before you can use it, or you can screw in the waterproof adapter and just have a dangly thing attached.
The screen protector is rather reflective, so in very bright sunlight, it might bother you. It doesn't bother me, but I thought I'd mention it.
The case itself is quite stylish, I think. Very low-profile, adds a bit of length on the bottom, but not much width or depth. It's not trying to look fancy, or rugged, or pretty, it's just a good solid case where everything works and you don't have to ever worry about it. Doesn't get stuck in pockets, all the buttons work just fine, and the belt clip you can get for it is just as solid (and locks).
Anyway, if you want to protect your iPhone, I highly recommend this case. I decided on getting this instead of AppleCare and don't regret it one bit.
chainprayer Avatar
172 months ago
Good to know that if I'm strolling through a power substation and get fried, my apps will be safe.
Popular Stories
iPhone 17 Pro 34ths Perspective
iPhone 17 Pro Launching Later This Year With These 10 New Features
Sunday March 23, 2025 10:00 am PDT by
While the iPhone 17 Pro and iPhone 17 Pro Max are not expected to launch until September, there are already plenty of rumors about the devices. Below, we recap key changes rumored for the iPhone 17 Pro models as of March 2025: Aluminum frame: iPhone 17 Pro models are rumored to have an aluminum frame, whereas the iPhone 15 Pro and iPhone 16 Pro models have a titanium frame, and the iPhone ...
maxresdefault
Apple Releases iOS 18.4 With Priority Notifications, Ambient Music, New Emoji and More
Monday March 31, 2025 10:03 am PDT by
Apple today released iOS 18.4 and iPadOS 18.4, the fourth major updates to the iOS 18 and iPadOS 18 operating system updates that came out last year. iOS 18.4 and iPadOS 18.4 come two months after Apple released iOS 18.3 and iPadOS 18.3. Subscribe to the MacRumors YouTube channel for more videos. The new software can be downloaded on eligible iPhones and iPads over-the-air by going to...
top stories 2025 03 29
Top Stories: WWDC 2025 Announced, iPhone 17 Pro and iOS 19 Rumors, and More
Saturday March 29, 2025 6:00 am PDT by
Apple's big developer event is a little over two months away, and rumors about what we can expect to see in Apple's next major operating system updates are becoming increasingly frequent. A public release of iOS 18.4 is also imminent with a number of updates and improvements, although we won't be getting the major Apple Intelligence Siri upgrades that had reportedly been planned for this...
Magic Mouse Green
What to Expect From the Magic Mouse 3
Saturday March 29, 2025 10:15 am PDT by
Apple is reportedly working on a new Magic Mouse. Below, we recap what to expect. The two key rumors for the Magic Mouse 3 so far include a relocated charging port, along with a more ergonomic design. It was briefly rumored that the Magic Mouse 3 would also feature voice control, but that was misinterpreted information. Relocated Charging Port While the Magic Mouse switched from...
iOS 18
iOS 18.4 Expected Next Week - Here Are the Release Notes
Friday March 28, 2025 2:01 pm PDT by
With the second release candidate of iOS 18.4 that Apple seeded out today, the company finally provided us with release notes that give a full rundown on what to expect. There's an Apple Vision Pro app, new Apple Intelligence features for notifications and additional language support, plus an Apple News Food feature for Apple News+ subscribers, and several updates that should improve the...
Six Things to Know About Apple's Upcoming Foldable iPhone
Friday March 28, 2025 3:54 pm PDT by
We've been hearing rumors about a foldable iPhone for almost a decade now, but it looks like we might finally see the device come to fruition in 2026. We're going to be waiting many more months for the foldable iPhone, but so far we're hearing good things. Apple wants to make it creaseless. It's taken Apple multiple years to design a foldable iPhone that it's satisfied with because Apple ...
iOS 19 visionOS UI Elements
Apple Codename Provides Clue About iOS 19's Rumored New Design
Sunday March 30, 2025 6:40 am PDT by
Multiple sources have claimed that iOS 19 will introduce a new design with more translucent buttons, menus, notification banners, and more, and there is now another clue that points towards this glass-like appearance. Bloomberg's Mark Gurman today said the new design project is codenamed "Solarium" internally. A solarium is a room with glass walls that allow in plenty of sunlight, so this...
macOS Sequoia Feature
Apple Releases macOS Sequoia 15.4 With Mail Categorization and More
Monday March 31, 2025 10:04 am PDT by
Apple today released macOS Sequoia 15.4, the fourth major update to the macOS Sequoia operating system that launched in September. macOS Sequoia 15.4 comes two months after the launch of macOS Sequoia 15.3. Mac users can download the ‌‌macOS Sequoia‌‌ update through the Software Update section of System Settings. It is available for free on all Macs able to run macOS 15. With...
